04-09-2008, 02:43 PM
#1
ECS 8800GT Vgpu mod?
Hello everyone,
sorry if this has been asked before, but I didn't find anything during my search.
I am looking for a voltage mod for ECS 8800GT w/ factory equipped Arctic Cooling S1 HS which has non-reference layout.
Pictures of the card can be found here at the review by xbitlabs: http://www.xbitlabs.com/articles/vid...12mx-dt_2.html
(That voltage chip is a RT8802A)
I tried the bios-mod to 1,1V already but it didn't give me any improvement in overclocking, I'm stuck at around 720mhz for the core. Temps are no higher than 45C load with a 120mm fan.
I tried to measure some suspicious looking points with DMM, recording 1,07V idle and 1,09V load for vgpu (after flashing altered bios). This makes me think that the bios-mod might not work on this card.
Any help would be greatly appreciated, I may post a more detailed picture if needed, thanks.
__________________
Abit IP35-E Bios 18 ~ E8400 400x9 tRD 5 ~ 2x1GB Mushkin XP2-9200 @ 1000MHz 4-4-4-12 ~ Elitegroup 8800GT ~ Silverstone ST50EF-Plus ~ Xigmatek HDT-S1283
04-11-2008, 11:08 AM
#2
Would like to help you, but pics aren't working
__________________
Blaat
04-27-2008, 07:16 AM
#3
04-28-2008, 07:54 PM
#4
Yes that's exactly the layout that my card has.
I suppose VGPU mod is the same as seen on some other non-reference card (Gainward or something) which has the same RT8802A controller chip.
Which means soldering a 100K VR between Pin 4 (FB) and GND.
I remember there was a picture on a russian forum, but I cannot retrieve the link
Haven't done the mod yet though.
__________________
05-27-2008, 01:03 PM
#5
I´m have the same card...
You managed to do the vmod?
where is the point to solder the VR? (please, show it at the picture)
05-27-2008, 03:37 PM
#6
-110c club
make sure you use 100k Vr i did not see this tread and try'd 1k-20k and they puts the card in ovp
the red dots are both connected and where i put my connection
http://www.xtremesystems.org/forums/...postcount=1044
05-28-2008, 05:18 AM
#7
Originally Posted by EvoCarlos
Wow!!! Nice...
so, i need to use a 100K VR...
How max overclock you achieved and what the voltage?
05-28-2008, 05:20 AM
#8
Another question...
Where is the GND point to solder the other VR point?
05-28-2008, 11:17 AM
#9
-110c club
i just used the screw pad on the corner (here)
as for overclocking well i did not want to push it at 1st so i went to 1.23v noload and 1.25v load but was unsucsessful any clock i give it the driver just bottemd out so had a play with the volts @1.30 noload and its running fine temps are below 50c w/c tho
core/shader/mem = 780/2000/950mhz
was playing assassins creed for about 5hours last nite full settings and no problems
still working on the clocks tho will push for some more mhz when i have time
05-28-2008, 06:44 PM
#11
Nice results!
Here is my best overclock with my ECS 8800GT without vmod, but it's not stable.
She is stable with 741 core - 1805 shader - 2200 mem
I do vmod but I am afraid, couse i lost a EVGA GF8800 320MB doing this ...  I have sucess in vmod, but wen i tried to remove it the card dont work again...
Here the results with EVGA 8800GTS 320
Now this baby is DIE
I think I will try anyway with the 8800gt
05-30-2008, 09:52 AM
#12
I made the vmod.
I used a 20K VR what gave me 1.19v set up at maximum resistance at full load.
I achieve 801 Core - 1912 shaders - 1150 mem... but I could not raise my score in 3dmark 2006. I believe that my E2160 is bottlenecking even at 3.5 ghz...
I want to change my cpu, what do you suggest? Q6600 or E8400 ?
