XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
View Poll Results: Is your 45nm degrading?
Yes it has 38 16.03%
Not one bit 120 50.63%
I run my 45nm @ stock settings 10 4.22%
I have a 65nm 69 29.11%
Voters: 237. You may not vote on this poll
Reply
Old 10-18-2008, 11:13 PM   #1
Glow9
Glow9's Avatar
So read a few things on the 45nm chips degradation going on so I'm curious over all if it's as bad as some people are making it out to be. Clearly on this forum people push their chips so I figure this would be a good place to find out.
Glow9 is offline   Reply With Quote
Old 10-19-2008, 12:11 AM   #2
Brahmzy
Brahmzy's Avatar
I've got 2 high-end boxes at home here. One's got an E8400 at 4.0GHz - it degraded quite a bit very quickly but then quickly stopped, I'm still able to maintain 4.0 with very acceptable volts.
My main box has had an E8600 at 4.4GHz the day they came out. Not one hint of degradation at all in months. Possibly because of the E0 stepping?
So, yes and no.
__________________
i7 920 (4.0GHz @ 1.375V) HT ON | ASUS P6T WS Pro | OCZ 6GB 1600/C7 | TRUE Black | Antec 1200 | Corsair HX1000W | SB X-Fi Ti FP
2 eVGA GTX285's SLi | 2 OCZ Vertex 120GB R0 | WD6400AAKS | Samsung DVD-RW | Samsung 305T | G15 | G9 | W7RTM x64 Ultimate
E8600 (4.4GHz @ 1.325V) | ASUS P5Q-E | G.Skill 4GB PC2-8000 | TRUE | Antec SOLO | Corsair HX620W | SB X-Fi
eVGA 9500GT | OCZ Vertex 60GB | WD6400AAKS | Samsung DVD-RW | Samsung 245BW & 204B | G15 | G9 | W7RTM x64 Pro
Brahmzy is offline   Reply With Quote
Old 10-19-2008, 12:46 AM   #3
Leeghoofd
I am Xtreme
Leeghoofd's Avatar
Like mentioned in the other thread I smoked my first Qx due to inadequate knowledge of the mobo and CPU at that time... pushing 65nm volts through it for a whole weekend during an SLI benching session made it degrade quite a bit... yet the CPU still runs strong at 4ghz with +/-1.35volts...Before it needed around 1.32 for prime stability at 4ghz... My error totally (one of the reasons I have a DMM now lol)
All the other CPU's stayed stable after the burn in period...some even got better ( better voltage regulation on the P5Q dlx )
One E8500@Ghz at 1.25volts, one E8400@4ghz 1.21volts, QX9650@4ghz at 1.26volts and the E8600@4.5Ghz at 1.36volts... Wolfies all at 500FSB, Qx at 450FSB. All are on air just the Qx is on water... E8600 is pretty new so maybe too early to judge... other CPU's are over 7 months , with the Qx being the oldest...
__________________
Question : Why do some overclockers switch into d*ckmode when money is involved
Leeghoofd is offline   Reply With Quote
Old 10-19-2008, 12:49 AM   #4
cabbspapp
cabbspapp's Avatar
Send a message via AIM to cabbspapp
I have a Xeon E3110 sitting at 4005 Mhz with 1.328 Vcore and it's been just fine, 10 hour prime stable after ~4-5 months. That's not a lot of voltage though.
cabbspapp is offline   Reply With Quote
Old 10-19-2008, 12:54 AM   #5
{GOD}Raptor22
{GOD}Raptor22's Avatar
Send a message via AIM to {GOD}Raptor22 Send a message via MSN to {GOD}Raptor22 Send a message via Yahoo to {GOD}Raptor22
Wheres the option for 90nm (PD820)...
__________________
|-------Conner-------|
RIP JimmyMoonDog
My F@H Statistics:
http://fah-web.stanford.edu/cgi-bin/...e=Conman%5F530
{GOD}Raptor22 is offline   Reply With Quote
Old 10-19-2008, 02:31 AM   #6
CryptiK
CryptiK's Avatar
My e8400 degraded rapidly over about 4 weeks, at first needing only 1.304v for 4GHz stable, then it became unstable and needed 1.32v, was ok for a week or so then became unstable and needed 1.328v, was ok for another week then became unstable and now requires 1.336v. Seems to have not degraded any more but it might, no way to tell with these flakey 45nm cpu's.
