Page 1 of 7 1234 ... LastLast
Results 1 to 25 of 156
Thread: Generic CPU Benchmark
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    Hey guys. I wrote a CPU benchmark that tests a battery of common math ops on a large dataset. It should be a good mix of both CPU and RAM stress. While this didn't start as a serious project, I figured some of you might like a new bench to play with. It does actually measure performance in a realistic manner despite the humor in its interface, so it isn't a bad benchmark to try out.
    The throughput is measured in KCUs per second. Higher numbers are better. This benchmark is multithreaded, and it will probably make your machine sluggish while it is running. It shouldn't take too long to complete--15 seconds is pretty common on modern hardware.
    Build 105: Locked to x86 since it runs faster on AMD64 systems. Also reports individual thread finish stats.
Name:	Generic CPU Bench - 2008-10-11 - 18.00.34 - Bench Only.png
    Attached Files Attached Files
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
    Feb 2007
    Kentucky
    Vista64:
Name:	Generic CPU Bench - 2008-10-11 - 19.22.45 - Bench Only.png
    Asus Maximus Formula (Rampage Conversion Bios 0403)
    Q6600 G0 stepping@4.05 Ghz
    8GB G. Skill 1066 @ 1081 Mhz
    EVGA 280 GTX
    Auzentech Prelude
    2X 74 GB WD Raptors in Raid 0 Windows 7 Ultimate 64
    2X 1 TB WD Caviar Blacks in Raid 0 Vista Ultimate x64
    Thermaltake Toughpower 1200W
    DTek Fuzion V2 in a custom CPU only water loop
    Coolermaster Stacker 830
    Hanns-G 28" widescreen
    Klipsh Pro-Media 2.1
    G15 Keyboard and G9 Laser Mouse
    Dec 2002
    AMD 1090T@4.0ghz
    Enzotech sapphire/Mo-Ra extreme rad
    Asus Crosshair IV Formula
    ht 2400mhz / nb 2400mhz
    12gb Gskill 1300mhz
    HIS HD5970
    Enermax Evo Galaxy 1250
    case: XCLIO A380PLUS-BK
    4.61ghz water
    4.5ghz superpi 1M 15.585
    http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
    25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
    21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
    Phenom 2 125w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=117414
    Phenom 2 140w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=109214
    Phenom 2 AM2+ 940 cold air results
    http://futuremark.yougamers.com/foru...ad.php?t=97430
    If I dont get every single drop out of my cpu I feel like someone is stealing from me
    Jan 2008
    Lubbock, Texas
    phenom 9600
    corsair dominator 1066 @ 5-5-5-24-30
    m3a32-mvp
    nothing is overclocked
Name:	Generic CPU Bench - 2008-10-11 - 16.56.59 - Bench Only.png
    Xtreme Mentor
    Dec 2007
    State of Confusion, USA
    Well.... I just had to be the 1st one to break 31,000 KCU's
    CLICKABLE:
    AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
    Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
    First Computer: Commodore Vic 20 (circa 1981).
    Apr 2008
    Kansas
    Good work, dave. I think that's the record so far.
    Rule 1A:
    Rule 2:
    Rule 2A:
    Rule 3:
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    Cpu @ 4.3ghz
    Click image for larger version.
    L-l-look at you, hacker.
    Jun 2007
    Perth, Western Australia
    31.1k
    Test seems to love low latency - about 3k boost going from CAS-7 to CAS-6 at same speed.
Name:	Generic CPU Bench - 2008-10-12 - 12.23.58 - Bench Only.png
    Rig specs
    CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
    Foundational Falsehoods of Creationism
    Feb 2007
    Kentucky
    Quote Originally Posted by SoulsCollective View Post
    31.1k
    I tried a lot of things just now in windows upping and lowering speed of the processor made less than 1k of difference. I agree with the above that memory latencies will make a big difference though.
    EVGA 280 GTX
    Auzentech Prelude
    Apr 2008
    Phenom 9850BE @ 3.107 ghz
    Nov 2006
    A great place again
    Throughput score should be measured from a single core if it's only multiplied by the number of cores.
    On the rise!
    Sep 2005
    This is my bench, its on a C2D lappy - T7600@ stock 2.33Ghz - 10,829 KCU's. LOL
    Something I noticed is that the test doesnt seem to be touching the CPU. It didnt make it jump 1% even. I think it is more memory oriented.
    Xtreme Mentor
    Dec 2007
    31.1k
    It does seem to be pretty memory sensitive, but thats not a bad thing...
    In fact, it probably makes it a better test for real world performance.
    I started by tweaking timings first which showed slight improvements, but to actually break the 31k barrier I had to up the Mem Frequency... (I seriously doubt it was 24/7 stable, but it was stable enough... )
    Geez SoulsCollective, I was hoping to hold the record a little longer than 1/2 an hour....
    Nov 2006
    A great place again
    Quote Originally Posted by m411b View Post
    Cpu is at 100% for the time it runs. Each block=5 seconds.
    Jan 2008
    Lubbock, Texas
    i usually use my logitech g15 to check my cpu load and for every benchmark i have ever ran it works and shows the load. for this one it pauses and w/e load it was on it stays at that. like i have ran the test with it saying 0% load just because this program eats up so much bandwidth.
    Aug 2006
    Oklahoma
    _______________
    Q66@3.8ghz
    Rampage/Maximus SE hybrid W/C. 4 gigs OCZ reapers.
    4890,s CF Dual loop rocketfish case.
    ^^^^^All shaken, (from the earthquake) not stirred^^^^^
    Quote Originally Posted by Vapor View Post
    There's a lot less voodoo in watercooling than is assumed
    The only thing future proof in electronics, is the electricity itself.
    Any one who relies on only one source of information is a fool.
    On the rise!
    Sep 2005
    Quote Originally Posted by dengyong View Post
    Quote Originally Posted by roofsniper View Post
    Yeah I see that now, didnt think of opening task manager.
    Was using Everest OSD..
  18. #18
    Jun 2007
    Quote Originally Posted by sirheck View Post
    Nice result. Mind posting up your system settings? Sig is a little short on detail.
    Rig specs
  19. #19
    Aug 2006
    Oklahoma
    I dont really understand the benchmark.
    But here are my settings from CPU-Z and Realtemp.
    _______________
    Q66@3.8ghz
  20. #20
    Nov 2006
    A great place again
    If you hold the Alt key when you hit PrtScn (print screen) you'll only capture the active window and won't have to crop your image.
  21. #21
    Aug 2006
    Oklahoma
    Yeah im lucky just to be able to post a pic
    I always use (snag-it) for this type of shistuff.
    _______________
    Q66@3.8ghz
  22. #22
    Jun 2007
    *pic snip*
    What PL setting and strap?
    Rig specs
  23. #23
    Aug 2006
    Oklahoma
    IIRC everything in my rampage bios is stock.
    The volts for the cpu are up a little.
    But things like trans booster,gtl ref and all that are (auto)
    I had to manually set certain things on my old maximus SE
    to keep the Q66 folding stable at 3.6 but almost everything
    in BIOS on this rampage is stock/auto.
    Sorry im old and its been a while since i set it all.
    Could post a pic of BIOS if you like.
    Probably better to PM so not to jack this thread to much.
    _______________
    Q66@3.8ghz
  24. #24
    Nov 2006
    A great place again
    I use paint with the shortcut on quick launch. Saving as jpeg keeps the file size small enough to not need an image host.
  25. #25
    Jun 2007
    Hmm, ok. It's not thread-jacking, we're trying to work out what makes this bench tick, and thus why your score is better than anything else posted so far.
    Rig specs
