XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Thread Tools Rating: Thread Rating: 58 votes, 4.57 average. Display Modes
Old 10-28-2008, 12:45 AM   #76
ezaleina
ezaleina's Avatar
Originally Posted by BuGjAE View Post
Nice !! Well,Do you plan to get higher that speed ? For my E8600 I need above 1.60 VTT boot up to window in FSB 500+, I'm not sure for for around FSB 450. I'll try soon.
But for over 4.33 GHZ I can't get any stable at all.
no.,i think not nice bro.,because the VTT quite high i think.,i heard they say better not use VTT over 1.35..now 1.42 already..
__________________
Core i7 860 4.0Ghz 1.36v > Asus Maximus III Formula > GSkill F3- 176000CL7D-4GBPIS > Intel X25-M 80GB SSD > Samsung Spinpoint 1TB F3 > Sapphire HD5850 1GB DDR5 > Silverstone TJ-07 > Corsair HX620 PSU > Dell S2409W > Windows 7 Ultimate x64 > EK Supreme LT > EK FC- 5850 > EK FB Maximus III Formula > Laing DDC 3.2 + EK X-Top V2 > TFC XChanger 480 Rad > EK Multioptions 250 Res > Feser UV Blue Tubing > Bitspower Fittings
ezaleina is offline   Reply With Quote
Old 10-28-2008, 12:54 AM   #77
BuGjAE
BuGjAE's Avatar
Sure may be not Nice for you. but I don't know why this board need very much VTT to boot up compare with my old mobo maximus II formula.(for my E8600)and I need at least 1.60 to get on Window, but for you 1.42 is OK for me.
__________________
____________________________
E8600 Q820A346
EP45-UD3R Rev.1.1 l EP45-UD3P Rev.1.0 F4 BIOS(Waiting for C2Q)
Crucial Ballistix 4GB 2x2GB(5-4-5-14) @1.8 V
WINFAST 9800GTX @800core/1220mem
Coolermaster Centurion 5 CAC-T05
ENERMAX 460 WATT
BuGjAE is offline   Reply With Quote
Old 10-28-2008, 01:00 AM   #78
ezaleina
ezaleina's Avatar
yes bro.,me also think why dis board need very much VTT.,but i also they can get below 1.30.,maybe we not have a good luck..
__________________
Old 10-28-2008, 02:15 PM   #79
zodden
I have been tweaking for about 7 days now. It has been a to get Prime/Orthos stable at higher FSB with acceptable (for me) voltages but I finally accomplished it. I was able to do 20 runs of linpack, 2 hours of OCCT, super-pi runs and prime small ffts for an 18 hour run before I manually halted. Blend is what I had a problem with. I tried almost every combo I could.
Maybe this will help somebody else. When I lowered my MCH reference to .70 I finally got 24 hours of Orthos blend.
So here is my new 24/7 settings.
__________________
E8400 @ 4.2 Ghz (525x8)
Gigabyte EP45-UD3P
Corsair Dominator 4GB (2 x 2GB) PC2 8500 2.1V
PowerColor 4870x2
150GB Western Digital Raptor
500GB Western Digital 5000AAKS
Westinghouse LVM-37w3 1080p Monitor
Vista64
Cooling: CPU-OCZ Vendetta2+Scythe S-FLEX SFF21F 120mm, Silverstone TJ09 case with 4 120mm yate loons.
zodden is offline   Reply With Quote
Old 10-28-2008, 03:23 PM   #80
bellinghamwa
Hello zodden,
Can you please share your other BIOS settings? Especially the ones in BOLD below?
DRAM Performance Control
Performance Enhance...................: Standard
Extreme Memory Profile (X.M.P.)………….Disabled
(G)MCH Frequency Latch...............: ???Mhz
System Memory Multiplier ..............: ???
Memory Frequency (Mhz) ..............: ???Mhz
DRAM Timing Selectable ................: Manual
Motherboard Voltage Control
CPU Vcore….……….........................???V
CPU Termination…..... ???V
CPU PLL…………………....???V
CPU Referen.…………....???V
MCH/ICH
MCH Core…………….....???V
MCH Reference….…….???V
MCH/DRAM Ref.…......???V
ICH I/O……………….....???V
DRAM
DRAM Voltage ……....???V
DRAM Termination .…???V
Channel A Reference………..0.750V [Auto]
Channel B Reference………..0.750V [Auto]
Ch.A Address VRef………..0.750V [Auto]
Ch.B Address VRef………..0.750V [Auto]
bellinghamwa is offline   Reply With Quote
Old 10-28-2008, 03:35 PM   #81
zodden
Sure below are my bios settings. Mem is at 5-5-5-15 2T, PL9, stock sub timings except trfc at 60
Performance Enhance...................: Turbo
(G)MCH Frequency Latch...............: Auto
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ..............: 1050 Mhz
CPU Vcore….……….........................1.3750V
CPU Termination…..... 1.28V
CPU PLL…………………....1.57V
CPU Referen.…………....autoV
MCH/ICH
MCH Core…………….....1.38V
MCH Reference….…….0.750V
MCH/DRAM Ref.…......autoV
ICH I/O……………….....normalV
DRAM
DRAM Voltage ……....2.1V
DRAM Termination .…autoV
__________________
Gigabyte EP45-UD3P
PowerColor 4870x2
Vista64
Old 10-28-2008, 05:22 PM   #82
nugzo
Ultra Durable
nugzo's Avatar
Send a message via MSN to nugzo
I've had this board up and running an hour. I previously had 2-Striker 2 Formulas, 1-MSI P7N diamond, 1-EVGA 780 FTW,
2- Maximus 2 formulas and 1- Rampage Extreme.My goal was a Q9650 4500Mhz 500x9 on Air. None of the other boards could do it.
