XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme News
Reply
Old 06-16-2008, 05:21 AM   #101
MomijiTMO
Banned
Send a message via MSN to MomijiTMO
Originally Posted by savantu View Post
Isn't it a bit early ?
Umm way too early. I remember people going crazy over Penryn quads expecting crazy overclocks but it didn't happen. Speculation is just that.
MomijiTMO is offline   Reply With Quote
Old 06-16-2008, 06:53 AM   #102
Donnie27
I am Xtreme
Donnie27's Avatar
I don't know about that, I don't remember a lot of folks saying something like that? This forum isn't crazy like a few others. Most estimated it would be easier to get Dual Core to 4GHz and Quad to 3.6GHz. Even when others talked about 4GHz for Quad, most folks agreed maybe with water and extra voltage.
__________________
C2Q-9550 with Ninja 120mm Fan, Asus P5Q Pro P45 mobo, Lian Li 7B Al Case, OCZ Stealth 700W PSU, 6GB of Mushkin PC-800 RAM, Vantec Card internal reader, Sapphire Radeon 4850, X-Fi Platinum Pro with I/O Drive, Haupauge 1250 HDTV Card, 640GB WD HDD and 1TB Seagate HDD, 2 (Q&F) Samsung 22X DVD Burners LS. Beyerdynamics 770+Mic, Harmon Kardon 247 and DIYer 5.1 speakers that RAWCs! MS Ergo 4000 KB and 6000 Laser Mouse. Tri-Booted with Win64 Ultimate, Windows 7 64bit and WinXP Home 32bit. Acer 22" LCD and 19" GW VX900T CRT.
Donnie27 is offline   Reply With Quote
Old 06-16-2008, 06:07 PM   #103
virtualrain
Originally Posted by Pinacolada View Post
I'm passing Nehalem and I see no point in upgrade.
10% on single core and 20% on multicore is not enough to consider me buying new : CPU,RAM,mobo and cooling.
Penryn is good enough until cheap octalcores appear which will offer more than 100% multithreaded improvements than quadcore Penryn.
Expect the performance improvements to increase significantly once motherboards have the kinks worked out. Any application that is constrained by memory performance will benefit much more with Nehalem.
Check out how your current memory is being bottle-necked by the FSB and how Nehalem's triple-channel DDR3 IMC really opens the spill-way on RAM bandwidth...
Note that Nehalem's tri-channel DDR3-1333 peak bandwidth is on par with Penryn L2 cache! (the likes of which would never be seen on Penryn with it's highly bottlenecked FSB).
Source
virtualrain is offline   Reply With Quote
Old 06-16-2008, 06:54 PM   #104
Anemone
Perpetually learning
DDR3 1333 is pretty cheap. It's the 1800-2000 stuff that gets pricey. Even if the advanced Nehalem offers 1600, that won't be too bad for 6gb triple sticks come Q4.
Anemone is offline   Reply With Quote
Old 06-18-2008, 04:43 AM   #105
JCornell
JCornell's Avatar
2.93GHz Rev.B0
__________________
JCornell is offline   Reply With Quote
Old 06-18-2008, 04:52 AM   #106
STaRGaZeR
Xtreme Mentor
STaRGaZeR's Avatar
__________________
Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
STaRGaZeR is offline   Reply With Quote
Old 06-18-2008, 05:01 AM   #107
informal
AMD™ 10h&RV770 cruncher
informal's Avatar
Around 10% faster than Penryn @the same clock,not bad but not earth shattering.We need something else apart from useless Spi1m(wPrime ie. where multicore shines)
__________________
Quick dictionary lesson:Bulldozer : n. 1. A multi-threaded performance-oriented x86 processor core contained in the “Zambezi” processor for client PCs and “Interlagos” and “Valencia” processors for servers. Included in the “Scorpius” desktop PC platform and “Maranello,” “Adelaide,” and “San Marino” server platforms. “Bulldozer” will be a completely new, high performance architecture for the mainstream server, desktop and notebook PC markets that employs a new approach to multithreaded compute performance for achieving advanced efficiency and throughput. “Bulldozer” is designed to give AMD an exceptional CPU option for linking with GPUs in highly scalable, single-chip Accelerated Processing Unit (APU) configurations. 2.A heavy, driver-operated machine for clearing and grading land, usually having continuous treads and a broad hydraulic blade in front 3. An overbearing person; a bully.
informal is offline   Reply With Quote
Old 06-18-2008, 05:27 AM   #108
Shintai
Xtreme Cruncher
Shintai's Avatar
http://www.anandtech.com/cpuchipsets...oc.aspx?i=3326
And thats still singlechannel
__________________
Crunching for Comrades and the Common good of the People.
Shintai is offline   Reply With Quote
Old 06-18-2008, 05:28 AM   #109
Hornet331
Xtreme Mentor
Hornet331's Avatar
Send a message via ICQ to Hornet331
anyone can upload the pic on another image hoster, photobucket is down for me since yeaterday...
