XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Thread Tools Rating: Thread Rating: 50 votes, 4.52 average. Display Modes
Old 06-08-2008, 10:35 PM   #226
pmp
pmp's Avatar
Some new builds to work on:
ASUS P5Q-E build 0702
ASUS P5Q Deluxe build 0702
ASUS P5Q3 Deluxe build 0702
Note that 2 new options are added, CPU and NB clock skew. Set CPU to 400 ps and NB to 100 ps to get some extra FSB (play ofc with these settings).
__________________
skulltrail | quadsli | 15K.6 | 30" | desktops are baaad!
pmp is offline   Reply With Quote
Old 06-08-2008, 11:49 PM   #227
Leeghoofd
I am Xtreme
Leeghoofd's Avatar
Thx PMP will test it today , hope to improve some rambandwith here
EDIT : For my QX quad all seems to be the same... will have to try the wolfies soon... only thing I noticed is that Static Read Contol can remain on auto, while I had to disable it before to get it to post... latency on the ram is still the same and performance level manual set too...
This board is moving fast, good job PMP...will this be the new Commando ? So nice 400FSB/1066Mhz out of the box with minimum voltage settings...8Gb of ram and a Quad
Kind regards Albrecht
__________________
Question : Why do some overclockers switch into d*ckmode when money is involved
Leeghoofd is offline   Reply With Quote
Old 06-09-2008, 12:58 AM   #228
Chri$ch
Chri$ch's Avatar
Thx for Bios 0702, got ~20Mhz more FSB (CPU 200ps / NB 100ps)
http://valid.x86-secret.com/show_oc.php?id=372923
Edit:
http://valid.x86-secret.com/show_oc.php?id=372927
Chri$ch is offline   Reply With Quote
Old 06-09-2008, 01:24 AM   #229
AMD_Freak
AMD_Freak's Avatar
very nice Chri$ch keep up the great work, what kind of cooling are you using LN2 ?
__________________
OS: Vista 64
CPU: AMD Athlon X2 7750@3.4ghz/PHII x4 955@3.8ghz
CPU Cooler:XIGMATEK HDT-S1283
Motherboard: ASUS M4A79 Deluxe
GPU: XFX Radeon HD 4850 XXX
Memory: Mushkin 4GB XP2-8500
Hard Drive: Western Digital Caviar Black x 2
Optical Drive: SAMSUNG 22X DVD Burner
Power Supply: XIGMATEK 650w
Display: Hanns-G 22"wide (1680 x 1050)
Case: rocketfish TribalFish Pic
AMD_Freak is offline   Reply With Quote
Old 06-09-2008, 01:27 AM   #230
@rne
Team AF
@rne's Avatar
Great, Thank you VERY much
And i think that the process of saving and loading the settings of the profiles works much faster since the first alpha you provided us.
@rne is offline   Reply With Quote
Old 06-09-2008, 01:35 AM   #231
Chri$ch
Chri$ch's Avatar
water
Old 06-09-2008, 01:58 AM   #232
Jupiler
Administrator
Jupiler's Avatar
Originally Posted by Chri$ch View Post
water
You must be glad you didn't sell the board after all.
__________________
Rig #1
Gigabyte UD3P Rev. 1.0 Bios F4
E8600 @ 4400Mhz, 1.296V
2x2Gb OCZ1066 LV Blade
BFG GTX280 OC
Coba Nitrox 750W
Watercooled with HK 3.0 CU, EK-FC280GTX, PA120.3, Laing Ultra with XSPC top
Rig #2
DFI UT P35-T2R (0317 bios)
E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
2x2Gb Chaintech Apogee GT PC2-8500
Powercolor 4870
Corsair 520HX
Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
Originally Posted by Movieman View Post
I've got Supermicro boards that lasted longer than one of my marriages!