CryptiK is offline   Reply With Quote
Old 10-19-2008, 02:38 AM   #7
oli_ramsay
oli_ramsay's Avatar
My e8400 requires 1.465V for 4GHz and it's not even orthos stable at that. It's stable for everyting else I use it for though (gaming, music, internet etc). I'm hoping to get an e0 stepping of it when the prices fall after Nehalem launch.
But it hasn't degraded at all.
__________________
E8400 @ 4GHz (500x8)
MSI P35 Neo2 FR
4GB Patriot PC6400 (5-5-5-15 @ 1000MHz)
Sapphire 4870 (w/ AC Accelero S1)
Corsair HX620W (Sleeved UV Green)
1.1TB of storage (Raptor, 7200.10, F1)
oli_ramsay is offline   Reply With Quote
Old 10-19-2008, 02:38 AM   #8
carepolice
carepolice's Avatar
Sounds pretty sad, I bet that you was even in safe limits of all voltages
__________________
Asus P5Q-E @ 1306 Ket's handwork
Intel® Core™2 Quad 9550 3600Mhz -1.28v load- FPO: 816xxxxx
Xigmatek HD1283 -> 30-33 IDLE / GAMING 45*C
Sapphire 4870 512MB If you want feel like in aeroplane, turn fan to 100% that is what i call xtreme
A-Data 2X2GB 850mhz 1:1 damn budget
Corsair HX520W Small but powerfull
Antec 300
Noctuas casefans <3 Silence
WD 640GB
Eizo Flexscan S2201W 22''
3DMARK 06 (+17000)
Vantage (+10000)
Best SuperPI time @ 3.6Ghz
carepolice is offline   Reply With Quote
Old 10-19-2008, 02:53 AM   #9
CryptiK
CryptiK's Avatar
Yep, vcore as stated above and I never went over 1.336v, vFSB 1.11v, vPLL 1.50v. I never abused it, stayed well within spec on all voltages, and degradation still occurred.
Old 10-19-2008, 07:26 AM   #10
rge
I am Xtreme
rge's Avatar
E8400 was 15hrs prime stable 4.2ghz with 1.36v bios loadline enabled (1.36cpuz), ran it 4 months that way, and was still 15hrs prime stable after that and some benching at 1.5V.
Then ran it at 1.425 bios, loadline off, 1.4v cpuz 4.3ghz. Initially prime 15hrs stable, then after 4 months of normal usage, started getting random crashes, esp. in games, never crashed once before...rechecked and stopped prime in 2-3 seconds repeatedly.
Originally needed 1.3V bios for 4hz, now running at 1.36v bios (1.33cpuz) for 4hz. But no further degradation since.
__________________
i950 4.5 Ghz prime stable - Windows 7 64 - GB X58Ex - OCZ Plat 6gb - PCP&C 910 - Intel X25m SSD - 295 GTX - 26 inch Samsung LCD
Lian Li G70 WC - 3dmark 6 30K - i950 5.13 Ghz water - 8.16 spi1M @ 5ghz - 4.92 sp32m
rge is offline   Reply With Quote
Old 10-19-2008, 08:11 AM   #11
Monkey101
Monkey101's Avatar
LOL i like the ammount of people who have their 45nm CPU at stock speeds :P
__________________
Intel Q6600, 400x9 @ 1.5v, TRUE Black
DFI Lanparty X48
OCZ SLI Ready 2 x 2gb DDR-800
Force 3D 4870X2
Antec 1200
G15 Rev.1 + Razer Lachesis
Samsung 245T 24"
Sennheiser HD 485
Logitech Z5500 5.1
Monkey101 is offline   Reply With Quote
Old 10-19-2008, 08:18 AM   #12
Ozzfest05
Ozzfest05's Avatar
Well have my E8500 at 3.8 for 24/7 nothing special, had it up to 5ghz on air at really high volts C0 stepping but havent noticed degradation its a decent chip
__________________
Case: CM HAF
PSU: Corsair HX1000W
mobo: Rampage Extreme!