Closest stable was 490x9 with the MIIF. I've only had 1 BSOD with this board and it only took an hour for the beginnings of an oustanding OC session.
This is what i call FUN! I've booted into windows at 533X8 only to get my 1 and only BSOD after 10-15 seconds.
That was with no extra voltage over what i'm running now. I'll be checking for max FSB Next.
Thanks to napalm for some bios settings.
__________________
EVGA X58 Classified 759
Intel Core i7 w3520 Bloomfield @ 4.2Ghz (21x200)
G.SKILL Perfect Storm 12GB (6 x 2GB) 1600 8-8-8-21
Cooler Master Storm Sniper
Thermaltake 1000w PSU
2-128GB gskill Titan SSD RAID 0
2-1TB Seagete 32mb RAID 0
1-1TB Western Digital
1- Plextor PX-B320SA Blue Ray
1- Plextor PX-880SA 24x DVD/RW
2- EVGA Nvidia GTX-295 Quad SLI
TRUE w/2-SCYTHE S-FLEX™ "SFF21G" 120mm Fans
LG 30", Hanns G 28"
nugzo is offline   Reply With Quote
Old 10-28-2008, 06:26 PM   #83
radaja
cOmPuTeRsPoNgE
radaja's Avatar
thanks zodden for your settings. it really helped lower my volts and up my fsb.
__________________
____________________________________________
............ImAcOmPuTeRCRUNCHINGsPoNgE.............
®adaj@'s HEATWARE
radaja is offline   Reply With Quote
Old 10-28-2008, 07:16 PM   #84
ezaleina
ezaleina's Avatar
nice radaja.,this is my result.,no so impressive.,because cannot get 450fsb..need to pump vcore to 1.45v to get it..so this the last i can manage..
__________________
Old 10-28-2008, 08:33 PM   #85
derekd
I have a UD3R, and it seems like for most of the 120mm CPU fans on Newegg there is a review that says it didn't fit on this model because the on-board heatsinks got in the way.
Has anyone been able to put a 120mm non-stock fan on their CPU?
derekd is offline   Reply With Quote
Old 10-28-2008, 08:50 PM   #86
zodden
Glad I could help! Looking good
__________________
Gigabyte EP45-UD3P
PowerColor 4870x2
Vista64
Old 10-28-2008, 09:09 PM   #87
BuGjAE
BuGjAE's Avatar
Glad to you radaja & ezaleina, Thanks zodden for your info, I just notice that CPU VTT is relate to MCH reference (if you set MCH ref. to non auto)
And now I can boot up success to window at VTT 1.28 and MCH ref around 0.64 ( but show in ET6 0.90) .Still not test a stable yet. But this is
first time I can boot up to window with below 1.60 VTT, I'll post the test later.
__________________
E8600 Q820A346
ENERMAX 460 WATT
Old 10-28-2008, 11:02 PM   #88
ezaleina
ezaleina's Avatar
glad to u also bro Bugjae..can you upload your screen shot.,maybe we can share your setting if u don mind..
__________________
Old 10-29-2008, 03:16 AM   #89
radaja
cOmPuTeRsPoNgE
radaja's Avatar
i set what zodden did with the mch reference voltage to o.750 in bios and in et6 shows 0.700 and i was able to boot with vtt lower than 1.42
__________________
®adaj@'s HEATWARE
Old 10-29-2008, 04:28 AM   #90
golfjam
golfjam's Avatar
Man, there are so many threads about this mobo that it's hard to keep up!
__________________
Intel i7 920 @ 4Ghz - Asus P6T Deluxe - OCZ Gold 1600 3x2Gb @ 1690 - Sapphire HD 4890 (900/1100) - 2x Velociraptor 300Gb Raid0 - WD Green 1Tb - Seagate 7200.11 1.5Tb - DVD-RW DL (samsung/Pioneer) - Cooler Master 1000W - Cooler Master Stacker 830 SE - Microsoft Ergonomic Keyboard - Logitech MX Revolution - Vista 64 - Hanns-G 28"
golfjam is offline   Reply With Quote
Old 10-29-2008, 05:36 AM   #91
M-XXXX
Send a message via MSN to M-XXXX
http://img261.imageshack.us/my.php?i...apimagebq7.jpg
Can you se it now?
