Many of us already seen some thing about EFI and know what it is capable off, but I'll post this anyway. Why? Because if you ask me this is one of the biggest real innovation we've seen in the last 10 years along with SSD. Apple uses EFI for a few years already but still we have not seen any other brand other then MSI using EFI.
EFI
EFI is divided into 2 parts. The first part has to be flashed into the motherboard. This part is the basic to run the motherboard. The other part containts tools which are not nececeraly needed and doesn't need to be flashed into the motherboard. The second part can be put onto another medium, harddisk are cd-rom.
Flashing with EFI
Flashing an EFI ready board is not so much different then flashing a Bios. Only the flash tool is different.
The EFI GUI
EFI is graphical and can display detailed screens at higher resolutions then we where used too with BIOS. You can even use the mouse in the bios, or should I say EFI?
Settings in EFI
The MSI EFI bios contains 5 different sections:
-Setting
-Utility
-Eco
-OC
-Game
Most settings are comparable with the ones you had in the old Bios. The 3 biggest innovations we see are:
-Language support
-Tools
-Games
Most brands probably won't put games into there EFI bios's but nevertheless it shows what EFI is capable off.
Some Screenshots:
Some benchmarks
OS boot time:
Bios = 45 sec
EFI = 43 sec
Superpi 1m
Bios = 15,394 sec
EFI = 15,409
Tweakers.net Conclusion
EFI works fast and stable.
Pros
-Userfriendly interface
-Multilanguage support
-Higher resolutions possible
-Extra tools are possible.
Cons
-No Port 80 information (needed for debug cards)
-No POST
-Looks to fancy.
-Games are not needed.
Source
I don't know how much impact EFI has for overclockers. Probably not much but maybe we will see some good OC tools for EFI. Who knows