CPU:E8600 @ 4.4ghz 1.23 volts (Batch Q820aA405)
RAM: G Skill 1600 mhz DDR3 @ 7-7-7-18-1T stock OC'ed to 1960 mhz 8-8-8-26-1T
Graphics:4870x2
Cooling:H20 Apogee Gtz+Black Ice Tripple Rad
OS: XP 32
Bench Rig
Case: Antec 1200
Mobo: DFI LP DK P45 T2rs+
Ram: OCZ 800 mhz @1100+
CPU:E8500
PSU: Ultra 700w
CPU Cooling: Single Stage
Video Card: 9800gtx
Ozzfest05 is offline   Reply With Quote
Old 10-19-2008, 09:06 AM   #13
BenchZowner
One-Eyed Killing Machine
BenchZowner's Avatar
Send a message via ICQ to BenchZowner Send a message via AIM to BenchZowner Send a message via MSN to BenchZowner Send a message via Skype™ to BenchZowner
Degradation ?
What's that ?
None of my CPUs is showing any signs of degradation yet.
But then again, I'm not pushing high voltages through them ( I always stop at 1.9V on air / water cooling )
__________________
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Oliver Baltuch, Steffen Eisentein
ASUS CAN LICK MY COJONES
BenchZowner is online now   Reply With Quote
Old 10-19-2008, 09:47 AM   #14
eaa315
Send a message via AIM to eaa315 Send a message via Yahoo to eaa315
E3110 @ 4.0gigs w/ 1.32 volts for about 6 months now with no issues.
__________________
Abit IP35 Pro | Xeon E3110 @ 4Gigs
8Gigs Mushkin DDR2
150Gig Raptor | 500Gig Samsung
X1900XT 512
ASUS P5WDG2 WS Pro | E6600 @ 3.6gigs
6Gigs Mushkin XP DDR2 800 | 2x150 Gig Raptors RAID0
Sapphire HD2900Pro 1Gig | Mushkin XP-650 Enhanced PSU
Lian Li V2000 Case & Custom W/C Set-up
eaa315 is offline   Reply With Quote
Old 10-19-2008, 03:11 PM   #15
rge
I am Xtreme
rge's Avatar
Actually looking at my old orthos 10-64ffts stable pic from several months ago (left pic) then running all exact same settings (right pic), nearly the same stability...not counting the first two attempts at orthos as it rebooted.
__________________
Old 10-19-2008, 03:33 PM   #16
Glow9
Glow9's Avatar
If people are telling the truth it's kinda scary 1/3 of chips are degrading. Honestly I thought it was gonna be like 4 in 30
Old 10-19-2008, 04:01 PM   #17
rge
I am Xtreme
rge's Avatar
Mine degraded only when abusing it. If I actually cared about my chip, I could have prevented it.
Benching 1.65 for an hour and running 1.36v cpuz for months with loadline enabled, did not degrade even one notch.
Running 1.425v for 4 months degraded first time, then benching few hours this am trying/failing to get 5ghz. 4.9 easy with 1.7V, but 5ghz is no go, ram/mem had much more room but cpu cant do it on water with 10C outside air. Interestingly after few hours it would not do 4.9 anymore even with 1.8V.....waiting for i7 results before deciding on e8600 vs q9650 vs i7, so this chip is going to be relegated for backup use soon anyways.
__________________
Old 10-19-2008, 05:14 PM   #18
truehighroller
Originally Posted by CandymanCan View Post
Yea mine has but im not sure if its degradation or a burn in period or because i used diff voltages at the time of testing. Because at first my cpu was able to run 4200mhz with 1.288v and now it requires 1.296v but it hasnt gone down since and its running fine. 4300mhz required only 1.338v and now it needs 1.36v.
It also might be due that i was running the VFSB Termination when i first tested the cpu at 1.20v and when i relised that was kinda high i lowerd it down to 1.10v so now the cpu needs more vcore. Im not sure if this is degradation or due to fact that i simply lowerd 1 of the voltages causing it to need more voltage on something else to continue running stable. I dont really care tho my 24/7 speeds are 4200mhz because the voltage is all default or extremely low and 4200mhz is perfectly fine for me i dont need that extra 300mhz for 24/7 usage and i dont benchmark anymore so i see no point.
I guess the only way to tell is to raise my VTT back to 1.20v and lower the vcore back to 1.288v and see if it will pass 4200mhz if not then i guess i do have degradation. If it does pass then it was just because the VTT voltage was to low for that vcore.
Benchzowner: I havent fully read through your thread where you took bets on if the cpu would die or not, but the parts i did read i dont think i saw a single screen shot or video or anything from you proving that your cpu or cpu's havent failed or degraded all i see is writing and frankly its rather hard for me to belive that your putting 1.9v through a 45nm cpu and its running fine 24/7 without any proof
You can safely push it to 1.25v. Some one put out an intel thing that showed it some where on this thread. I think the gtl reference thread actually..
