Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 52
Thread: Overclocking 4850 beyond 700mhz
  1. #26
    Aug 2006
    Oxford, UK
    Quote Originally Posted by Battlestar View Post
    Using stock cooler?
    yes. And asus fan control. THe stock cooler isn't half bad if you can control the fan
    || 2500K @ 5GHz 1 thread, 4.8 2 threads, 4.7 3, 4.6 4 1.284V ||
    || P8P67-M Pro || 8GB @ 2133MHz ||
    || 5850 @ 1000/1225 || XFX 650W || Silverstone FT03B ||
    || 37" LCD TV || CM Hyper 212+ || Samsung 2.1 Soundbar ||
  2. #27
    Dec 2007
    Quote Originally Posted by gurusan View Post
    Cool, I assume you used this trick (you posted on previous thread):
    disabled overdrive, pencil modded...edited the bios with a hex editor...and flashed
  3. #28
    Aug 2006
    Oxford, UK
    yup. It sounds like a new version of RBE will be released very shortly though...allowing fan control as well as clock changes. That's much easier than editing the hex tables....staring at all those values gives me a headache.
  4. #29
    Dec 2007
    Hehehe but you have a nice table there buddy, let say you have successfully OC your card in hard mode RBE is the easiest way, but if the release won't up this evening, I'll try your trick
  5. #30
    Feb 2008
    Quote Originally Posted by Jakalwarrior View Post
    A VF700 is enough for this card?!?! time to canabalize my 7600GT. Will have to buy lots of ram sinks though I assume for all of the stuff.
    VF900 certainly does work with this card, i'm running the ZV9 (the silver/red version) on mine.
    With fan at lowest (silent) idle temps are ~50C, load temps ~85C (stock cooler was giving me 82C idle, 92C load).
    If you crank the fan up to about half way on the VF900/FC-ZV9 then load temps come down to ~70C, maxed out fan (noisy as hell!) will give you high 50's/low 60C's.
    The Accelero S1 will prolly give you better temps with a 120mm strapped to it, but I didn't have the space to squeeze one in.
  6. #31
    Banned
    Apr 2006
    NYC
    Quote Originally Posted by easyrider View Post
    4850 I would think.
    Its in the title.
    LOL
  7. #32
    Banned
    Apr 2006
    NYC
    RBE doesn't display anything here, in Vista Business x86... what am I doing wrong?
  8. #33
    Xtreme Legend
    Jan 2003
    Stuttgart, Germany
    Quote Originally Posted by T2k View Post
    did you click file -> load bios ?
  9. #34
    Aug 2006
    Oxford, UK
    ^lol.
    it works fine for me..I'm on Server 2008 64bit
  10. #35
    Dec 2007
    ^lol.
    Hi I have a problem regarding the RBE latest version. I set the fan into default settings and it shows on GPU-Z 50% fan speedand it drops my temps from 72deg to 61deg , my problem is it underclock my GPU Clock into 500Mhz but the Default Clock remains 625 Mhz with same Memory 993Mhz I think. Is this normal? Sorry I can't provide screenshot still here @ the office Anyways, I revert my default BIOS and still waitin' for your answers
    -battlestar
  11. #36
    May 2007
    Louisiana
    Does it stay at 500 when you give 3d work load?
    E7200 @ 4.0ghz 1.29vcore
    2x 6870
    OCZ 4gb @ 5-4-4-12 846mhz
  12. #37
    Dec 2007
    Hmm Im not sure buddy, But Im pretty sure when you check on GPU-Z under Graphics Card Tab at the botton you can see this following:
    Using RBE with 50% FanSpeed (I used the Set all fan settings to recommended values that's why came up 50% FanSpeed)
    GPU Clock: 500Mhz Memory:9XXMhz
    Default Clock 625 Mhz Memory:9XXMhz
    Also on GPU-Z Sensor Tab:
    GPU Core Clock: 500Mhz
    GPU Memory Clock: 9XXMhz
    My Default BIOS
    GPU Clock: 625Mhz Memory:9XXMhz
    Another thing, I don't see anything this kind of tables on my latest RBE
    *See attached file with red box
    Im using WinXP SP3
    Sapphire 4850
  13. #38
    Jul 2005
    can u give our RBE software ? I can't download it from anysite !
