XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Graphx Vmods
Reply
Old 07-08-2008, 07:17 PM   #26
VETDRMS
Sorry for the delay guys, way too much going on around here.
The mod went fine, but the results really were a mixed bag. First thing is its a hot chip and it responds really well to lower temps, but no so much increased voltage.
Here is what the card looked like with the EVGA block removed, lots of white silicone, with pretty bad contact on the memory chips. I re-set the block with AS Ceramique to check contact and it was better with a little more paste and more torque on the block. Nylon spacers are used between the block and the PCB.
The finish on the block was so-so, the machine work was a little rough but all that buffing costs money I guess. I pulled the block apart to clean the leftovers from tapping the inlet/outlet holes for fittings.
I'm sure you've all seen EVGA's take on cooling, the logo is pretty neat and it seems to work pretty well, but seeing how I was already in there I figured I'd break out the dremel and create a little more surface area. I didn't go that deep as it is not that thick to start with. Flame on if you want, I couldn't think of how this would be detrimental, should at least create more turbulence through the "pin" array.
The mod was refreshingly simple, with nothing really to burn up. I used to mount the pots legs directly to the solder point, but if the card is going to be moved around a lot, I have found the small wires give a little more without damaging the board.
I actually forgot to install a vGPU check line before bolting the block up so I had to do this while the block was in place, otherwise I would have used a point closer to the outer edge of the board.
While I had the block off I polished all the visable surfaces, and hit the ram and cpu seating surface lightly, which took off some edges you could feel with yoru fingernail. Its pretty sharp all polished.
Results:
Using chilled water (water temp is maintained around 60F with a 5000btu Daewoo AC) the card responded well. Idle temps were 20C while loaded temps were 28-31C.
I found there is an issue with clocking the card past the high 700s and 800s range using Riva/Precision. You can get past this by using Nibitor, but your core clock will be reported as 100mhz in Riva/Precision. Also, as I have never loved Nvidia's dynamic clock switching (anyone remember the 7900 not switching?) I set all the clocks and VID the same in the bios. This caused a rather nasty corrupt screen when loading windows so I flashed it back, clock switching will stay I guess.
I was able to run 826 core 1620 shader and a pretty impressive 2754 on the memory. I was able to run 2800 on memory for benchmarks, but it showed some errors in ATITool. 1674 shader was not doable at any voltage. Also, forcing different shader clocks in the bios has mixed results, as does forcing odd clock frequencies. Setting core to 794 and shader to 1512 would cause instant hard-lock in ATITool, setting core to 794 and shader to 1566 was stable. Setting core to 795 would instant hard-lock. All clock changes had to be made with bios as Riva/ATItool would not set clocks above 783 core.
As far as voltage goes, anything over 1.350v caused it to pop pixels in ATItool constantly. Even with loaded temps in the low 30s. The card was bench-stable/game-stable at these speeds with the chilled water, but was not stable once loaded temps passed 45-47C (with the chiller off). Voltage was at 1.338 for tests.
The card belongs to a friend was visiting, so we didn't have a ton of time to test it. Its going in a system with a QX 9650 and I'll post up some benchmarks once he gets it running in that system.
Here is a 3DMark06 run on my Q6600:
VETDRMS is offline   Reply With Quote
Old 07-09-2008, 09:38 AM   #27
JaD
JaD's Avatar
Send a message via ICQ to JaD Send a message via MSN to JaD Send a message via Skype™ to JaD
What you are missing is that core and shader clocks are related even in unlinked mode.
You can't set the core over certain frequencies if you don't clock the shaders higher aswell: when the shaders are at 1458, max core frequency will be 712; at 1512, the core will top at 748 etc.
That is caused by the different core/shader ration GTX series have, which is different than 8800's.
I've heard there are people who are trying to change that ratio through the bios but don't know the details.
About software voltage adjustments, considering the same Volterra chip is being used I really hope W1zzard can sort it out like he did with ATItool for 2900s.
