Oh man, this thing gets better and better every time I see it!
Few questions for you if you don't mind answering them.
First, is the waterblock made of pure copper or is it some kind of plated alloy? It looks amazing but I have to make sure it will run safe in my loop
On that same note, how is the contact. We have all seen the Asus Maximus Extreme and many of us have noticed that there is not nearly enough contact (or just crappy cement) between the block and the NB, which rendered all the goodness of watercooling useless. Does this waterblock perform equally to an aftermarket one say from Danger Den or EK?
Third, please tell me that auto overclocking isn't present, or at least not turned on by default.
Anyways, thanks for the pics, I am not the most accomplished overclocker, however this board looks badass enough for me to step up my game :P
wow thats looking out for the enthusiast with the benchtable no more using the mobo box. tho i can definitly forsee the near future quite a few going up for sale...
Someone mentioned this already, but it would be great to get more info on the NB waterblock.
__________________
Time is an illusion. Lunchtime, doubly so. Douglas Adams
QX9650 @ 3825mhz CoolIT FZone
2x HD3870X2 @ 845/946mhz air
Asus Maximus Formula 0907
2x2048mb OCZ Reaper 8500
2x Raptor 150G Raid0; 'Cuda 1000G
1200W Thermaltake
xFi Extreme Gamer/ Z-5500
Vista Ult. 64
Cosmos 1000
30" NEC
You can see the waterblock internals. That is pure copper you see in there. I think it does pretty good job. Power circuit and SB is cooled a bit also.
You can use whatever DDR3 memory you like, but when talking about Intel chipset, you can only use 1:2 setting or lower divider. There is no unlinked moe in these chipsets. You have take your fsb higher, if you like to use higher memory speeds. (500fsb = 1000MHz ram, 2GHz effective)
I really think that this mobo is worth every penny *Yes, I do test other motherboards aswell, so my option is not so much biased*
__________________ You are as good as your samples are! AOCC2008 WW #5, MOA2008 EU #5, GOOC2008 WW #1, GOOC2009 WW #3, MOA2009 EU #4, MOA2009 WW #4, GB TweaKing #"5" (4,10), Ditech International OC #2 / #2, ASUS ROG OC Showdown # semifinals
We all know that is the perfect mobo for Xtreme, has the touch of the best OCers, but we will have to wait to see how it does in the hands of an "average Joe".
I wonder how It will perform with locked multi processors and "normal" Air/WC systems.
But I have lot's of time to wait the reports, sadly it will take forever before it arrives in Brazil.
[ ]s
I have played six months with this motherboard and obviously I can't use LN2 24/7 This board does really well with air and water. Believe me
This might be a silly question, but what's that 32-bit raid floppy all about? Do you absolutely need it to set up raid? Does it come in a CD/DVD? Thanks (And thanks for the mobo pics - lookin' good!)
edit: i'm thinkin' it's just the floppy version of the included disc (ie and this was a silly question)?
__________________
1200W Thermaltake
Vista Ult. 64
Cosmos 1000
30" NEC
I updated third post in the first page. There is now pictures from BIOS
There is no silly questions. You answered to yourself.
Originally Posted by benniebeeker
ill take 2 please!!!
OMG this board redefines HW porn ...love the bios features, love the bundle.. love pretty much everything im seeing here
btw does this board show negative temperatures in bios...?? my foxconn mars board just refuses to do that
SF3D, any changes in dualcore 45nm overclockability in retail version compared to "prerelease" versions? Or is the sweet spot around 550fsb, just like with all the other X48 boards?
I would like to know that as well, I have E8200 capable of 650 FSB
nice review petri keep up the good work.
Thanks!
My pre release board showed only -40c, but this retail version might be different.
I will try to find some time to test Dual core. I have one E8500 that is cabable of doing 610 fsb on air (on a different mobo)
I know the pre release board didn't have that cooler on the NB, but do you know if any of the guys have tried the retail cooler with LN2 ?
I'd like to know how they got on with insulating it, doesn't seem to be much room around the 3 points in red.
I have one of the ES board with a ES NB and it was super easy to insulate. You just gotta cut around those areas and then insulate around the block itself.
__________________
Originally Posted by 3oh6
damn you guys...am i in a three way and didn't know it again
Originally Posted by Brian y.
Im exclusively benching ECS from this point forward
On that note ... I'm looking at what I think are the (blue) hdd/sata power outlets
I think there's a good chance my lower GPU will be sitting right on top of them. I guess that's where those "L" sata cable connectors come in. I'm not familiar with the "L" shape connectors, but unless they plug into the mobo in both directions, I'm not sure I could fit more than 3 of 'em in under this big gpu? (Which is ok now, but I'm thinkin' of getting a 4th HDD.) Do those cables "go both ways" like that?
Cheers,
__________________
1200W Thermaltake
Vista Ult. 64
Cosmos 1000
30" NEC
