XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Benchmarking
Reply
Old 06-27-2008, 09:01 PM   #26
Truckchase!
Truckchase!'s Avatar
Originally Posted by aldamon View Post
You shouldn't have to do that. It's a shame that the dozens of hardware sites, that had both cards in their possession, didn't run this kind of test so you wouldn't be put in that position. It's like they took for granted that the 4850 would never hit the core speed of the 4870 and just ignored the possibility the GDDR5 is all fluff.
I enjoy doing this stuff. Most reviews aren't very good. Quantity does not necessarily equal quality. I appreciate the concern tho....
__________________
Asus P6T-DLX V2 1104 & i7 920 @ 4116 1.32v(Windows Reported) 1.3375v (BIOS Set) 196x20(1) HT OFF
6GB OCZ Platinum DDR3 1600 3x2GB@ 7-7-7-24, 1.66v, 1568Mhz
Sapphire 5870 @ stock until DP Flicker is fixed in unlocked BIOS
X-Fi "Fatal1ty" (endorsements suck) & Klipsch ProMedia Ultra 5.1 Speaks/Astro A40 Mixamp with beyerdynamic DT-880 Pro (2005 Model) and a mini3 amp
WD 150GB Raptor (Games) & 2x WD 640GB (System)
PC Power & Cooling 750w
Homebrew watercooling on CPU and GPU
and the best monitor ever made + a Samsung 226CW + Dell P2210 for eyefinity
Windows 7 Utimate x64
Truckchase! is offline   Reply With Quote
Old 06-27-2008, 09:30 PM   #27
adpr_02
Here is my 2C. I'm sure it's not much, but just shows that memory does help - at least in synthetics.
According to Legit Reviews, the HD4870 gets P8769 3dmarks.
Their processor is the newer Q9770.
My system, with the card clocked at 720/1050 and my q6600 at 3.6ghz I get P7850 marks.
The net processor performance, I am guessing is the same since, although theirs is 3.2ghz only, it's the newer version with higher performance/clock. Also, I do not think the CPU score has a very large impact on the overall score.
Seeing as how my clocks are so close to the 4870 (with the memory overclocked, even) and my score is so far away, I am guessing that the GDDR5 does have an impact, but it is not that large. I am sure that if I pushed my core to 750 I would jump my score to P8100.
Just my 2C
adpr_02 is offline   Reply With Quote
Old 06-28-2008, 04:12 AM   #28
aldamon
Just my 2C
If you did overclock to 750 and hit P8100, you'd only be 8.25% off of the 4870's pace. Games are showing an even smaller difference.
__________________
ASUS P5K | 4GB Micron D9
Q6600 | Ultra-120 Extreme
512MB PowerColor HD 4850 @ 775 /1075
Raptor 150GB | X-Fi XtremeMusic
Cooler Master RPP 750W
aldamon is offline   Reply With Quote
Old 06-28-2008, 08:13 AM   #29
adpr_02
I've got close to that. I looked at their score, and didn't realize they shwed the gpu and cpu score. So I get my cpu score close to theirs, and bench again, this time with my card at 735/1060.
I got 7121 marks on my gpu score
They got 7890 marks on their 4870 gpu score
My cpu score was 13295
Their cpu score was 13132
I noticed that cpu speed does not affect the gpu score at all (My gpu score was exactly identical at 3.6ghz and 3.8ghz.)....
Overall, I got 8050 marks
They got 8769
My gpu score jumped more than 100 marks by increasing the gpu frequency 15mhz (and memory 10mhz). At 750/1050 this card should score around 7250 gpu marks which would bring it close to the 4870.
I am guessing that this card clocked at 800/1200 should EASILY overtake the 4870. I'll try that when I get the right size variable resistors.
Old 06-28-2008, 10:33 PM   #30
keiths
Originally Posted by Truckchase! View Post
1. What performance drop off? GPU, memory, both? Be specific.
2. You can't compare to a review. They have different base hardware, different OS, different benching techniques, etc. On top of that I can't guarantee the skill of the tester. (nor should you)
3. Max overclock will vary on a card by card basis, but obviously will reach an average. (as I believe you're getting at) However, the point of this thread is not to compare to Nvidia products, but to compare a 4850 vs. A 4870.
