BitsPower Rotary 90-Degree Fitting
BitsPower Rotary 90-degree Fitting Review
If you think of reviews, I’d dare say that fittings don’t pop to mind first. They may not even pop to mind at all. I mean, sheesh, it’s a fitting. But I would say that not all fittings are created equal.
First off, a bit of fitting facts. There is currently a general standard for watercooling componentry, namely G1/4. It is also known as BSPP ¼, for British Standard Parallel Pipe. The ¼ refers to the radius of the internal diameter (ID) of the fitting, making it a ½ inch fitting. Also, there are G3/8, NPT ½, and 9/16 fittings available. Those, however, are more proprietary, belonging to ThermoChill, Swiftech and Danger den, respectively.
Moving forward, this is a review of a relative newcomer to the watercooling market-BitsPower. I noticed them showing up last year with some very well machined parts, and today I’m here to share one of them with you.
This is the Bitspower Rotary 90, and I know you’re wondering what’s so special. I’ll cover why I actually found quite an interest in something as mundane as a fitting (I’ve been watercooling since late 2002…)
It arrived in a sealed plastic bag bearing the BitsPower logo, labeled simply “G1/4 silver Shining Rotary Angel ½ Fitting”. It’s SOLID, though. General estimates put it at roughly triple the weight of my DD Hi-Flow 9/16 barbs. Speaking of…
This is one of the accused, standing in to help me explain what’s great about this. You can get a good deal of scale if you’ve ever used any WC fittings.
Looking face on, we can see the ID of the fitting is much bigger (comparatively) on the BP fitting.
The ID of the threaded end is smaller, though, which does sort of follow, as the 9/16 is a larger threading. Notice, however, the same proportion of wall material left.
Also of note is the captive O-ring, which works much better in preventing leaks.
Just to finally drive this point home, though, the 9/16 fitting actually slips inside the BP partways.
Mounting is simple, it screws in finger tight, and can turn in any direction. Certainly a boon in any case, especially cramped ones. Also, the threaded depth is shallow, which means it doesn’t project into thin topped brass blocks. (Or my Koolance full-cover that’s posing so gracefully.)
As you can see, this really is a step forward-no longer do we have to hope the 90 fitting ends up in the right place or buy restrictive, smaller fittings. BitsPower makes an entire line of hard-to-find, extremely innovative fittings, and I’m glad to have gotten to show you this one.
My thanks to RealRedRaider of XtremeSystems for the giveaway, and Gary at Sidewinder Computers for making it possible.
Also, thank you to my collection of vintage DD fittings and blocks that I no longer use for helping me display this fitting.
Can you get the outer dimension of the knurled end? I am trying to establish if they will work on a aquagratiX FC block. It's a little tight w/ 3/8 x 5/8 compression fittings and I was considering the 90 or 45* rotary's.
17mm. As measured by my slide rule. next tool will be calipers, lol.
Calipers...Harbor Freight, $15
- You may not post replies
- You may not edit your posts
Forum Rules