Jupiler is offline   Reply With Quote
Old 06-09-2008, 06:17 AM   #233
@rne
Team AF
@rne's Avatar
Today i changed from boxed to big typ from thermaltake, let's see:
http://valid.x86-secret.com/show_oc.php?id=373030
There is room for more
Old 06-09-2008, 06:20 AM   #234
STaRGaZeR
Xtreme Mentor
STaRGaZeR's Avatar
Does clock skew affect perfomance or only stability and max OC?
__________________
Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
STaRGaZeR is offline   Reply With Quote
Old 06-09-2008, 07:55 AM   #235
pmp
pmp's Avatar
Hence it has to do with some internal delays, overall performance is still better due to higher FSB clock. In theory :P
__________________
Old 06-09-2008, 09:48 AM   #236
hiwa
Disposable Heroes
hiwa's Avatar
max fsb with P5Q3 deluxe Guys?
hiwa is online now   Reply With Quote
Old 06-09-2008, 10:06 AM   #237
Leeghoofd
I am Xtreme
Leeghoofd's Avatar
Haven't seen one in the shops yet... GAR is awaiting his one so he will update you asap with numbers
__________________
Old 06-09-2008, 10:15 AM   #238
hiwa
Disposable Heroes
hiwa's Avatar
waiting with anxiety my E8500 waiting for fast chip
Old 06-09-2008, 10:15 AM   #239
@rne
Team AF
@rne's Avatar
i reached 560MHz prime stable with conroe when i had it for review and with unmature bios.
If it profits of the new bios as the p5q dlx, 600mhz no prob. Without the new version i could also get only 560 with p5q dlx and conroe.
Old 06-09-2008, 10:33 AM   #240
LUCI5R
LUCI5R's Avatar
On Air (Arctic Freezer 7 Pro), and PC2-8000 (1000) 4GB - How far do you guys think I'll be able to take my Q9450? The board is being delivered tomorrow. CPU & RAM are sitting packaged & sealed in their boxes at home.
__________________
~~ ++: Primary Rig :++ ~~
» ASUS P5Q Deluxe P45 ICH10R 1600/1333MHz 16-Phase;
» Intel Core 2 Quad Q9450 Yorkfield 2.66GHz 45nm 95W Quad-Core Processor (w/ SSE4.1);
» OCZ Platinum Edition 4GB (2X2GB) 240-Pin DDR2 SDRAM 1000 (PC2 8000) Dual Channel Memory Kit;
» ASUS EAX1950PRO/HTDP/256M Radeon X1950PRO 256MB 256-bit GDDR3 PCI Express x16 HDCP CrossFire Ready;
» Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive;
» Pioneer 16X DVD±R DVD Burner With 5X DVD-RAM Read DVR-111D; Pioneer 12X DVD±R DVD Burner DVR-109
» ARCTIC COOLING Freezer 7 Pro CPU Cooler; Arctic Silver 5; 2 X 80mm Intake; 1 X 80mm Outtake; 1 X 40mm Northbridge;
» Rosewill RP550V2-D-SL 550W Power Supply;
Current OC: 3.8Ghz (475 X 8) 1:1 (DDR2-951Mhz); BIOS 1406
ASUS P5Q Deluxe Beta Bios Downloads: 0702 * 0706 * 0803 * 1406
~~ ++: 1080p/Full HD :++ ~~
» Toshiba 42" Regza LCD 1080p FullHD; 4 HDMI; PixelPure 4G; Game Mode; Dolby Digital SoundStrip;
» XBOX 360 HDMI Premium Falcon; HD-DVD Add-On; 1TB External Hard Drive (Samsung 32mb / 7200rpm) for Blu-ray/VC-1/WMV-HD Movie Playback;
» Samsung HT-Z410 5.1 Channel 5-DVD HDMI 1080p Upconverting 1,000 Watts Home Theater System;
LUCI5R is offline   Reply With Quote
Old 06-09-2008, 10:37 AM   #241
hiwa
Disposable Heroes
hiwa's Avatar
thanks
u tested P5Q3 deluxe or p5Q deluxe?