My point is that the main difference between a 4850 and 70 is the memory bandwidth. (yes I realize the voltage circuity is better on a 70) Given this information, one can conduct tests to see if the 4850 is memory bandwidth limited and answer the majority 4850 vs. 4870 question, which is the premise of this thread. That being said, I think I'm going to unwrap my 4850 tomorrow and do some tests since I have the automated scripts to do so. The offer still stands if anyone wants to buy this card since I'm getting 70 from FXVideoCards on Wednesday.
Edit: Oh snap, I didn't see that it was you that opened the thread until now KeithS.... do you want to change the context? I can't provide Nvidia data.... I'll just say they're "for the most part, faster and more expensive"
1. Memory. I'm interested in seeing how big a benefit the 4870's memory gives.
2. You can, and we already have, roughly. In spite of different platforms, there are trends in the results.
3. Of course, and yes, average.
I had added it since gurusan provided an oc result. That a 4850 can reach 260 and 280 performance makes me interested in seeing those results as well.
keiths is offline   Reply With Quote
Old 06-29-2008, 01:43 AM   #31
gurusan
gurusan's Avatar
The 4850 can surpass the GTX 280 The guy with .2 fps more than me has a highly clocked 45nm quad @ 3.7ghz while I only have a 65nm dual core at 3.6ghz. Also you should notice his GTX 280 is overclocked quite a bit :p
__________________
|| E8400 @ 530x8.5 = 4505MHz || EP45T-UD3P || 4GB DDR3 1700MHz CL7 ||
|| Sapphire HD4890 @ 905/1100 1.275V || Toughpower 750W || Antec P182 ||
|| 2048x1152 23" Samsung || Air cooled || Sennheiser HD580 ||
gurusan is offline   Reply With Quote
Old 06-29-2008, 02:14 AM   #32
Lightman
Xtreme News
Lightman's Avatar
That is very impressive!!
Congratz!!
__________________
RiG1: Phenom II 940BE 0850BPEW (45nm@3850MHz 64bit), Gigabyte MA790FX-DQ6 (RD790FX), 2x2GB OCZ Reaper PC8500@1145MHz 5-5-5, HD5870 1GB, 2x1TB Samsung F1 RAID0 + 750GB Samsung F1 + 400GB Samsung T133 + 30GB OCZ Solid SSD, Hiper 4M880
RiG2: HTPC AMD Athlon II 250, 2GB Crucial Ballistix D9, ASUS M3A78-EM, ASUS HD4670 512MB, 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH
SmartPhone T-Mobile Compact V
XBOX360 Elite paired with 52'' Samsung LCD TV
Lightman is offline   Reply With Quote
Old 06-29-2008, 02:21 AM   #33
keiths
Yep, what I expected from linear extrapolation of your 810 result. What's your cooling now gurusan? Is 1680x1050 your max/monitor resolution? I'd like to see where the 4850's memory peaters out. And where is that chart from?
Old 06-29-2008, 05:10 AM   #34
gurusan
gurusan's Avatar
on watercooling. 27-28c idle 36-38c load.
And yeah 1680x1050 is my max resolution. The chart is from a private forum so I can't really share it here :p
__________________
Old 06-29-2008, 05:42 AM   #35
aldamon
I'm ordering one of these bad boys when I get back from the beach.
__________________
Old 06-29-2008, 08:13 AM   #36
keiths
What's your water cooling setup?
Old 06-29-2008, 08:25 AM   #37
gurusan
gurusan's Avatar
Laing D4 --->XSPC Edge--->Maze4--->Alphacool 120.3
__________________
Old 06-29-2008, 10:17 AM   #38
zaraza
in order to reach those speeds could i do it on AIR with a accellero s1 v2 with 2 120mm fans? Also the pencil volt mod, is it safe to do with an S1 on it. How high will i be able to clock with the pencil mod? I want to try it when i get my 4850 next week. Also what kind of pencil did you use for the mod?
zaraza is offline   Reply With Quote
Old 06-29-2008, 10:24 AM   #39
gurusan
gurusan's Avatar
you should be able to do high 850-900mhz on air i would think. And I just used a #2 pencil
__________________
Old 06-29-2008, 10:48 AM   #40
zaraza
Dang gurusan thats awsome! i really want to buy the 4850 now and try the mod, i was thinking about buying it from besbuy inorder to have the option to return it if it goes wrong. lol. but newegg gives 2gb of ddr2 for free with a visiontek. In the techpower article it said i wont get more than 1.4 on the vddc, is that true? Please stick with me and help me understand this. This is my first time considering to volt mod.
