Fantastic Biobio TP45 HP : WR E8200/E8300/Q9450/X3360 ...
Hello Guys
For several days, I test the biostar TP45 HP with my few cpus and my caskade
Today i finaly test my cpus and i have broke WR i think (under Ripping.org)
My Configuration :
Code:
E8200 Q745 / E8300 Q815 / Q9450 C741 / X3360 C803B / QX9650 C739
Biostar TP45 HP (Bios 0604/0710) AC82P45 SLB7Z L818A955
Crucial Pc8500 2x1go ou Single
HIS HD4870 512mo
Coolermaster Real Power 1000w
Caskade 2 stages (-109°) évapo
My Setting for the C2D :
Code:
BIOS SETUP
O.N.E
Over-Clocking Navigator (Manual OverClock)
Intel(R) SpeedStep(tm) : Disabled
Ratio CMOS Setting : ×6 or max multi
CPU Frequency Setting : 590
Over Clock Retry Count : 1
FSB(Bsel) To NorthBridge Latch : 1333
DRAM Frequency : DDR2-1180
DDR2 Enhance Mode : Auto
DRAM Timing Configuration
DDR2 RCOMP Configuration : 2 or 4
Static tREAD Value : PL10/11 (13/15 for the Max Fsb)
Configure DRAM Timing by SPD : Disabled (5-5-5-15)
Clock Gen Configuration
PCIE Frequency Setting : 101
CPU Clock Skew Control : 200
(G)MCH Clock Skew Control : Auto
CPU Clock Driving Control : Auto
Voltage Configuration
CPU Voltage : ...
DDR Voltage : +0.600v / 0.700v
Chipset Voltage : +0.5v
FSB Voltage : +0.35v
CPU Core1 GTL Ref Voltage : 0.67*VTT
CPU Core2 GTL Ref Voltage : 0.67*VTT
MCH GTL Ref Voltage : Auto
CPU PLL Voltage : 1.5v (more it's instable)
Dimm : 2 & 4 (2 for the Single)
My Setting for the Quad :
Code:
BIOS SETUP
O.N.E
CPU Frequency Setting : 440 (for the X3360) & 490 (for the Q9450)
DRAM Frequency : DDR2-880 or 980
DDR2 Enhance Mode : Disabled
CPU Clock Skew Control : Auto
CPU Voltage : ...
DDR Voltage : +0.400v / 0.500v on 1:1
Chipset Voltage : Auto (or + 0.4/0.5v) same fsb
FSB Voltage : Auto (or + 0.3/0.35v) same fsb
The newt Week end , i need test 2 QX9650 C1 and the Q9550 C1 too , maybe others good surprise !!
Only defects of the TP45 HP are vdroop on C2D/Quad (+0.04 / 0.06v) and performance in Superpi / pifast & Co (you must change the Mchbar / offset and make timmings tight to make good results)
__________________
OCM Member / IXTREMTEK Admin !!
DDR1 2*256 BH5 Adata @324.7Mhz 1.5/2/2/5 1T at 4v @318.6Mhz Benchs DDR2 1*512 Kingston Pc8500 @702Mhz 5/5/5/18 at 2.42v réel DDR2 2*1024 Cell Shock Pc8000c4 @534Mhz 3/3/3/8 at 3.5v réel
i'd love to know your bios settings for the quad cores to be able to get so high..
PLeAse share them!
it sucks that the maximus line of mobo's arent support but many of the other asus P5 older and newer boards are, i'd love to see what setfsb can do for my maxi formula
__________________
no more computer...... HeatEbay XB360 GamerTag VvvlestatvvV
WoW.... group of WR very nice result Bob, Congrats m8
looking forward for Q9550 result
__________________ Sorry For My English OverclockZone Team THAILAND
Originally Posted by hipro5
Actually there is NO NEED for 164 phases that companies put in nowadays mobos....
FOUR (4) are enough with nowadays materials and maybe SIX (6) with the upcoming Gulftowns....
The 1024 phases is a "marketing trick" nowadays....
You will buy MY mobo because I put 2048 phases in my motherboard....
Of Course , i have 3pcs of TP45 HP at home (i have just test the first)
Originally Posted by loopy83
Nice results ..... whats the max FSB of the Board with DC?
661mhz sure (my E8300 on air) but i haven't test the max fsb on caskade (with the 6x or 7x multi )
Originally Posted by TheGoat Eater
way to go BOB !!! - that is a nice clock on the QX9650
Thank , i hope found the better QX for my caskade (more + 5.9ghz) and i can benchs at + 5.7ghz spi1 mo
Originally Posted by okorn
Another Biostar....amazing
P45 rlz
Yes impressive little P45 , great price/perf but with the few defects (vdroop/perf on stock)
Originally Posted by Achill3uS
biobio takes all the stars? aah not again
congrats m8, really nice collection
it's a nice model (not very complicated for the settings), offers good frequency max for only 4 phases even with quad !!
I prefer overclock the motherboard on top price that the more expensive models (but it remains interesting to test the different models P45 and see the different settings to find the max of the motherboard)
Originally Posted by Lestat
i agree pretty insane clocks.
PLeAse share them!
No pb , i have add the setting in the first post
Thank you
Originally Posted by Gautam
You must go for 100% on the E8300.
Yes , i would like , maybe the next week !!! (are you recieved the E85 ?)
héhé thank Zolkorn , i hope found the good Q9550 (Chip C1 ES Q803 i think) , answer the next week !!!
Originally Posted by Blacky
nice quad fsb
Yes good fsb max of Quad for the little Biobio
Originally Posted by c1rcu1tburn3r
Wtf boble, you killed my e8200 wr
I'll hate u till you'll die.
Soory man , my E82 isn't very good Chip (it's hard have screen at 652mhz !!) , the E8300 is very better
I wait your result with the P45-DQ6 ant the news setting , good luck
__________________
We want 700MHz now
We know you can do that.
This combo is very amazing
Héhé yes but with LN2 i think !!! et maybe 6ghz for the E8300
Originally Posted by Fr3ak
Impressive results! =)
Thank Bro
My cooling Chipset is a few "special" !! my waterblock is too big for the chipset, so I find a piece of copper at a friend today (it's coming from a device dentist ) it's not very good but for the First test , I am quite satisfied
Now i hope able to test under LN2 before selling it, but its difficult to get to my house and it is very expensive .
__________________
Temp Evapo : -109°
Temp Liquid Chiller : -25° (in the reservoir) for the NB !!
More Pics soon
107% on the E8300, what can anyone say other the superb.
My E8200 is killer good for air/water, I can send it you to try on the cascade, just don't burn it though
Can you try same settings with 6 Multi for max fsb? You have Pm
__________________
24/7 Gigabyte EP45-UD3R|E8400 @ 4302 Mhz @1.344v|Corsair 2 x 1GB DHX @ 940 Mhz 2.06v|PNY 9800GX2 700/1750/1100|Cooler Master 690 + 3 x 140mm + 2 x 120mm|TRUE + 2 x 120mm|Chieftec 750-14C 750W