MB Model : P5Q DELUXE
NB : Intel P45 rev 02
SB : Intel 82801JR (ICH10R) rev 00
GPU Type : GeForce 6600 GT
GPU Clocks : Core 550 MHz / RAM 560 MHz
DirectX Version : 9.0c
RAM : 2048 MB DDR3 Dual Channel
RAM Speed : 618.9 MHz (1:1) @ 5-5-5-18
Slot 1 : 1024MB (PC2-6400)
Slot 1 Manufacturer : Crucial Technology
Slot 2 : 1024MB (PC2-6400)
Slot 2 Manufacturer : Crucial Technology
which one is right?
Old 06-09-2008, 11:11 AM   #242
Leeghoofd
I am Xtreme
Leeghoofd's Avatar
did you see this Arne ?
P5Q3 DLx bios 0702 !!!!!
http://strony.aster.pl/pmpcfg/PC/ASU...ELUXE-0702.rar
thanks
which one is right?
That's a bug in CPU-Z DDR3 at only 618mhz is so so... those are the P5Q Dlx results....
__________________
Old 06-09-2008, 11:25 AM   #243
@rne
Team AF
@rne's Avatar
i tested both but i haven't the p5q3 dlx anymore so i cant test the new bios.
Old 06-09-2008, 11:45 AM   #244
johnysb
johnysb's Avatar
hi guys!
Do you think it does worth selling my P5kC and buy P5Q dlx? will i see diference?
johnysb is offline   Reply With Quote
Old 06-09-2008, 11:52 AM   #245
hiwa
Disposable Heroes
hiwa's Avatar
630,40 possible with nb@ln2
Old 06-09-2008, 01:13 PM   #246
Leeghoofd
I am Xtreme
Leeghoofd's Avatar
Originally Posted by johnysb View Post
hi guys!
Depends on what you want to do... max overclocks this board seems sweet with the latest biosses, day to day use with same clocks... don't think there will be much that differencs from P35/X38/X48/P45...
PMP you have any idea if the P5Q premium version will have voltage and temp readouts for NB and SB ?
__________________
Old 06-09-2008, 01:30 PM   #247
pmp
pmp's Avatar
No.
__________________
Old 06-09-2008, 02:39 PM   #248
wideband
Originally Posted by STEvil View Post
8x 2.0 is equal to 16x 1.x.
In theory.
True, but it would appear that current highend gpus are starting to be held back under 8x 2.0. If this is the case then surely next gen cards will widen the gap
(I hope this is considered on topic )
wideband is offline   Reply With Quote
Old 06-09-2008, 03:47 PM   #249
Loser777
Loser777's Avatar
Send a message via AIM to Loser777
Originally Posted by BigJoe View Post
500FSB EVEREST memory test
Is it really DDR3 ? Everything I've read says DDR2... or is that a CPU-z bug?
__________________
MAIN RIG Revived 11/27/2009
ASUS P5Q-E
Q6600 @ 3.4GHz
1.2625v vCore
1.50v PLL (STOCK )
1.20v VTT (STOCK )
1.10v NB (STOCK )
24+ hrs P95 Stable, 20 loop Max mem Linpack stable
Loser777 is offline   Reply With Quote
Old 06-09-2008, 03:48 PM   #250
R@ptor =]]
R@ptor =]]'s Avatar
It's a bug of cpu-z....
P5q deluxe it's a ddr2
__________________
E6750 G0 @ 3.6ghz with Noctua NH-U9B/NT-H1 @ P5Q DeluXe >>>>>>>>> Pics
2x1gb crucial ballistiX tracer 800mhz @ 901mhz 5-5-5-15
Seagate 250gb sata II 7200rpm 8mb cache buffer
8800gts G92 512mb PNY @ 750/1756/2104 @ Lcd samsung 19" 932b plus
g-5 modded / speedy 2mb / dvd-rw LG h54n / Powered by Corsair VX550W
R@ptor =]] is offline   Reply With Quote
Reply
Tags
p5q-deluxe coldbug
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