Looking forward for the ATITool substitute he's been talking about
JaD is offline   Reply With Quote
Old 07-09-2008, 10:40 AM   #28
HitandRun
HitandRun's Avatar
Send a message via AIM to HitandRun
Results:
Nice read my friend!
HitandRun is offline   Reply With Quote
Old 07-09-2008, 12:46 PM   #29
VETDRMS
Thanks JaD, I am able to change the core using Nibitor, hopefully the ratio will be directly editable at some time in the future.
Old 07-09-2008, 02:21 PM   #30
seba84_2005
seba84_2005's Avatar
Send a message via MSN to seba84_2005
GTX 280 v-mod
Hej! what you have the standard voltage GPU?
__________________
i7 920 D0 4.2GHz 24/7 | ASUS Rampage II Extreme | EVGA GTX 280 with SLI + XFX 9800GT for Physx | Corsair Dominator 3x2GB 1600MHz | WD 640GB AALS Black | ASUS Xonar D2/PM | Antec Signature 850W | Lian Li A77B
EK Supreme HF | Bitspower Black Freezer R2E | 2 X EK-FC GTX280 Nickel & Plexi | Mips Ram Freezer Special Edition | Laing DDC 1T+ & EK plexi top v2 | EK rez 250 v2 | TC 120.3 & 120.2 | Aquaero VF + Powerbooster & Poweradjust | Bitspower all fittings
LC-Solution
seba84_2005 is offline   Reply With Quote
Old 07-09-2008, 03:15 PM   #31
speedfreak86
I am Xtreme
speedfreak86's Avatar
Has anyone flashed a GTX280 yet? I was thinking of trying to find a FTW edition bios and flash to it. Or can someone check the bios voltage settings from theirs? Mine currently has Extra set at 1.18V, the 3D set at 1.06V, and the 2D set for 1.03V.
Oh Seba84, would you attach your bios please?
__________________
Asus Maximus Formula (Rampage Conversion Bios 0403)
Q6600 G0 stepping@4.05 Ghz
8GB G. Skill 1066 @ 1081 Mhz
EVGA 280 GTX
Auzentech Prelude
2X 74 GB WD Raptors in Raid 0 Windows 7 Ultimate 64
2X 1 TB WD Caviar Blacks in Raid 0 Vista Ultimate x64
Thermaltake Toughpower 1200W
DTek Fuzion V2 in a custom CPU only water loop
Coolermaster Stacker 830
Hanns-G 28" widescreen
Klipsh Pro-Media 2.1
G15 Keyboard and G9 Laser Mouse
speedfreak86 is offline   Reply With Quote
Old 07-09-2008, 05:11 PM   #32
rodman
Nice 06 scores, wow over 20k on a single gpu, ATI can't touch that Currently i'm waiting for a Koolance waterblock along with a Exos 2-LS to see if I can push my card anymore for stable gaming use. I have a DD Tieton on a Koolance Exos 1 running 1/4 in tubing so I imagine the results will improve with the new block (thinking the backplate and actual block quality will help) and Exos 2-LS. Right now load temps hit 63c and I still manage clocks of 756/1512/2650 rock solid stable. I'm hoping to be able to raise the shaders higher as 1600 is stable till it heats up past 50c like you mentioned. This would allow me to go for 800/1600/2700 however I'm not sure, esp with no voltage adj.
About the votage adj. Did you adjust them all with a bios flash or hard mod? Does anyone know if Voltage adj will be available though a driver level like ATI? I mean Nvidia's own performance tab shows GPU and Memory voltage and drop down tabs for adjustmants yet they are greyed out.
