03-27-2008, 10:59 PM
#1
X.I.P
Gigabyte X48T-DQ6 CPU and memory testing
Received this motherboard from GA about 4 days and here is my testing result for both memory and CPU results
-------PICTURES OF MOTHERBOARD------
here is the picture of the box
User manual, STAT cables, IDE and floppy cable, and I/O shield
Motherboard itself, blue looks pretty good but personally i like black or white color
clock-gen ID 9LPRS914EKL
Two GB LAN chips
Audio codec ALC889A from RT
8 prots of USB2.0, IEEE1394a, 2 RJ45, Coaxial and optical sound output. no extra output audio card needed
------MEMORY CL TESTS------
For a good motherboard, CL6-6-6 should reachs DDR3 1600 1.9v, YES IT PASSED
For a good motherboard, CL7-6-5 should do DDR3 1800 1.9v, Well, it does 4x1M at the time. not bad at all
For a good motherboard, DDR3 2000 1.9v with CL8 should be no problem either. It passed 32M test.
------CPU FSB TESTS------
E8400 reaches 534 benchable. not as high as i wish to go, the max i can make it boot is about 545 but won't load into windows
E6400 max out at 510 but only stable at 500, well, it is same as the memory DDR3 2000 i post on top
E8400 32m max out at about 4.5G
It is a good board, but still a lot of bios bugs need to fix. specially the memory divider it not easy to play with. Also if north bridge goes over +.575, motherboard will not boot up. i am not sure it is just my board or everyone else. For CPU voltage, when vcore set to 1.5v, actual voltage is at 1.47. no vdroop during loading. Thanks to Gigabyte PR for this review.
03-27-2008, 11:07 PM
#2
Nice review
I am looking at maybe getting one myself but ddr3 version , all depends if I get the 45nm cpu I am after or not, but looks good so far.
It would be interesting to see how these go with Quads.
__________________
GA-EX58-UD3R rev 1.6[/color]
6gb Patriot DDR3 @ 1333mhz
166 QPI Core i7 920 @ 3.33ghz
4 X 80gb Veloci Raptors in Raid 0
Creative Xfi Fatal1ty
2 Sapphire 4870s in Crossfire
Dell 3007 WFP
Cooler Master Real Power Pro 1000watt PSU
Lian Li PC-A10B
Air Cooled by Noctua
03-27-2008, 11:19 PM
#3
X.I.P
Originally Posted by REVHEAD
Nice review
i tested with Quads but i forget to save the picture.
max for QX9650 is 465 in my case. but this QX9650 is the very new one (and suxx, max 4.4G not even stable on any mobo). Actually the DDR3 1600 and 1800 were using QX9650 400 and 450 FSB
forget to metion, i use intel stock E6400's cooler for all the test....
03-27-2008, 11:34 PM
#4
Xtreme X.I.P.
guess2098: I add higher values for tRFC in this version: memset35
03-27-2008, 11:37 PM
#5
X.I.P
thx bro. i just download it.
03-27-2008, 11:44 PM
#6
...you two characters
nice testing there man
i hope that applies to 790i as it jumps out of range when i boot ram past 2200MHz
__________________
Team.AU
Got tube?
Originally Posted by Gautam
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
03-28-2008, 02:03 AM
#7
I was actually hoping it would have played nicer with the quads  it sounds like it playes the same with them as the DQ6 x38
__________________
Dell 3007 WFP
Lian Li PC-A10B
03-28-2008, 04:55 AM
#8
One-Eyed Killing Machine
Have you flashed to the latest BIOS version Denny? ( it helps a lot on memory overclocking & dividers )
03-28-2008, 05:31 AM
#9
Xtreme Mentor
Sexy looking mobo...can we get more pics of the onboard chips?, isin't there two new clock generators on the PCB?...one for memory and one for the NB?
__________________
Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
03-28-2008, 06:27 AM
#10
Sweet looking board !
FSB could have been better i guess. especially because its X48.Is it because its a DDR3 board or something ?
Asking this because my Abit IX38 clocked FSB very nicely.550 on E8400 is easy, max i could do was 580FSB under DICE.
Could someone shed some light on this ? guess2098 , dinos22...anyone ?
03-28-2008, 06:47 AM
#11
Most QX9650's and QX9770's are FSB limited somewhere between 440MHz and 480MHz FSB on P965/P35/X38/X48/nF790i.
There are some exceptions, finally reaching 500MHz ( stable or not  ) but that's the luck of draw effect
For the maximum FSB with E8xxx CPUs, once again, the average X38/X48 FSB overclock is around 540-560MHz, with some exceptions reaching even 600MHz FSB.
As noted several times before, FSB Limit is a CPU + Motherboard combo related.
You can get 10 E8500's and test them on the same ( part not just model ) motherboard, and reach different max FSBs...
Or you can try the same CPU on various motherboards ( even two of the same model ) and reach different FSBs.
03-28-2008, 07:45 AM
#12
Thanks for clarifying my doubts BenchZowner
03-28-2008, 08:28 AM
#13
X.I.P
i use F4h bios, been told that is latest bios. the original F4 bios doesn't do over DDR3 1600...
__________________
i left gskill about 4 months already.!!! please don't PM me about gskill's product :P but i can still help
03-28-2008, 08:29 AM
#14
Yeap, that's the good one, F4h
03-28-2008, 12:11 PM
#15
Xtreme X.I.P.
...what values are out of range? only tRFC?
03-28-2008, 12:31 PM
#16
Just got mine
& started winding it up
mifgt expain why i'm not getting a stable 1800Mhz I only see official F4
GA-X48T-DQ6
Anybody help with F4H please.
thanks
Edit: Found it Linky here if any one else wants it Thanks to BenchZowner
__________________
- i7 920
- DFI DK X58-T3eH6
- G.SKILL PI Black DDR3 PC 12800 CL8 6GB kit (F3-12800CL8T-6GBPI-B)
- Crossfire 2x ATI HD4670 GPU 785 Ram 1060
- Thermaltake Toughpower 1200w
- Cooling: Water - EK Supreme
- Lian Li V2000B+
24/7 OC 4Ghz 20x200 x8 1600Mhz 8-8-8-21
Official Gigabyte X48T-DQ6 Info Thread
DFI DK X58-T3eH6 on Test
03-28-2008, 01:21 PM
#17
nice runs ,which ddr3 ram you using in the tests?
__________________
Gigabyte X38T-DQ6/2x1gb xtreme/2x2900xt
E6850@ 4500
1000w psu/vapo Ls/2x74gb raptor raid.
03-28-2008, 03:16 PM
#18
X.I.P
GSKILL 1600 2GBHZ
03-28-2008, 11:12 PM
#19
FELIX
tRC
tRFC
__________________
Team.AU
Got tube?
03-29-2008, 12:28 AM
#20
Is the crazy cool easy to remove?
__________________
Dell 3007 WFP
Lian Li PC-A10B
03-29-2008, 12:57 AM
#21
Yes see Removing CrazyCool Heatsink , it also tells you in the manual page 16,
luck
__________________
- i7 920
- DFI DK X58-T3eH6
- Lian Li V2000B+
03-29-2008, 04:58 AM
#22
Xtreme X.I.P.
FELIX
tRC
tRFC
...fixed in this version.
03-30-2008, 08:07 PM
#23
I am Xtreme
GSKILL 1600 2GBHZ
what Vdimm?
03-31-2008, 04:55 AM
#24
this is cellshock and 2.0v still testing
__________________
E6850@ 4500
03-31-2008, 09:23 AM
#25
I am Xtreme
very nice...
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