NEED HELP
__________________
i7 920, Evga X58 SLI, CF 4870/ 5870, 3x2GB Crucial
Water cooling, Single stage cooling, Bench table
Intel G2 SSD, WD 640Gb, G5, G15, NEC 2470 WVX, 970P...
M-XXXX is offline   Reply With Quote
Old 10-29-2008, 05:58 AM   #92
radaja
cOmPuTeRsPoNgE
radaja's Avatar
@zodden,on that 525fsb run you posted you were able to run pl9 with 1/1 ? i thought the lowest pl on the 1/1 divider above 450 fsb was pl10 on the P45 chip. the lowest i could do on my maxII at 467fsb @1/1 was pl10.
__________________
®adaj@'s HEATWARE
Old 10-29-2008, 07:41 AM   #93
CryptiK
CryptiK's Avatar
Hey nugzo, not bad at all, I notice you are using 1.6v on the MCH on the UD3P, just wondering if you tried up to 1.6 vNB on the M2F when trying for max stable FSB? What vNB were you using on the M2F for 490 FSB stable?
CryptiK is offline   Reply With Quote
Old 10-29-2008, 08:50 AM   #94
Dymblos
why gigabyte boards dont support G.skill and Crucial Ballistix DDR2 rams?
I have two set 2x2gb 8500 of g.skill and crucial. .and im planning buy a new board, but gigabyte dont support them ... anyway Asus support all ddr2 brand, maybe my next board will be Asus P5Q series
Dymblos is offline   Reply With Quote
Old 10-29-2008, 09:42 AM   #95
BuGjAE
BuGjAE's Avatar
Smile
He Guy I'm try @zodden BIOS setting and set 0.75 Mch Reference is working great!! here is my share BIOS setting
Extreme Memory Profile (X.M.P.)………….Disabled <----I don't have this in BIOS
Memory Frequency (Mhz) ..............: 1066 Mhz
Mem is at 5-5-5-15 2T and no change in sub timimg
CPU Vcore….……….........................1.43750V
CPU PLL…………………....1.50V
MCH/ICH
MCH Core…………….....1.32V
ICH I/O……………….....auto
DRAM
DRAM Voltage ……....1.8V
Channel A Reference………..[Auto]
Channel B Reference………..[Auto]
Ch.A Address VRef………..[Auto]
Ch.B Address VRef………..[Auto]
I try to run HyperPI ,Orthos ,Memtest at the same time like crazy to find where unstable may happen!
Notice that when pull up the CPU VTT the MCH REF 'll up also.
I doubt that why AUTO voltage setting for this board seem unstable even @stock speed (E8600 3.33 Mhz)
Anyway I found 1 error memtest in this setting.
__________________
E8600 Q820A346
ENERMAX 460 WATT
Old 10-29-2008, 10:54 AM   #96
zodden
As far as any hard-wired restrictions- maybe there is but it must not be at 9. Maybe the restriction starts at 8 since I couldn't even post but I don't know. From what I have read here though I think you can take it as low as your system lets you. For me 9 is as low as I was able to go. I didn't mess around with the pull ins and stuff from that bios page because frankly I don't understand it enough to mess with it.
Maybe CryptiK can answer your question as he knows more about this stuff then I do.
__________________
Gigabyte EP45-UD3P
PowerColor 4870x2
Vista64
Old 10-29-2008, 10:57 AM   #97
radaja
cOmPuTeRsPoNgE
radaja's Avatar
@bugjae, great job that looks awesome!
__________________
®adaj@'s HEATWARE
Old 10-29-2008, 11:19 AM   #98
zodden
Wow that's some awesome clocks! This is a special board.
__________________
Gigabyte EP45-UD3P
PowerColor 4870x2
Vista64
Old 10-29-2008, 01:18 PM   #99
dannyuk32
Well I just got a UD3R.
In comparison to my Asus P5Q-E that I had I'm disappointed with some things ... the fit isn't as good. The I\O panel fit \ connections is poor and getting my Nvidia 260 GTX to sit was difficult to say the least and it doesn't feel secure. .
dannyuk32 is offline   Reply With Quote
Old 10-29-2008, 02:58 PM   #100
Sparda
Sparda's Avatar
If anybody wonder about an aftermarket cooler for the mosfet. The old thermalright HR02-U//S that fit maximus and rampage formula and EK asus 3a backplate also fit this board.(Note that on thermalright website only the I/O mosfet fit)
Forced me to use it since I have some clearance problem with heatsink and the stock jigabyte cooler. The blue color look cool though. :P
__________________
Sparda is offline   Reply With Quote
Reply
Tags
best p45 motherboard, cpu, gigabyte, overclocking, p45, ud3
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