Any additional info would be great
__________________
I7 920@4ghz
EVGA Classified X58
6GB Corsiar 1600
2X GTX 285@756/1550/2700
Corsiar 1000WT
ASUS 25.5 LCD/58"Plasma TH-58PZ800U
Custom H2O cooling
Oh, thats a pic of my other rig.
rodman is offline   Reply With Quote
Old 07-09-2008, 06:53 PM   #33
seba84_2005
bios from the version FTW anything does not differ, there is also extra 1.18v 3D 1.06v and 2D 1.03v
write You to me on priv this give link to bios from FTW
I have flash bios from the version HC
my PC: GTX 280 & water block from Aquacomputer GTX 280
__________________
LC-Solution
Old 07-10-2008, 07:47 PM   #34
rodman
[quote=seba84_2005;3128532]bios from the version FTW anything does not differ, there is also extra 1.18v 3D 1.06v and 2D 1.03v
Say what, lol. Are you saying the bios from the FTW has increased voltages? The engineers from EVGA said that they do not add voltage to any cards they sell.
What are you using to flash the bios? Nitbitor?
__________________
I7 920@4ghz
EVGA Classified X58
6GB Corsiar 1600
Corsiar 1000WT
Custom H2O cooling
Old 07-12-2008, 04:59 PM   #35
Renegade5399
Renegade5399's Avatar
Send a message via AIM to Renegade5399 Send a message via MSN to Renegade5399
No, he said the voltages are the same. And that if you want the FTW BIOS, send him a PM.
Now the pics of his rig are just flat out sex. VERY clean, I like very much.
Now, will the GTX 280 mods work on the 260?
__________________
Intel i7 Xeon 3520 @ 4.41GHz (210*21) @ 1.326v
DFI T3eH8 w/ beta BIOS (4/28)
6GB Kingston HyperX DDR3 2000 @ 1680MHz 7-7-7-18-1T @ 1.66v *RMA*
XFX 5870 at 1100/1300 with 1.32v
Loop 1: Apogee GTZ CPU block, Enzotech NB block, MCR360 rad w/ Scythe fans, Micro-res, Aquaextreme 50Z pump
Loop 2: EK-FC5870 block, MCR240 rad w/ Yate Loon fans, T-line, MCR650 pump
U2-UFO case
Renegade5399 is offline   Reply With Quote
Old 07-17-2008, 12:49 PM   #36
Orion24
Orion24's Avatar
Finished my GTX 280 v-mod yesterday, but my water pump is malfunctioning and the water flow is very poor, making me unable to test the overclock before I change it. At least I was happy to find a VGPU measure point on the top of the card, cause I couldn't use those shown at vr-zone as I had already placed the waterblock.
BTW VETDRMS, I'm starting to worry about power consumption. In practice the stock GTX 280 eats approximately 200W under load according to intel from reviews. At 1.338V and 826 MHz core it should require about 75% more, hitting 350W while its power inputs are rated at 300W. I hope my Enermax 1KW Galaxy is capable of feeding a lot more than the rated 75 & 150W for the 6 and 8 pin outputs.
__________________
CPU: Core i7 920 D0 @3.8 GHz 19x200 1.175Vcore, 1,46V QPI/VTT
Cooling: Zalman CPNS9900 (things about phase)
Mainboard: Giga-Byte X58-UD7
RAM: 12 GB Corsair 1600 CMD12GX3M6A1600C8
Video Card: EVGA GeForce GTX 280 713/1428/1350
PSU: Enermax 1KW Galaxy
Storage: Intel X25-M G2 160GB, 2x300GB VRaptors RAID-0, 2x750GB WD RE2 RAID-0
Orion24 is offline   Reply With Quote
Old 07-21-2008, 06:49 AM   #37
s e t h
Champion
s e t h's Avatar
anyone seen a vmem mod for these cards?
s e t h is offline   Reply With Quote
Old 07-21-2008, 07:42 AM   #38
古強者死神
古強者死神's Avatar
Saw the 4.2ghz q6600 and was like WoW... then say the nearly 1.7v Vcore and was like... omg nvm lol.
The GTX280 is a good card and yes it is the most powerfull single card out there but Price vs Performance is where its at IMO. I grabed two 4850's for $150 each and am stuck at 19,400 3dmark06 right now being held back by my cpu because I cant break 3.7ghz on my quad, but im all air cooled and no volt mods :P
So curious what would your score be with your q6600 @ 3.8ghz? I wonder if it would be equal to mine. I assume slightly better since dual cards should use more cpu overhead.