__________________
_____________________________________________
Rig = GA-UD3P Rev 1.6 - Q9550 E0 @ 4.2~Ghz 1.37v~, 1.34v Under Load - Swiftech Water Cooling - 2x2Gb OCZ DDR2 1150Mhz @ 1188MHz 5,5,5,18 @ 2.0v -XTX 5870 @ 1GHz / 1200 - 3x Western Digital RE3 320Gb 16Mb Cache SataII Drives in Raid0 - Corsair HX 850w Power Supply - Antec 1200 Case - 3dmark Vantage Score = 19049 3DMark06 Score = 23393
truehighroller is offline   Reply With Quote
Old 10-19-2008, 05:42 PM   #19
rge
I am Xtreme
rge's Avatar
Originally Posted by BenchZowner View Post
Degradation ?
What's that ?
My E8400 degraded .03v in a few hours at 1.8V vcore on water in 10C outside air.
Can you post pics of cpuz/stress testing from different time points to show it has not degraded at that high vcore, etc
__________________
Old 10-19-2008, 06:01 PM   #20
AVWar
AVWar's Avatar
just killed E8500 waiting for E8600
__________________
AVWar is offline   Reply With Quote
Old 10-19-2008, 07:33 PM   #21
nugzo
Ultra Durable
nugzo's Avatar
Send a message via MSN to nugzo
Degradation ?
What's that ?
I'll answer for him... If you aren't familiar with his thread, the sarcasm may not have been detected. http://www.xtremesystems.org/forums/...d.php?t=198614
__________________
Under Construction. EX58a-UD7 in route. Currently Running:
EVGA X58 Classified 759 (3-way x16 SLI +physX)
Intel Core i7-950 Bloomfield @ 4.2Ghz (24x175)
G.SKILL Perfect Storm 12GB (6 x 2GB) 1745 8-8-8-21
Cooler Master Storm Sniper
Thermaltake 1000w PSU
2-128GB gskill Titan SSD RAID 0
2-1TB Seagete 32mb RAID 0
1-1TB Western Digital
1- Plextor PX-B320SA Blue Ray
1- Plextor PX-880SA 24x DVD/RW
2- EVGA Nvidia GTX-295 Quad SLI
TRUE w/2-SCYTHE S-FLEX™ "SFF21G" 120mm Fans
Acer 27" B273HU LCD / ASUS 24" LCDe
nugzo is offline   Reply With Quote
Old 10-19-2008, 07:52 PM   #22
nugzo
Ultra Durable
nugzo's Avatar
Wink
I havent checked through the entire thread but from the first 4 pages i see no proof at all no proof and there is no way im beliving it, i mean everyone seems to praise this guy just for his word. He hasnt posted 1 screen shot even showing the voltage from cpu-z let alone a single prime95 or burntest....
BZ has a good rep around here as far as i know. We've both been around for quite a while and i cant recall anything negative. Plenty of useful threads and posts by BZ. My VTT is at 1.4 b/c of his thread. All is good although its still early. Screenshots dont realy prove anything pertaining to that thread. If he wanted to be deceptive, then falsifying SS wouldn't be a problem. Believe Candyman Believe!!!!! i believe!
__________________
Old 10-19-2008, 08:45 PM   #23
Glow9
Glow9's Avatar
What you do?
Old 10-19-2008, 08:54 PM   #24
Fungus
I run my E8500 at 3.8ghz 24/7 for a few months now and I have had no degradation.
__________________
- ASUS P5E (BIOS 0903) 400 FSB - Intel E8500@3.8GHZ (1.28750 VCORE) - Thermalright HR120 Extreme - 4GB Corsair PC28500CS (1066 3:4) - 2*500GB Hitachi Deskstar -
- EVGA 9800GX2 (700/1025/1750) - Creative X-Fi Extreme Gamer - PCP&C 750W - Antec P-182SE - 4* Yate Loon 82CFM - 2*ASUS DRW-2014L1T - Logitech G11+G5 - Samsung 245T -
Fungus is offline   Reply With Quote
Old 10-20-2008, 02:43 AM   #25
BenchZowner
Relax... if you really want it that much, I'll give you some.
You just have to wait a bit... unless you're willing to write those 14 hardware reviews that I have to get done ASAP.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
