Did this one live?
thats a big core
Looks like its only soldered at core, no soldering or glueing in the pcb.
The silvered core says everything
Nice photos Cooper!
Kinda sad it is soldered, but good lapping will give similar results so this is not end of the world.
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55'' Samsung LED 3D TV
i dont think soldering is of high quality as shown in KTE's photo
E8400 E0 @ 4.00 GHZ, DFI P45 T2RS+, 4X2GB Mushkin 1066 996599, Radeon 4890 , Enermax Liberty 620W , 4X500GB HDD+Samsung SLC 64gb SSD.
all paired with a LG 245WP
So it's impossible to take it away?
How did you do, cooper, to have a so clean work?
i used a pci cover bracket from cheap foil made case to cut the rubber
Actually the gap between HS and the CPU package is bigger then that X2.
then i just used the blowtorch on the heatspreader while keeping it face down and it fel off after 30-40 seconds. rest of solder removed with credit card.
Did it live?
1. ASUS Sabertooth 990fx | FX 8320 || 2. DFI DK 790FXB-M3H5 | X4 810
8GB Samsung 30nm DDR3-2000 9-10-10-28 || 4GB PSC DDR3-1333 6-7-6-21
Corsair TX750W | Sapphire 6970 2GB || BeQuiet PurePower 450w | HD 4850
EK Supreme | AC aquagratix | Laing Pro | MoRa 2 || Aircooled
lol do you guys really think the cpu survived? To fuse the solder the temperature needed is about 300°C.No way it survived.
Please, do not mind the temperature I said before...I think the solder used in cpus have a different thermal fusion as its proprieties.I think to unsolder its above 100ºC , but to sold it to the cpu the temperature may be lower.
Would it be feasible to sand the IHS all the way down, rather than trying to desolder it?
CPU was dead in the first place. I ain't crazy enough to conduct such experiments on working one
Actually since the HS is soldered onto I see no point of removing it either lapping it to the bare minimum. Just get a better cooling
Has anybody been successful in getting the IHS off a Phenom, or K8 chip that was soldered on?
I'd be tempted to try it with my 6000+ (ADX), but only if I'm sure it could work.
yes, that is really easy
i have "decapped" 2 Phenoms right now (9600BE / 9850BE) and booth are workin fine.
what i have done is:
1. Cut the Silicon between CPU/HS with a razorblade (make sure that you not cut to to deep into - i used 6mm from the outer border of the CPU - 5mm if you measure from the border of the HS).
2. Insert 2 Cutterblades between CPU/HS (also not to deep into, but so that there is a little bit tension (don't know the correct English word) between CPU/HS)
3. Put this onto 2 or more stands - so that the CPU is free and will fall down when the tinsolder melts
4. Transform yourself into a Firedevil and heat the HS up, i personaly use a Gas soldering iron, other's prefer a handleiron ("Bügeleisen").
(there are different Ways to do this)
sorry for the bad (english) description .....
regards
Trynity
it's shame that you didn't do a photo guide Trinity
Adobe is working on Flash Player support for 64-bit platforms as part of our ongoing commitment to the cross-platform compatibility of Flash Player. We expect to provide native support for 64-bit platforms in an upcoming release of Flash Player following the release of Flash Player 10.1.
Including a heartbeat reading when you did it.
i think the heartbeat was normal *g*
Unfortunaly my Digicam was not here as i have done this, but if i can get my hands on another Phenom i will make movie from the process
regards
trynity
KTE
CPU was dead before you cutoff heatspreader? Right bottom corner look like thermal damaged without thermal interface.. You can shot this place with more magnification?
Synaptic Overflow
CPU:
-Intel Core i7 920 3841A522
--CPU: 4200Mhz| Vcore: +120mV| Uncore: 3200Mhz| VTT: +100mV| Turbo: On| HT: Off
---CPU block: EK Supreme Acetal| Radiator: TCF X-Changer 480mm
Motherboard:
-Foxconn Bloodrage P06
--Blck: 200Mhz| QPI: 3600Mhz
Graphics:
-Sapphire Radeon HD 4870X2
--GPU: 750Mhz| GDDR: 900Mhz
RAM:
-3x 2GB Mushkin XP3-12800
--Mhz: 800Mhz| Vdimm: 1.65V| Timings: 7-8-7-20-1T
Storage:
-3Ware 9650SE-2LP RAID controller
--2x Western Digital 74GB Raptor RAID 0
PSU:
-Enermax Revolution 85+ 1250W
OS:
-Windows Vista Business x64
ORDERED: Sapphire HD 5970 OC
LOOKING FOR: 2x G.Skill Falcon II 128GB SSD, Windows 7
Ok Two options Ive Done,, Option One is to unsolder the 6000+.......
Oh 50% chance you can kill it too
Option Two,, Sand Lap for a Few Hours to get the IHS to 1mm thick.....
Also 50% chance you can bust pins
I removed the IHS's to show how thick the Stocker is Compared to Sanding and then Lapping Mirror mooth...
When i sanded the IHS I used some Old CPU tray's and an old 940socket tray (stole from dead Board)
Cut one tray to fit inside another ,,Insert the (cpu foam) under the 940ZIF tray...
940Zif,,Foam,,Small tray,, use blue painters tape to to hold Cpu and trays together...Now set the taped Cpu in the bigger tray and tape once more..
Now your ready for the 100/120grit wet dry...then 400/600 and onto 1000/1200 and Finaly 2000....
Note: Unsoldering resulted in about the the Same Temps(+-1-2c )Vs By Sanding/Lapping the IHS....Sanding IHS you leave a very thin edge that supports the W/B with out as much Risk of Crushing Core....Ive Shatered Cores Before and Thus when i want to get down and Crazy , I now just san it paper thin,No more risk of Cooking Core(unsoldering) or shattering under Preshure