Hornet331 is online now   Reply With Quote
Old 06-18-2008, 05:30 AM   #110
Chri$ch
Chri$ch's Avatar
Chri$ch is offline   Reply With Quote
Old 06-18-2008, 05:34 AM   #111
Pinacolada
http://www.anandtech.com/cpuchipsets...oc.aspx?i=2991
"In our recent DDR3 vs. DDR2 review we discovered a 16% to 18% improvement in memory bandwidth with the P35 chipset. This translated into a 2% to 5% increase in real world performance in some computer applications.
This bandwith will be only for overpriced Bloomfield Nehalem,Nehalems in lower price will come in 2H 2009 and will have only dual channel.I expect Bloomfield setup to be 100-150% more expensive than Penryn setup (Intel will position Bloomfield as high-end system and it will cost) with performance around 10-20% single thread ,20-40% multithread.New drivers and better mobos won't help more than 1-3%.
So until you really need new computer or you are into multithreaded apps upgrade to quadcore Nehalem does make sense.Otherwise you will pay 100% more for about 10-20% improvement - not worth IMO for typical user it's much wiser to upgrade GPU or wait for cheap SSDs.
Quadcore penryn is good enough to wait till 2H 2009 for 32nm shrink where price/performance ration against Penryn will be much better.Most probably octalcores will be available then.
People are expecting marvels from Nehalem but it will be more evolution than revolution.
Pinacolada is offline   Reply With Quote
Old 06-18-2008, 05:40 AM   #112
Hornet331
Xtreme Mentor
Hornet331's Avatar
Originally Posted by Chri$ch View Post
thx mate.
Old 06-18-2008, 05:42 AM   #113
Hornet331
Xtreme Mentor
Hornet331's Avatar
how can you compare fsb to QPI/IMC ?
Old 06-18-2008, 06:04 AM   #114
informal
informal's Avatar
Shintai,Pinacolada summed it up well here:
__________________
Old 06-18-2008, 06:22 AM   #115
Donnie27
I am Xtreme
Donnie27's Avatar
So this isn't thread crapping,
Old 06-18-2008, 06:26 AM   #116
bowman
bowman's Avatar
Firstly, Bloomfield will launch in the Q9450, Q9550 and QX brackets - if you think a mainstream quad core Penryn is 'overpriced' to begin with then I guess the 2009 Lynnfield one will be too.
For me upgrading the GPU is of no use because it's an 8800GTX, it plays every single game just fine and even folds quite quickly. The GT200 is an overpriced incremental upgrade that brings nothing new to the table, just more of the same.
My CPU, on the other hand, is a 90nm AMD dual-core. Maybe it's not worth it for all your Penryn owners to upgrade, but everyone doesn't have Penryn.
bowman is offline   Reply With Quote
Old 06-18-2008, 06:27 AM   #117
informal
informal's Avatar
Hmm i quote another user's opinion(which btw is realistic),i don't call out any1 and you call that thread crapping?Get a grip man.I thought the Fugger's post was enough,seems not
I agree,in that case upgrade is well worth it.
__________________
Old 06-18-2008, 06:37 AM   #118
Donnie27
I am Xtreme
Donnie27's Avatar
Sorry, talking about overpriced without a price list, trying to downplay performance with only estimations, ummm, sounds like crapping to me!
Old 06-18-2008, 06:42 AM   #119
informal
informal's Avatar
It was a quote from another user.Get it?!This is so amusing.
__________________
Old 06-18-2008, 07:01 AM   #120
savantu
Originally Posted by JCornell View Post
2.93GHz Rev.B0
Please post some memory scores.
__________________
Originally Posted by cupholder2.0 View Post
For 3 years AMD beat Intel, all it did was made Intel get a bloody nose. In one year, AMD ended up in the intensive care unit.
K10=K5x2
savantu is offline   Reply With Quote
Old 06-18-2008, 07:08 AM   #121
Hornet331
Xtreme Mentor
Hornet331's Avatar
i second that, maybe some everest scores?
__________________
Old 06-18-2008, 07:19 AM   #122
Donnie27
I am Xtreme
Donnie27's Avatar
Yes you are amusing LOL!
Old 06-18-2008, 07:21 AM   #123
Donnie27
I am Xtreme
Donnie27's Avatar
I'd like to see them as well.
But we'll still run into a problem. Unless the user is stressing the system, most of the time Bandwidth isn't a bottleneck now.
Old 06-18-2008, 08:54 AM   #124
JCornell
JCornell's Avatar
Can't run everest, it crash while click the everest.exe
I did run CINEBENCH R10 : Rendering (xCPU)
__________________
Old 06-18-2008, 09:01 AM   #125
Hornet331
Xtreme Mentor
Hornet331's Avatar
damn would have been to good.
same with sisoft sandra?
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
