Available in 30GB, 60GB, 120GB, 250GB capacities*
Read: up to 170 MB/sec**
Write: up to 98 MB/sec**
Slim 2.5" Design
100.2 x 70 x 9.3mm
Lightweight 77g
Operating Temp: -10C ~ +70C
Storage Temp: -55C ~ +140C
Low Power Consumption
Shock Resistant 1500G
RAID Support
Mini USB 2.0 Port
MTBF 1.5 million hours
2 year warranty
And props to OCZ as well for taking a step in the right direction as far as naming convention - the 30gb drive has 30gb available formatted - now if only the rest of the hdd manufacturers would follow suite...
*Consumers may see a discrepancy between reported capacity and actual capacity; the storage industry standard is to display capacity in decimal. However, the operating system usually calculates capacity in binary format, causing traditional HDD and SSD to show a lower capacity in Windows. In the case of SSDs, some of the capacity is reserved for formatting and redundancy for wear leveling. These reserved areas on an SSD may occupy up to 5% of the drives storage capacity. On the Core V2 Series the new naming convention reflects this and the 30 is equivalent to 32GB, the 60 is equivalent to the 64GB and so on.
OCZ really found the sweet spot. cheap SSD's!!! it's hard enough to find the original core series in stock any ware. now that they know that they can not make enough to satisfy demand why not make them better as well! i would buy a few if i can find them in stock any ware.
__________________
Does your pc just idle when at work surfing the web or any time you aren't gaming? Give it a purpose and crunch for the XS WCG team. Meet great people and kick cancer and aids right where it hurts!!!!! We have everything to gain and nothing to loose!!!!!
Rig1:
-Intel Core 2 Quad Q6600 2.4Ghz@3.8ghz under a TRUE
-Asus P5Q Deluxe
-4GB G. Skill DDR2 800mhz @1014mhz
-Sapphire ATI 5870 1GB @900/1265
-Creative XFI Titanium
-Logitech G15 (old) and G5
-Antec 900 and OCZ GameXStream 700watt
-2X Kingston SSD Now 40GB in RAID 0
-Western Digital Caviar SE16 500GB 7,200rpm
-Windows 7 Ultimate 64Bit
Glad to see OCZ giving the middle finger to the other makers. Maybe it will get the other developers off their asses and start inveesting more time into SSD.
__________________ PC Lab Qmicra V2 Case SFF
i7 950 4.4GHz 200 x 22 1.36 volts
Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c See my Thread here!
GTX 470 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II | Xigmatek Northbridge cooler mounted to the stock system.
OCZ Vertex RAID-0(60Gig x 2) | WD 1000Gig Storage
Enermax Liberty 620
Originally Posted by bhavv
But Apple are hack proof, virus proof, fail proof, and only consist of epic win.
I gotta say OCZ really is kicking it into gear recently. Its also nice to see them not giving to much premature info on their hit products for a change. Actions speak louder then words in the case of OCZ. Big thumbs up to what OCZ is doing in the SSD arena
I really want to get my hand in SSDs, but its something that will certainly drop like a rock at some point, I may try out a 60GB for my OS if its cheap enough though
__________________
i5-750 w/ Thermalright Ultra120X
Coolermaster HAF-932
MSI GD65
2x2GB G.skill Cas7 1600MHz
Zotac GTX260-216
Western Digital 640GB.AAKS
2x Samsung F1 1TB
2x Samsung SLC 64GB SSD
Pioneer DVR-212BK
Corsair HX620W
Creative X-Fi Xtreme Music
Samsung SyncMaster 713BM (DVI)
The plan is to make Core more affordable and Core2 just a little above it. SSD tech is moving at a furious pace, much faster than i have seen anything move for quite a while. The push to make the drives faster is a weekly thing, it really is quite scary at the moment.
Drives arrive with OCZ early next week I hear, in stores immediately after.
USB is for firmware upgrade only ( i will recheck) and the drives are sata
__________________
Got a problem with your OCZ product....? Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
Wait, what about the bad random write performance of the first series? Is it been fixed in this series? And even if it is not, there might be the possibility to do that later with the built in usb connection to flash a new firmware into the SSD. Aight.