__________________
Specs: Q6600 @ 3.65ghz 1.42v / Asus P5Q Deluxe / 2x2gb Mushkin DDR2@810 / PC P&C 750w / 2x ATI 4850 Crossfire @ 710/1050
古強者死神 is offline   Reply With Quote
Old 07-23-2008, 01:33 AM   #39
Orion24
Orion24's Avatar
OK, now I finalised my testing and I am not particularly pleased with the results, but here goes:
Maximum overclock: (stock voltage/v-modded voltage)
Core: 713 --> 771 (+8.13%)
Shader: 1458 --> 1566 (+7.4%)
Memory: 1377 (no v-mem mod)
I couldn't get the shader 100% stable at 1620 no matter what. 1566 is stable at 1.25V and I went up all the way to 1.42 as an attempt to get 1620 stable and still no go. In fact the more I kept increasing the voltage, the earlier the tearing/artifacting seemed to occur (load temps mid to high 60s). Another note is that I never had a core overclock instability, since setting the clocks with rivatuner I was unable to set higher core clocks with the givven low shader clock overclockability. If flashing the BIOS gets around the core/shader 1/2 limitation, I'll give it a shot.
Looks like yield problems are important for the GT200 chips. G92s can do 2.0 GHz shader with 1.1-1.15V and I need 1.25V to stabilize this at 1.56 GHz. It has so many more SPs, but no more than ~40% more shader performance in practice due to these yields.
** update **
It seems that at 1.30V the card artifacts when the core temperature exceeds 75 Celcious degrees (this is not the case at stock voltage). In fact, I wonder where the temperature sensor is located. If the temperature sensor doesn't read the read die temperature, then I must calculate that for a givven temperature reading, the actual die temperature is a lot higher when higher voltages are used. Maybe 1620 MHz was inevitable because of cooling issues after all. I'm having a hard time controlling the temperature of this thing with the weather here at 35 - 45 Celcious degrees; I'll only know in the winter how much of a bottleneck the temperature is.
__________________
Old 07-29-2008, 05:57 PM   #40
rodman
Does anyone know if Nitbitor can set voltage and have it stick on the G200? I would like to play around with some voltage adj and OCing but do not want to hard mod the card. For one i can't solder for crap and 2 it does not seem like volt mods help at all unless you have extreme cooling solution. That was how Fugger managed such high OCs on no volt mod. It seems like it's best to put your money into better cooling and not volt mods.
I still would like to be able to set and test out some volts and OCs myself though
__________________
I7 920@4ghz
EVGA Classified X58
6GB Corsiar 1600
Corsiar 1000WT
Custom H2O cooling
Old 07-30-2008, 07:58 AM   #41
Renegade5399
BIOS volt modding is not an option with most current nvidia cards.
__________________
U2-UFO case
Old 07-30-2008, 07:58 AM   #42
kemist
Is the vmod the same for the GTX260, they appeared to be the same pcb, but wondering if anything such as trimmer resistance should be changed.
kemist is offline   Reply With Quote
Old 07-30-2008, 08:26 AM   #43
Justifire
Justifire's Avatar
** update **
What cooling do you use?
The stock air-cooler ?
__________________
QX9650 @ 4450 mhz
Asus Striker II Extreme 790i
4 GB Corsair Dominator 1800 @ 1870 8-8-8-20 1T 1.8v
3 x Asus GTX280 TRI-SLI 810/1647/1296
Asus Xonar DX
Thermaltake Toughpower 1500 W
Dell 30" 3007WFP
Logitech G7, G15, G25
Watercooling Hailea 1500 chiller, EK, Swiftech, D-Tek
Dual Prometeia site
Justifire is offline   Reply With Quote
Old 07-30-2008, 06:45 PM   #44
Orion24
Orion24's Avatar
Watercooling with an EK waterblock and my old crappy Thermaltake BigWater 745 installation (changed the water pump to a more powerful 500l/h one). The video card is cooled third (CPU --> NB --> GPU).
