Gigabyte X58A-UD3R | i7 930 @ 4 GHz | Corsair H50
G.Skill RipJaws 4x2 GB @ DDR3-1600 7-7-6-24-1N | HIS Radeon HD 5870
3x Intel X25-M 80 GB RAID-0; OCZ Agility 120 GB | Samsung SH-S243D
Corsair HX1000 | Dell 3007WFP & Samsung 204T | 7 Ultimate x64
1:1 is stuck to pretty high PL, it's better to use other dividers...
I did the testing a few pages before will sum it up again :
400FSB and Ram at 800Mhz -- Bios sets 13 perf level at AUTO setting -- Lowest manual is 9 (8 doesn't post)
400FSB and Ram at 1003Mhz -- Bios sets 10 perf level at AUTO setting -- Lowest manual is 7
400FSB and Ram at 1066Mhz -- Bios sets 9 perf level at AUTO setting -- Lowest manual is 7
450FSB and Ram at 900Mhz -- Bios sets 13 perf level at AUTO setting -- Lowest manual is 10
450FSB and Ram at 1081Mhz -- Bios sets 10 perf level at AUTO setting -- Lowest manual is 8
500FSB and Ram at 1200Mhz -- Bios sets 13 Perf level at AUTO setting -- Lowest manual is 10
600FSB and ram at 1200Mhz -- Bios sets 13 perf level at AUTO setting -- Lowest manual is 11 (though RAM not stable at all)
At the moment this board needs some higher PL than P35 and X38/48 to remain stable... Don't forget the board is only a few weeks old and future biosses will hopefully bring some more performance and ram compatability...
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro Asus Saaya yupp, I agree
I went ahead and ran prime blend over night while I was at work using the following settings:
CPU Ratio: 7.0
FSB: 425MHz
PCI-e: 101
FSB Strap: 400
DRAM Freq: DDR2-1133MHz
5-5-5-15-3-40 (The rest AUTO)
DRAM Static Rd: Enabled
DRAM Rd Training: AUTO
Mem OC Charger: Auto
Ai Clock Twister: Moderate
Performance Lvl: 7
Pull-ins: Disabled
CPU Voltage: Auto
CPU GTL (0/2): 0.63
CPU GTL (1/3): 0.63
CPU PLL: 1.50V
FSB Term: 1.16V
DRAM Voltage: 2.14V
NB Voltage: 1.26V
NB GTL: 0.67
SB Voltage: 1.10V
PCIE SATA: 1.50V
Load Line: Auto
NB/CPU Clock Skew: Auto
and it passed 12 hours and was still running until I turned it off. I am terribly confused because in order for me to do the same with my Maximus Formula it took an nbv of 1.58-1.61V while here it only takes 1.26V? Huh.... I understand that the NB is now 65nm and that they also added better power regulation to the P45 but I wasn't expecting this much of a gain. Huh, again...
So I went ahead and shut the computer down for about 30 minutes and then rebooted, entered BIOS, exited BIOS and there was no issues whatsoever. It seems to be stable but as soon as I try 1.30V it fails to boot as well as at 1.34V. Huh again, I guess.....All is well
QX 9650 | Maximus II Formula | G.SKILL 4GB (2 x 2GB) PC2 8500 | Sapphire 4850 X2 2GB| Auzen X-Fi Prelude 7.1 | 3x's WD 150GB Raptors & 2x's 1TB Seagate 7200.11 | Silverstone OP1200 | SilverStone TJ07 | Dell 2707WFP
EK-RES 250 --> Swiftech MCP655 --> Apogee GTZ --> Enzotech Sapphire NB --> Feser X-Changer 360
I've reached the same conclusion, 1:1 only brings trouble, best to stick to other divider when possible.
In my setup I can use PL 8 with those settings and 1.16vNB as I said before. Here's my settings:
JumperFree Configuration Settings
AI Overclock tuner: manual
CPU Ratio Setting: 9
FSB Strap to North Bridge: Auto
FSB Frequency: 500
PCI-E Frequency: 101
DRAM Frequency: 1200
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : 5
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Read Training: Disable
MEM. OC Charger: Enable
AI Clock Twister: AUTO
AI Transaction Booster: Manual
Common Performance Level [8]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.44375
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.5
FSB Termination Voltage: 1.1
DRAM Voltage: 2.1
NB Voltage: 1.16
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Auto
NB Clock Skew : Auto
Advance CPU Setting
CPU Ratio Setting: Auto
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Sinner can you run Everest cache and memory benchmark at those settings please?
Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
Thanks That'll probably be my exact configuration when the board and the OCZ arrive here. Damn you have pretty good BW over there
Could those of you who have already received their P5Q Deluxe please post their revision (and possibly, if their board was made in China or in Taiwan)?
So far, I'm only aware of 1.03G, maybe there are others?
It would be great if this information could also be put into the first post, to makle this thread a proper resource of information...