Old 06-29-2008, 10:51 AM   #41
zaraza
the only problem i would have from overclocking, is that i have to flash the bios to get the speeds right?
Old 06-29-2008, 01:34 PM   #42
keiths
Long ago I did a homemade water setup for my k6; square PCV block caulked right onto the CPU Still have the bilge pump I used(attwood v450, 450GPH@13.6v so ~= 397GPH/1503LPH@12v vs 1400LPH for the Liang D4,) and tubing. Also have an AC condenser/evaporator from a 90s Civic that I can use as a radiator, which is as tall as my tower case, slightly narrower, ie big for this use, which has a half and quarter inch inlet/outlets. Leaves coming up with a container to hold the pump, scrounge something up, and the water blocks.
Old 06-29-2008, 03:32 PM   #43
aldamon
Can we get a list of expected overclock and maximum voltage per cooling option?
Is this about right?
Stock cooler with higher fan speed
1.3V? 800MHz?
Upgraded air
1.4V? 850MHz?
Water
1.5V+? 900MHz+?
__________________
Old 06-29-2008, 03:58 PM   #44
gurusan
gurusan's Avatar
910mhz on 1.45v for me under water
__________________
Old 06-29-2008, 04:37 PM   #45
zaraza
someone with a 4870 really needs to step it up and post comparisons to 4850 oc's
Old 06-29-2008, 04:39 PM   #46
dnottis
Xtreme Mentor
dnottis's Avatar
What block?
__________________
Q9550 @ 4.105 Ghz
Gigabyte P45 UD3P F9
G.Skill PC2-8800 DDR2-1100 8GB Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, D-Tek FuZion pro mounted, FuZion GFX 2
Cooler Master UCP 1100 Watt PSU
MSI HD5870 1Ghz (1.16v), 1300Mhz
Lian Li PC V-2000
Acer X222Wbd 22" LCD
3 x WD 640GB WD6400AAKS HD
Pic of my watercooled rig
dnottis is offline   Reply With Quote
Old 06-29-2008, 04:43 PM   #47
gurusan
gurusan's Avatar
Originally Posted by dnottis View Post
What block?
maze4. 27c idle 36-38 load
__________________
Old 06-29-2008, 04:47 PM   #48
dnottis
Xtreme Mentor
dnottis's Avatar
any problems with it fitting? no mods or anything right?
__________________
Q9550 @ 4.105 Ghz
Lian Li PC V-2000
Old 06-29-2008, 04:50 PM   #49
dnottis
Xtreme Mentor
dnottis's Avatar
Ive got a Q6600 65nm @ 3.6Ghz, 4870 @ stock I scored P89xx. Dont remember the exact number but was just under 9000.
I will run Crysis 1680 later, what settings are all the ones in the spreadsheet run at? 1680x1050, very high, no AA?
__________________
Q9550 @ 4.105 Ghz
Lian Li PC V-2000
Old 06-29-2008, 05:16 PM   #50
jaredpace
I am Xtreme
jaredpace's Avatar
dudes, hunch: r700 will be slightly faster than two 4850's in crossfire.
i checked some benchies, 4850 averages around 79-80% the performance of a 4870, i think the extra 125mhz adds about 17% while have gddr5 adds the next 3-4%.
if the plx bridge doesn't do anything super for increasing r700's performance over 2x hd4870 in old-fashioned traditional [two-pcb/two-pcie] x-fire, then we should expect R700 to be 4% faster than 4850 x-fire (which still eats up a GTX 280 for the performance crown). Nvidia loses come August! Wonder if they take the lead again with 55nm gt200?
edit: just realized i posted this in the 4850 vs. 4870 core speed comparison thread, but it still has relevant information. I agree with this guy 100%:
Yeah, but that 25% difference was at stock speeds. 750 is 20% higher than 625, so are we to assume that at stock speeds, the GDDR5 only gives the 4870 a 5% advantage, clock per clock? That's a pretty crappy value if so and would explain the BIOS lock. I'm curious to see if that gap widens with higher core speeds.
__________________
Originally Posted by AndreYang View Post
Damn...Today is 11/06, but [his] bios date is 11/07........lol
jaredpace is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
