Are there any air solutions for the new GX2 yet?
never seen a aftermarket aircooler released or announced for the 9800GX2, only water.
I had this idea ages ago. Thermalright says that the HR-03 Plus's will mount on a 9800GX2, so.
Sorry if I missed a few little details and that the picture isn't great.
Have yet to see anyone do that, but it may work. I was waiting for Thermalright to bring out something for mine, but I've sent it back for the step-up to the 280. Which WILL have a specific HR-03GTX made for it, in August![]()
i5 750@3800
Noctua NH-U12P/120x38mm Panaflow M1
GSkill 4G DDR3-2000 Ripjaws
EVGA P55 FTW 200
EVGA GTX 480/Zalman VF3000F &
Zotac GTX 480 AMP Edition/Zalman OEM VF3000F SLI@800/2000
Seasonic M12D 750
WD Caviar 500
Coolermaster HAF 932 Black Edition
W7 64 Pro
It is possible to use 2 x HR-03 Plus/GT (with a small modding in case of Plus) in order to cool the 9800GX2.
Check this link from thelab.gr. The site is in Greek but the images might be very helpful.
Note that the first picture describes the small holes that you should make in case that you have HR-03 Plus. However if you have HR-03 GT you don't need to do this.
Many thanks to LevelOne from thelab.gr
CPU: Q9450 @3.6 | M/B: Rampage Formula | RAM: 4GB Dominator 1066 | VGA: Sapphire HD4870 | HDDs: 2 x Seagate 7200.11 32mb 500GB| Case: Lian-Li V1200B | PSU: Galaxy DXX 850w | Monitor: Samsung SM2232BW | Keyboard & Mouse: Logitech G15 & G7 | CPU Cooling: TRue 120 | Fan Controller: Kama Meter | Sound: Asus Xonar D2, Yamaha RX-V363 Amplifier, Yamaha YST-SW515 Sub, Crystal Audio TX-B1 & Roister Speakers
^ thats pretty badass.
- Silverstone FT-01B
- Corsair HX620
- DFI LanParty DK 790FX-M2RS
- AMD X2 6400+ BE w/ Thermalright Ultima 90 @ 3.2
- 2 x 1 GB G.Skill DDR800(4-4-4-12)
- 2 x 1 GB Corsair XMS2 Dominator(4-4-4-12)
- BFG Tech 9800GTX(stock cooling for now)
- 2 - 250GB Seagate SATA
Will the mem get enough cooling? But agreed, that is very cool looking.
The memory are cooled by individual radiators ... some Aluminium, some coopers..The sets used are different..
-AMD Phenom II X4 940BE oced to 3.6ghz with Scythe Kama Angle
-4 gb ram DDR2 Mushkin
- Gigabyte 790X UD3P with F7A beta bios
- Sapphire 6950
- WD 1001AALS Caviar Black
- win7 x64 with all updates
-Asus Xonar DX
-Samsung 223C DVD-RW
- Broadcom Xtreme NIC
-PSU: Corsair 750HX
WOW i so want that card, but i'm not sure i could fit it all in with my IFX-14.
Woah, that GX2 looks so slick. Nvidia could have sold something like that with a 30% markup with ease. Looks like a spaceship or something![]()
BTW thats so much for posting the link and pic's![]()
Hello guys, just dropped in to say a few words...
First of all, the memory IC's are no different from any other VGA. Using either aluminum, or copper heatsinks will provide enough cooling for them. In my case, i simply didn't have at the time two identical sets of heatsinks, so i went with what i had.
The one thing that needs to be taken seriously into consideration (and was by all means the hardest point of this project) is the VRM's... These can get very hot (~100C) and have to be efficiently cooled especially when you do all the Vmods. The problem with these,
is that they have such a small surface, and so little clearance, that installing normal RAM heatsinks is simply out of the question. They will simply not support even their own weight, so you might consider using other* mounting solutions. The whole procedure is 100% reversible provided you save all the little stock screws and a couple of photos to remember how it is mounted.
The results of this card were pretty good. With stock volts, the card benched at 830/1170 and with temps of around 50-55 @ full load. With the Vmods the card reached (as far as i can remember) 840/1190. I have a feeling though that the VRM's were responsible for this cut-out...
Bear in mind, that this is not a viable 24/7 solution, unless you don't mind having on your computer just your VGA. Not exactly spacious.
*I have yet to find out (glueing is one, but i look for something reversible)
Hope you liked it, cheers!
That is serious eye-candy!!!
My god, it looks more bad@$$ than a freakin awesome wc setup!