Thanks for help
05-30-2008, 10:09 AM
#13
E8400 @4000
__________________
PC: Nox HX, E8500 E0 @ 4300 24/7 @ true 120 extreme, DFI LANPARTY DK P45-T2RS/TURBO,
Asus GTX260(216SP), Nox Apex 700W, Raid 0 @ Seagate sp 250gb @ 9.5ms 150mbs leitura, kingston 2x2 8500 hyperx, X-FI Titanium,
MGE STATION 800VA, LG M227WD Tv FULL HD, G5 refresh, WAVE, G25
05-30-2008, 07:28 PM
#14
-110c club
^^ what he said i have the q6600 and its a pain in the ass to get stable @4ghz even with my vapo but i think its down to my mobo more volts me thinks lol
im up to 1.3v on the core with 800/2000/995 stable so far if i go any higher with the mem the driver crashs lots so just trying to find some info the mem in the other 8800gt thread lol
05-31-2008, 10:39 AM
#15
my memories come to 1178Mhz, but are stable with 1100Mhz...
you read something about the qmonda memories? They say that these chips are burning over 1000Mhz if work for a long time ... I do not know if I believe it ..
05-31-2008, 11:13 AM
#16
-110c club
yeah i hurd about the mem buring over 1000mhz but i thought that was the samsung chips i may be wrong i've run mine at 1040mhz since the day i got the cards had no problems but now with volt mod it dont like that clock
also beat my personal best today on 3dmark06 finally got the cpu to 4.05ghz stable
did a run with the gfx cards @ 790/2000/990mhz @ 1.31v loaded
19429 marks
http://service.futuremark.com/compare?3dm06=6937298
im pushing for the 20,000 mark then im happy lol
06-02-2008, 04:22 AM
#17
 You runing like the 9800GX2
I believe in taking a q6600 ... that I will put it to at least 3.8 with my GA-P35-DS3? My cooler is a ICEcube Super Flower + thermal compound AS-5
Or i take a q9450?
06-03-2008, 12:41 PM
#18
-110c club
cheers im glad i got these 2 ECS8800gt in sli like you say its almost like having a gx2 but filling 2 pci-x slots lol
well i got my cpu up and stable at 4.4ghz but there seams to be a bottle neck some where and i not sure what it is did a run on 3dmark06 and the score was in the 18000 so dont no if -40c to the cpu is good or not but it helps with 4.4ghz 83% overclovk on cpu ha ha i love it
http://valid.x86-secret.com/show_oc.php?id=369851
06-03-2008, 02:00 PM
#19
when I put my cpu to 3.6ghz (100% overclock) my cpu score in 3d mark 2006fall of 3030pts to 2500pts...
I believe it is the CPU temp. It exceeds 75°C.
Tomorrow comes my Q6600 ... I look forward to See how many points I will win ...
06-06-2008, 10:26 AM
#20
did the vmod today, finally.
adjusting the VR (100K) turned out to be tricky, at first almost nothing happens with the vgpu, but then all of a sudden if you tune it another notch the voltage soars up  OVP kicked in twice before I could figure it out
so I set it to 1.29v idle, 1.305v load and 803mhz gpu clock because that means just over 2000mhz shader clock
Here is a screenshot from 3Dmark06, but the score seems pretty low ?!
I don't have much experience with 3D06, but I scored only 1,000pts less with an E2160 and without vmodding the vga.... hmmmmmm
EvoCarlos very nice results with SLI cards
pedrovicz you could try to remove the heatspreader from your E2160 and direct cool the chip to improve temperatures. I have a E2160 too and done it  But it's quite dangerous, I once killed a E2180 when I first tried it
Oh, and btw my E8400 sucks. Needs like 1.4v+ for 4Ghz.
__________________
06-09-2008, 04:31 PM
#21
-110c club
06-11-2008, 06:01 PM
#22
Here is my new results... with my new CPU...
Q6600 @ 3.8Ghz
2 x 1Gb ddr2 1066 Samsung 5-5-5-15
ECS 8800GT - 850 Core - 2075 Shaders - 1150 Mem (2300)
It´s nice ?
09-13-2008, 02:05 PM
#23
good
850mhz core / 2075mhz shader, which voltage ??
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