HI again ppl
http://valid.x86-secret.com/show_oc.php?id=375799
Regards
San Diego 3700+ @3171.96MHz / Opteron 148 @3363.3MHz / Q6600 G0 @4503.05MHz / E6700 @4701.35MHz / E6850 @4814.91MHz / Conroe E6600 @4911.04 MHz / E8500 @5516.74MHz
max FSB
http://valid.x86-secret.com/show_oc.php?id=375559
and 600FSB 1:1 (PL10) Everest cache and memory benchmark
anyone here with the P5Q3-Deluxe? I'm looking at one, and can pick it up today with some cheap, but nice Patriot DDR31333 7/7/718.
GB 790XTA UD4
GSkill Pi Black 2000 Cas9
ASUS 4870
Enermax Revolution 1050+
http://www.heatware.com/eval.php?id=67661
Code:JumperFree Configuration Settings AI Overclock tuner: manual CPU Ratio Setting: x FSB Strap to North Bridge: Auto FSB Frequency: 600 PCI-E Frequency: 101 DRAM Frequency: 1200 DRAM CLK Skew on Channel A1: AUTO DRAM CLK Skew on Channel A2: AUTO DRAM CLK Skew on Channel B1: AUTO DRAM CLK Skew on Channel B2: AUTO DRAM Timing Control: Manual 1st Information : CAS# Latency: 5 DRAM RAS# to CAS# Delay: 5 DRAM RAS# Precharge: 5 DRAM RAS# Activate to Precharge: 15 RAS# to RAS# Delay : 5 Row Refresh Cycle Time: AUTO Write Recovery Time: 45 Read to Precharge Time: AUTO 2nd Information : READ to WRITE Delay (S/D): AUTO Write to Read Delay (S): AUTO WRITE to READ Delay (D): AUTO READ to READ Delay (S): AUTO READ to READ Delay (D): AUTO WRITE to WRITE Delay (S): AUTO WRITE to WRITE Delay (D): AUTO 3rd Information : WRITE to PRE Delay: AUTO READ to PRE Delay: AUTO PRE to PRE Delay: AUTO ALL PRE to ACT Delay: AUTO ALL PRE to REF Delay: AUTO DRAM Static Read Control: Disabled DRAM Read Training: Disable MEM. OC Charger: Enable AI Clock Twister: AUTO AI Transaction Booster: Manual Common Performance Level [10] Pull-In of CHA PH1: DISABLED Pull-In of CHA PH2: DISABLED Pull-In of CHA PH3: DISABLED Pull-In of CHA PH4: DISABLED Pull-In of CHB PH1: DISABLED Pull-In of CHB PH2: DISABLED Pull-In of CHB PH3: DISABLED Pull-In of CHB PH4: DISABLED CPU Voltage: 1.xx CPU GTL Voltage Reference (0/2): 0.63 CPU GTL Voltage Reference (1/3): 0.63 CPU PLL Voltage: 1.52 FSB Termination Voltage: 1.26 DRAM Voltage: 2.42 NB Voltage: 1.52 NB GTL Reference: 0.55 SBridge Voltage: 1.10 PCIE SATA Voltage: 1.50 Load Line Calibration: Enabled CPU Spread Spectrum: Disabled PCIE Spread Spectrum: Disabled CPU Clock Skew : delay 400ps NB Clock Skew : delay 200ps
try lower Performance Level (12 or 13) and play with CPU / NB GTLs, i think it is different at each system
anyone found any good, easily accessible voltage read points for these boards?
i950 (3035B684)
Gigabyte EX58A-UD3R
3x4GB G.Skill PC3-12800 7-8-7-24
HIS Radeon HD 6970 2GB & Dell 3007WFP-HC
Asus Xonar DX
128GB C300, Velociraptor & Sammy F3's
Corsair AX850W
Windows 7 Ultimate x64 SP1
Source Awardfabrik
Maybe a small note, not directly related to the Deluxe version, but anyway.
I decided to install the P5Q-Pro (wasn't quite sure to try it or not), just to see how it would perform, specially for my X3350.
It looks like some options are left out in the bios, compared to the Deluxe version.
The following options are NOT available in the bios of the P5Q-Pro (important regarding overclocking, IMO) :
CPU GTL Reference (0/2)
CPU GTL Reference (1/3)
NB GTL Reference
NB Clock Skew
CPU Clock Skew
Kinda disappointed not having these options in the BIOS.
The good part is that I installed my X3350, which couldn't run at 450*8 on the DFI DK-P35 / 2x DFI UT-P35 (not below 1.61 NBCore on one of them anyway), with only 1.24V NBCore on the P5Q-Pro.
Rig #1
Gigabyte P67A-UD4 trying to figure out this POS board
2600k @ ?????
2x2Gb GSkill RipJaws-X 1333 (7-7-7-21)
ATI 5850
Coba Nitrox 750W
Watercooled with HK 3.0 CU, Watercool GPU-X³ 5870 Nickel, PA120.3, Laing Ultra with XSPC top
Rig #2
DFI UT P35-T2R (0317 bios)
E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
2x2Gb Chaintech Apogee GT PC2-8500
Powercolor 4870
Corsair 520HX
Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
