yeah, very similar... the only difference is that on k10 you can actually ramp up the l3 cache clock independantly from the imc, right?
and yeah, 3x2gb is what everybody will run, except for benchers and xp fans who stick to 3x1gb.
the interesting part is that k10 cant get a ref clock much above 230 and i7 seems to be stuck at about that speed too, even lower actually... i wonder if there is some reason for this or its just a coincidence and the i7 bclock is really just limited by qpi and nothing else...
and if thats the case, then maybe amds ref clock is limited by some other clock that gets derived from the ref clock?
IMC and L3 same speed...as far as I remember
Regards Phenom, i have seen 280+ here...other have seen 300, its not the CPU that is the issue
__________________
Got a problem with your OCZ product....? Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
I got 4226 but all with the multi..
Max I could do on the buss was 150 with any multi
__________________ Crunch with us, the XS WCG team The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Originally Posted by Frisch
If you have lost faith in humanity, then hold a newborn in your hands.
is that the max stable for 4 cores loaded?
if yes then thats pretty good on air!
only 150 though is weird... did you lower the qpi divider to 18?
That was max SP1M stable with HT enabled.
What QPI divider? I don't see one in this bios..
i was wrong about memory dividers, its not derived from the uncore clockspeed but multiplier directly from the Bclock, my bad!
i corrected it and added a lot more details to the first post
Very nice writeup. Your post will save users a lot of time when first jumping to this platform. Also makes it easier to choose which processor should be bought based on their requirements and expectations.
__________________
#1 Rule Of The Internet - The majority of writing stated as or giving the impression of fact is little more than the author's opinion. And more times than not that opinion is based on little or no knowledge of the topic.
thanks
and yes, that was the idea, to make sure people know what to expect.
around 4Ghz should be max with the 920 and good aircooling, which isnt bad at all, and despite everything beeing locked, DDR3 1600 is possible with the 8x memory multiplier and a bclock of 200. going from 1066 to 1600 barely gives any boosts in games or 3d benchmarks actually... its great for synthetic memory benchmarks, but thats about it.
according to this article on bit-tech.net going from 1066 777 to 1600 777 doubled their memory bandwidth in synthetic tests, but this memory overclock plus going from 2.66ghz to 4ghz with a gtx280 gave them a boost of:
4fps in crysis (~10% boost)
6fps in far cry2 (~10% boost)
20fps in hl2 (~10% boost)
so a 50% boost in cpu clocks and a 50% boost in memory clocks results in a 10% performance boost in games... based on that id say:
920:
people who want to try the latest platform
people who want sli on an intel system or might want it in future
occasional gamers
hardcore gamers
workstation users
overclockers on air
940:
workstation users
overclockers on air
overclockers on water
overclockers on xtreme cooling
965:
demanding workstation users
bandwidth fetishists
3dmark fetishists
people with a huge budget seeking the best of the best
__________________
Please note: I am not here to provide any kind of official NCIX support on these forums.
For faster (and official) service please contact me at Linus@ncix.com, or please contact our customer care team at wvvw.NCIX.com (Canada) or wvvw.NCIXUS.com (America)
it seems higher memory multipliers and uncore multipliers will be unlocked on retail 920 and 940 chips after all?
i hope this is true, after all thats what intel promised everybody at idf and several other occasions
Hopefully this will be prove to be true. Although as you have already wrote it won't make a big difference either way for most users but the option would be nice to have.
__________________
anything being unlocked def makes anything more wantable to me
it's gonna be a fun the next copula years for shure
__________________
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
Weird thing, of 5 motherboards I tested only MSI Eclipse allowed all memory dividers with i7-920. I think other boards will have them unlocked with new bios versions.
__________________ www.teampclab.pl
MOA 2009 Poland #2, AMD Black Ops 2010
Test bench: lots of ddr3
Hey Saaya, you haven't really touched on CPU PLL voltage. Any thoughts?
__________________
Another question: Is max BClk determined by the CPU or the motherboard?
__________________
with the same cpu?
i checked our 920s and 940s and they have the memory multipliers locked.
basically the 920 and 940 cpus we have are double locked, uncore is locked AND the mem multis are locked.
its possible that you have a chip which doesnt have uncore and mem multis locked, but only the msi bios implemented uncore ratio changes for non 965 parts. and if the uncore doesnt change, then you cant use the higher memory multipliers...
havent played with it yet...
both somewhat, but its more a cpu than board thing i think.
Originally Posted by SAE
I think, CPU maxes at about 220MHz and boards determine if you are able to get there.
yeah, but as far as i know every board can get there... and its not really 220Mhz that you gotta reach, its the 4Ghz QPI speed...