Scary in the computer world is a good thing =-)
Enermax Liberty 620
it has to be mlc to be affordable so i think that stays
if u can get data over usb, ever read only that would be a great help
__________________
p2 1090t, gd70, g.skill 2x2GB ddr3 1600mhz HZ w/ GTS
2x samsung 500gb(raid 0), ocz agility 120GB, SBA2 plat pro antec p180B corsair 750tx
beyerdynamic DT 770 PRO 80ohms headphones (they are like wall hacks for your ears)
SSD is not HDD, plus when you factor in the massive improved seek times with SSD it can actually work out faster. There is nothing wrong with the first series, its just SSD is new, and we are all getting used to it. A very small amount of people have had issues but this is no different then end users having issues with some HDD on some boards.
Its early days, improvements in hardware and software will come moving forward, you will see this from all SSD suppliers.
Regards firmware flash im still looking into that, i feel there may be a way without USB...we have to wait and see
__________________
Tony AKA BigToe
A very small amount is maybe too little. I heard about quite a deal of users complaining about the random write speed. All this, though, is mostly due to the combination of the OCZ Core SSD with an Intel ICHR9 chip or something like that. But since most users have an Intel based system, I don't think it's just a small minority that has problems with it. I don't have hard numbers to back that up though.
Please don't blame a specific chipset, that just creates panic. I actually fully believe most of the issues some end users are see are bios related. We have a growing list of boards now working just fine with all sorts of chipsets, other boards with the same chipsets though may have odd issues...this can only mean BIOS is the issue.
Again SSD is not HDD, most apps testing SSD were built for HDD, so its hard to correlate any results from these tests.
__________________
Tony AKA BigToe
*Consumers may see a discrepancy between reported capacity and actual capacity; the storage industry standard is to display capacity in decimal. However, the operating system usually calculates capacity in binary format, causing traditional HDD and SSD to show a lower capacity in Windows. In the case of SSDs, some of the capacity is reserved for formatting and redundancy for wear leveling. These reserved areas on an SSD may occupy up to 5% of the drive’s storage capacity. On the Core V2 Series the new naming convention reflects this and the 30 is equivalent to 32GB, the 60 is equivalent to the 64GB and so on.
Thats nothing but load of bolox. How do we measure storaga capacity? In butterflies and crickets? Of course it's binary format stupid idiots.
I have aboslutelly no clue why the heck they measure everything with factor 1000. It's 1024 ever since computing exists. But noooooooooo. They sell you 750GB drive and you get less than 700GB of actual space in freakin BINARY format. Like they discovered America or something... heh
__________________
Core i7 920 3,3GHz | 6GB OCZ Platinum | ASUS Rampage II Gene | MSI HD5850 1GB OC Edition | WD Caviar Black 2TB | Auzentech X-Fi Forte | Altec Lansing MX5021 | Corsair HX750 | TT LANbox Lite
Yes they sell you a 750 GigaByte drive, but the PC will report the amount of storage in GibiBytes and a GibiByte is 1024^3 while a GigaByte is 10^9 bytes.
BTW, doesn't write performance have a lot to do with write block size and stuff like that? By that I mean that write blocks of 4 kB each will give much lower results than blocks of 64 kB each, something that is not the case with HDDs (at least not to the extent that is seen on SSDs).
__________________
"When in doubt, C-4!" -- Jamie Hyneman
Silverstone TJ-09 Case | Seasonic X-750 PSU | Intel Core i5 750 CPU | ASUS P7P55D PRO Mobo | OCZ 4GB DDR3 RAM | ATI Radeon 5850 GPU | Intel X-25M 80GB SSD | WD 2TB HDD | Windows 7 x64 | NEC EA23WMi 23" Monitor |Auzentech X-Fi Forte Soundcard | Creative T3 2.1 Speakers | AudioTechnica AD900 Headphone |
in all honesty random writes is nearly 10% tops of what my hdd is doing. I'm not saying random writes are irrelevant but its not nearly a big issue.
If random write performance is important invest in a battery backed caching controller with a lot of ram.
