[OC Team Latvia] Smashing the 3dmark2k1 WR!!!
Sam & mrlobber (OC Team Latvia) are back for another round
Thanks to 4850/4870 cards hitting the market with such a bang, G92 are dirt cheap nowadays, so:
now we can afford to bench 3D as well
And by the way, did Vince become too comfortable sitting up there in the 3dmark2k1 hill? Now he has some work to do to catch us up
3D rig
Core2Duo E8500 (Q746A, 1A0007)
eVGA 132-CK-NF79-A1 (790i Ultra reference)
2x1Gb HyperX 14400 (Micron D9GTR)
eVGA reference 8800GTS 512Mb (Samsung mems) Vgpu mod
Club3D reference 8800GTS 512Mb (Samsung mems) Vgpu mod
Samsung 40GB SATA (SP0401C)
WinXP SP2, ForceWare 169.21 (modded 173.67 don't work for some reason)
CPU cooling : Vikingpot 1.2 + LN2 (temps in the -140C to -125C range during bench)
Mobo cooling : stock cooler + two 120mm
mem cooling : stock cooler + 120mm
both VGA cooling : Tek9 + LN2 (both cards nice and smooth below -105C, no coldbug)
Vcore = 1.83V via CPU-Z
Vtt = 1.45V (BIOS set)
Vmem = 2.20V (BIOS set)
Vspp = 1.55V (BIOS set)
Vmcp = 1.70V (BIOS set)
Vgpu = 1.77V on Club3D card , 1.74V on eVGA card (both are vGPU modded)
GTL settings = keeping these a little secret
5:8 divider (unlinked mode), P1+P2 enabled
Tweaks:
OS base - exact same as the one posted in Team OCX zone
5 services left running
explorer off
run order DH-LL-LH-DL-CH-CL-N
LOD 4.9 (not optimised for each test)
cards maxed only for nature, other tests ran at lower GFX freq due to CPU limit
boot at 616x9.5 sometimes gets corrupt OS (luckily, have 3 backup OS), really need clockgen for this board
FM compare link : http://service.futuremark.com/compare?2k1=9392159
Unfortunately, our stock of LN2 ran out, so we had to settle with 123k, otherwise we suspect there would still be possibilities of some backup scores on this rig
Also, we found another good E8500 recently ... that means another WR, this time for E8500 32M
SuperPi rig
ASUS P5K3-Deluxe (79M0ACP39xxx Taiwan PCB) fully Vmodded, BIOS 0910
7300GT GDDR3
WinXP SP2
CPU cooling : Vikingpot 1.2 + LN2 (temp in the -140C zone during bench)
Vcore = 1.74V DMM (Vcore mod)
Vpll = 1.85V DMM (Vpll mod)
Vtt = 1.40V (BIOS set)
Vmch = 1.75V DMM (1.7V via BIOS)
Vmem = 2.35V DMM (2.25V via BIOS)
CPU GTL : 0.67x via BIOS
NB GTL : 0.61x via BIOS
5:8 divider, strap333 via BIOS
Tweaks:
basic reg.tweaks
only 3 services left running + drivers' chop by "Autoruns"
CDT (OPB's method with WinRAR files)
explorer off, priority CPU1, affinity high
boot at 600x9.5 then clockgen to 609x9.5 just before hitting "OK" on the 32M
32M screen:
And we have some young benchers growing up as well (that's another rig and an unsuccessful yesterday's bench though)
away & gone
- You may not post replies
- You may not edit your posts
Forum Rules