The water temperature is about 45 Celcious degrees by the time it enters the EK waterblock. I can't do much about it in the middle of the summer. We do have an A/C in the house but it is too far away from the PC.
__________________
Old 08-09-2008, 03:29 PM   #45
Justifire
Justifire's Avatar
Get yourself a waterchiller
__________________
QX9650 @ 4450 mhz
Asus Xonar DX
Dell 30" 3007WFP
Dual Prometeia site
Old 08-09-2008, 04:15 PM   #46
largon
Xtreme Guru
largon's Avatar
G200 overclocking & modding isn't too popular on XS?
There's just couple thousand views and few people with the cards discussing.
__________________
You were not supposed to see this.
largon is offline   Reply With Quote
Old 08-09-2008, 05:21 PM   #47
rodman
It's becouse volt mods do not help and for the most part can hinder performance. The best thing to do for a G200 is get it as cool as you can with a quality water block like the DD Tieton and use a killer water cooling solution along with it. Basicly, the cooler the core, the higher they clock
__________________
I7 920@4ghz
EVGA Classified X58
6GB Corsiar 1600
Corsiar 1000WT
Custom H2O cooling
Old 08-12-2008, 02:49 PM   #48
kemist
Yea i did vmod on gtx260 and it seemed to make things worse rather than help... Unsoldered it a few days later.
This was on water too btw.
Old 08-13-2008, 12:38 PM   #49
NST6563
Will it at least help on the memory?
__________________
Q6600 @ 3.4ghz 1.33v
Evga 680i
8800GTS 640
2gb Adata Extreme
OCZ Gamextreme 600w
NST6563 is offline   Reply With Quote
Old 08-14-2008, 04:38 AM   #50
mikeyakame
mikeyakame's Avatar
Changing VID tags in bios does nothing unless you actually change the physical voltage. Then it's a question of whether there is mapping for those voltage ranges or not. I've managed to get my memory to 2698MHz on air. I hit a wall at 2664MHz which I got around by loosening timings on Timing Set 0 in the bios. I can't remember what the original memory timings were, you have to compare an unmodified bios, but from what I can tell the default timing set used is Timing0, but be weary this is also used for boot clocks. This can be changed but I don't know if all the other timing sets are used and if so for what exactly. If there is a spare unused timing set, this could be changed to the original timing values of Timing Set 0 and set as default timing set for boot clock timings. This would be the safest way to go when trying to change timing values tighter than default, or loosening them too much. I only changed tRC, tRAS, tRP. tRC as a result of changing tRAS and tRP ( tRAS + tRP = tRC )
Memory timing values could be actively changed via I2C interface I assume by flipping bits in the gpu registers realtime. I don't know very much about the registers to give any advice on this. This is really W1zzard or Unwinders playground and they may be able to shed some light on which registers hold which values, and which bits set which timings.
Heres a s/s of my bios i modified. It's an XFX XXX bios which had the most recent bios version I could find. Nibitor 4.4 also permits changes to be made to the Fan Controller registers so I configured it properly, as software control via Rivatuner is a little unpredictable it seems, and from boot to boot this way would give inconsistent results. Most likely something Nvidia has broken but I don't have enough knowledge there to say for certain why. Setting the values in bios though does work as implemented and mine works very well now. 100% fan kicks in around 57-58c, and follows the angle of tSlope from 50 -> 100 and 100 -> 50. It doesn't sound nearly as loud as default since it rises progressively and not all of a sudden.
__________________
DFI LT-X48-T2R UT CDC24 Bios | Q9550 E0 | G.Skill DDR2-1066 PK 2x2GB |
Geforce GTX 280 729/1566/2698 | Corsair HX1000 | Stacker 832 | Dell 3008WFP
mikeyakame is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
