XtremeSystems Forums
Go Back   XtremeSystems Forums > Gaming > Clan Team Xtreme > MMOs > Age of Conan
Reply
Old 07-15-2008, 02:52 AM   #1
darthvedor
Send a message via MSN to darthvedor
Call of Duty 4 - iw3mp.exe
Hi all,
I install cod4 on my laptop, but when I try to play online gives me always the same error, iw3mp.exe stop working, someone knows how to solve this?
All patches installed up to 1.7
Punkbuster also updated.
Laptopell XPS M1710, card 7950 GTX
OS: Vista 32 SP1
Thanks,
darthvedor is offline   Reply With Quote
Old 07-15-2008, 10:16 AM   #2
FlawleZ
FlawleZ's Avatar
Send a message via AIM to FlawleZ
Do you have a legit copy of the game?
There's workaround renaming one of the files to a .bak extension. I'll try and dig it up again...
__________________
Phenom II 720 BE @ 3525Mhz
MSI 790FX-GD70
4GB OCZ Reaper 1333 DDR3 CAS6 6-6-6-16
Sapphire HD 4850 512MB 700/2300
WD Caviar Black 640GB
Mad Dog X-Connect 600W
Thermaltake Shark
FlawleZ is offline   Reply With Quote
Old 07-15-2008, 11:15 AM   #3
EagleRock
Xtreme Cruncher
EagleRock's Avatar
Send a message via MSN to EagleRock
I think the problem is in the sound try enabling you mic and i think it will work.
__________________
Asus P5E, Q6600 G0, Thermalright 120 Extreme, 4GB OCZ Reaper, Ati 4870 X2, Corsair TX850W, Coolermaster HAF 932, X-FI XtremeGamer, WD Caviar Black 1 TB, Samsung 500GB.
The world needs your support.
Join The XS WCG team and help cure Cancer, AIDS, and other diseases.
EagleRock is offline   Reply With Quote
Old 07-15-2008, 11:39 AM   #4
darthvedor
Yes, is a legit copy.
Old 07-15-2008, 11:50 AM   #5
3oh6
uncore challenged...
3oh6's Avatar
yup, usually sound related. as mentioned ^^, enable your mic if your sound drivers are installed, and if they aren't...then install them and you should be in business
__________________
3oh6 is offline   Reply With Quote
Old 07-15-2008, 01:40 PM   #6
darthvedor
Problem solved, latest sound drivers from dell intalled and voila i´m in the game.
Thanks all
Old 07-15-2008, 02:26 PM   #7
Knight
Knight's Avatar
Wow! This error can be sound related? I've had this problem with CoD4 only. Crysis ran fine, so I didn't think it was a OC problem.
I will enable my mic and see if it helps.
Thanks,
__________________
Intel | Q6600
ASUS | P5Q-Deluxe
G.Skill | 2x2GB PQ
Nvidia | 8800GTS 320MB
Seagate | 2x320GB 7200.10 Raid 0
Corsair | 520W PSU
Knight is offline   Reply With Quote
Old 07-21-2008, 07:18 AM   #8
Cassell98
Yeah I had the same problem with windows vista. I didn't install directx 9 because I thought vista would have it covered and nope sure didn't. Installed the latest directx and the problem went way
Cassell98 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