    THx !
    best regard !
  14. #39
    Aug 2006
    Oxford, UK
    Quote Originally Posted by thriller99 View Post
    THx !
    best regard !
    How about checking the site where it always is? :p
    http://www.techpowerup.com/downloads/Utilities/RBE/
  15. #40
    Feb 2007
    My Default BIOS
    Im using WinXP SP3
    Sapphire 4850
    i don't have that table on mine either.
    E8500 (4.2 ghz)
    Crucial 800 8gb
    Abit IP-35 Pro
    Thermalright Ultra 120 Extreme
    Hr-05 NB heatsink w/ 80mm fan
    GTX260
    Antec Quattro 850 psu
    28" I-Inc lcd monitor
    Logitech G9
    Logitech G15
  16. #41
    Dec 2007
    Ok, Im downloading the MSI & Visiontek 4850 BIOS here and it looks like both Visiontek & Sapphire have no Uselook up table for the latest version of RBE. MSI have one and not sure on the other brands
  17. #42
    Dec 2005
    Peoples Republic of Berkeley (PRB), USA
    My Sapphire 4870 has lookup tables in the latest RBI, just FYI. I set everything to recommended and now the card sounds like a hair drier half the time, but runs a lot cooler
    The cooler reminds me of my x1900xt...
    core i7 920, gigabyte EX58-UD5, 4870x2
    DDC3.2 > PA120.3 > DD4870x2fc > Fuzion v1 > PA120.2 > EK Res
  18. #43
    Banned
    Apr 2006
    NYC
    Quote Originally Posted by W1zzard View Post
    Yes.
  19. #44
    Oct 2007
    so when can we expect the normal overclock utilities to support 4800 series? Way more easier and safe to overclock on driver level instead of bios flashing.
  20. #45
    Jun 2003
    Portland, Oregon
    Quote Originally Posted by painkilla View Post
    http://www.hardforum.com/showthread.php?t=1322701
    Not a "normal" tool like RivaTuner but a simple software one at least...
  21. #46
    Jun 2008
    How does a 4850 @ 740/1050 compare to a 4870 @ stock in game performance?
  22. #47
    May 2004
    Brisbane, Australia
    Is it normal for the default memory to be stable at 1100mhz?
    I flashed mine with 1.327v core and it didnt seem as stable on the core as when I used 1.158v.
    Right now 1.158v 700/1100mhz flash seems to have worked really well. Updated the FAN profile so its idling around 55c now with 45% FAN and kicks up to about 70c under load with 55% FAN. Seems quite solid.
    CPU : i7 2600k @ 5Ghz
    RAM: 2GB DDR3 Corsair 1600mhz 78720
    MB : Asus P8P67
    GFX : ATi HD6970
    HD: Cosair F60 SSD - Raid0 + 1TB Samsung - Raid1
    Sound : Razer AC-1 and AD700s
    PSU : Thermaltake ToughPower 750W
    LCD : Asus 24inch MK241H 2ms
    Cooling : Swiftech CPU
  23. #48
    Engineering The Xtreme
    Feb 2007
    MA, USA
    Quote Originally Posted by HamTard View Post
    IIRC 10%
  24. #49
    Xtreme Mentor
    Feb 2008
    Powercolor use the following HSF on their overclocked 4850's:
    http://www.zerotherm.net/eng/product/GX810.asp
    It doesn't list the 3800 and 4800 series as being compatible, but they are used on both Powercolor and Club 3D cards.
    Maybe send an E mail to Zerotherm if you need to ask about compatability, but the coolers are very good - 3850s run at 70 degrees under full load at 775 Mhz, I'll get my 4850's soon to play with.
    I think the best solution is to just buy a card with one of these on it. No furthur modding required, just install it and start overclocking =D
  25. #50
    Mar 2007
    Pilipinas
    I wanted to put my Zerotherm cooler on my 4850 Sonic but Palit put the freaking warranty sticker on one of the screws. It's not a big deal because the Sonic's heatpipe cooler is already so much better than the stock one. The Sonic's stock clocks are 685/1000 iirc and I tried Auto-Tune in CCC just for the heck of it and it set the clocks at 720/1040.
