Well if you can see a reference voltage next to anything manually set it to that so then if you up your FSB they should remain locked if you want to be on the safe side.
What the hell mobo & CPU blown up?....could understand the mobo burning out, but the CPU getting killed as well???...MOSFET even melted the soilder contacts, must have got REALLY hot.
Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
I hear this high pitched noise as well on mine whenever udner heavy load...balls!
I was opening a new tab to newegg after reading first half of thread. I've since closed it without ordering. i'll wait for a few. Sorry for your loss guys. Who had the 3rd e8600 die? PcCI2 (1) , dinos (2) and ?. My EVGA 680i's all had that high pitched noise while stressing. Annoying!!
Gigabyte Z68X UD7
Intel Core i7 2600K (testing)
16GB Mushkin Redline 17000 2133 1.65v
EK, 3x120 Rad 2xMCP655
Acer 1200w PSU
2-128GB Samsung SSD RAID 0
2-1TB Seagete 32mb RAID 0
1-1TB Western Digital
1- Plextor PX-B320SA Blue Ray
1- Plextor PX-880SA 24x DVD/RW
2- EVGA Nvidia GTX-480 SLI
LG 30", Hanns G 28"
Alright thanks Im glad I asked. My CPU PLL was at 1.8v, its probably been like that all day and thats something I would have overlooked for a long time had it not been for easytune. Now its at 1.35 and MCH is at 1.4
I havent heard any high pitch sounds yet. I primed for probably about 4 hours total today and everything is quiet, thank god. Sorry about your boards, I hope mine doesnt follow.
e8600 w/ Tuniq Tower
Gigabyte UD3P
2x2GB G.Skill DDR2-1000
Visiontek 4870
OCZ 600W PSU
yep mobo and cpu
the good thing is about RMA ,next Friday a new EP45-UD3P from Gigabyte will be here
i think is Thomas ,but not the 3rd ,he is the firstI was opening a new tab to newegg after reading first half of thread. I've since closed it without ordering. i'll wait for a few. Sorry for your loss guys. Who had the 3rd e8600 die? PcCI2 (1) , dinos (2) and ?. My EVGA 680i's all had that high pitched noise while stressing. Annoying!!
Mojo
Family
Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
Criminal
Biostar Tpower X58A - 920~Gulf - G.SKILL2000CL8 - GTX580 - Intel 520 120GB - Antec HCP 1200w
Biostar TP67XE/TZ77XE4 2500k~3770K - G.SKILL 2800 - GTX480 - OCZ Vertex2 50GB - Corsair AX1200
Biostar Tpower X79 i7 3820 ~ E5 2680 - G.SKILL 2400C11 - GTX560Ti - Intel 520 120GB - AX1200i
Kids
P4GD1 - Pentium M 780 - XMS Xpert400 - GTX460 - Raptor 36GB - Aopen 560w
Mojo
Family
Criminal
Kids
how is vdroop?
If it's the same as the EP45 and EP45T Extreme boards,
manually changing the
DRAM Voltage will scale the following values if left to auto
MCH/DRAM Reference
DRAM Termination
Channel A Reference
Channel B Reference
I manually set all these to ~ 1/2 DRAM Voltage for high frequencies
and manually changing the
CPU Termination (aka vTT) will scale the following values if left to auto
CPU Reference
MCH Reference*
Again if it's like the EP45 Extreme boards, some values entered in the bios will not be what is reported in ET6.
Looky here
for a 45nm cpu, watch theses voltages
CPU Vcore ..........max ~ 1.45V (depending on ambient room temp!!!)
CPU Termination .....max ~ 1.40-1.50V
CPU PLL .............max ~ 1.60-1.70V
the above max suggestions are only a guide, some have been running higher vTT and PLL for months with no problems... so far
* I found scaling back the MCH Reference volts after increasing vTT seems to have helped me find stability when overclocking.
[SIGPIC][/SIGPIC] CoolerMaster Stacker 830SE|Antec Signature 850W|Gigabyte X58A-UD5 F5 slic2.1
Intel Core i7 930 16x200@3,200Mhz|vcore 1.14|Intel Stock CPU Cooler
GSKILL DDR3 Perfect Storm 2000 @6-6-6-16-1T 1600Mhz|ATI 5870 1024MB 850/1200
Windows 7 Ultimate x64 bootdisk: Crucial RealSSD-C300 128GB SATA-III
Excellent answer and very informative .
Mojo
Family
Criminal
Kids
SanAce 9SG1212G101 (F12-HHH) 120x120x38mm 6000rpm @ 260CFM + Gigabyte G-Power II Pro
room temp 24c
max clock at 4900MHz
fsb @ 650MHz
and pi @ 4750MHz
hmmm 650,fsb not bad at all but i dont like the max clock
my dead e8600 (Q820A599) was better (TRUE + SanAce 102CFM room temp - 25c)
Asus P5E3 Premium - 4980MHz for Pi
Gigabyte EP45T Extreme 4900MHz for 3d
Mojo
Family
Criminal
Kids
like to see the 1m pi on that 4.9, if u did a 9.1s w/4.5
nice to see someone else pumpin 1.5v can quad handle more less voltage then a duo,
or is it samesame
HWbot - Team: XtremeSystems
XS cruncher - Team: XtremeSystems
OCN Feedback
HEAT
*** Being kind is sometimes better then being right.
Mojo
Family
Criminal
Kids
more vcore and LN2 soon ^^
Mojo
Family
Criminal
Kids
OCN Feedback
HEAT
very nice man
i can ran a qx9770 at 4ghz with the same vcore but its not fully stable
but i have a great Q9550 E0
3870MHz @ 1.22v and 4GHz @ 1.288v (only for benching)
4GHz @ 1,22v
http://valid.x86-secret.com/show_oc.php?id=425560
Mojo
Family
Criminal
Kids
Whats the difference between F4 and F4-4, or even F5A??? im using F5A, any advice, thanks.
F4-4 is made to be fast in superpi 1m (probabaly only 1M, slower for all other tests). I think it lacks the E0 support to be fast in 1M (same with Maximus bios for exmple when penryn came out).
Looking forward to your LN2 results CI2iminal mate
MB- Gigabyte EP45-UD3P - F4-4
CPU- E8600
POT- Chilly1 LN2 conteiner
RAM- Team Group 1066
VGA- Force3d HD4670
PSU- Giga-EZ 1000w
HD- Hitachi 40gb 7200
SO- Win XP Pro SP2
Room temp- 25c
robust graphics booster - auto
cpu clock ratio 6x(fsb) 10x(clock and Pi)
cpu host clock control - enable
cpu host frequency - 630(fsb) - 570(clock and Pi)
pci express frequency 101
C.I.A.2 - disable
advanced clock control - default
performance enhance - standard(fsb) - turbo(clock and pi)
(G)MCH frequency latch - auto
system memory multiplier (spd) - 2.00B
latency - Cas5 5-5-12
load-line calibration - enable
cpu vcore - 1.3v(fsb) - 1.82v(1.87 real , clock and Pi)
cpu termination - 1.6v
cpu pll - 1.6v-1.81v
cpu reference - auto
MCH core - 1.4v-1.6v
MCH reference - auto
ICH I/O - auto
ICH Core - auto
Dram voltage - 2.5v
Dram termination - auto
channel a reference - auto
channel b reference - auto
Mojo
Family
Criminal
Kids
nice
shame your CPU is a lot worse than your previous one
Mojo
Family
Criminal
Kids
