here is a temperature sensor mod i did with a water sensor for aquariums found at local fish store..the goal is to take the lcd screen and use it as a readout for an inline temperature sensor connected to my pump top, which is pumping out of a highly modified honda radiator. I also wanted to set it up as a two pin connector on the LCD readout so that i could switch between the inline sensor, an ambient sensor, and the sensor that came with the device itself, so that i could dump it into the rad and see how accurate that inline sensor is. I modified some fan headers to set that up. Works beautifully for the eight bucks the thing cost me
I have since used shrink tubing to clean up that ugly wiring and it looks much cleaner LOL
__________________
"Lurking" Since 1977
Jesus Saves, God Backs-Up
Reason: sp
This is my ghetto mod, fan died needed to keep the low profile for other pci cards. so I used plastic steel puddy to rig up my own low profile cooler. an old bus heatsink and a fan from a dead laptop. works better then stock. no temps on an fx5500 but to the touch, big difference. 350/500 nibitor bios as well.
Hey, Life got in the way of living. I have been away for a while.
I checked out this topic again from start to the end. Thanks all you ghetto modders for making me giggle smile and swoon. Amazing and epic topic this is.
btw that Athlon system I posted on page 3 of this thread:http://www.xtremesystems.org/forums/...2&postcount=62 is still running, though it has been rebooted because I upgraded the storage at one point and the PSU failed and needed replacing. The pencil mod on the CPU is still good too.
__________________
Asus P5WDH,Corsair HX620,E6400@3.4Ghz+Freezer7Pro,2x2Gb G.Skill-PiBlack@425Mhz,Asus EAH5850-900/1200,Audigy2 Plat-EX,Hauppage HVR1300,500Gb Caviar Black,Sony AD7240s... Wrapped in a Lian-Li PC-60
I did this a few days ago when I wanted toi use my stock GTX 260 heatsink and a swiftech universal GPU waterblock
I had to remove the newly cut fins one at a time as not to ben the rest of them. Needless to say it was tedious as hell.
I also had to cut two holes for the tubing to pass through.
Not my best work. I should have used a sanding bit. Not too shabby I don't think but I know I could have done better.
I did even them out a bit but my camera battery died so i have no final product pics yet, sorry.
Another mistake I made was cutting the last heatpipe thinking I was going to remove it as well.
I am going to try and solder a new piece of copper tubing there and patch it as I think it will help a little bit in the long run.
Here is what it looks like with the Swiftech
this corner gave me the most trouble
I have since cleaned up the cuts there and on the side of the fins using a dremmel cutting wheel and "shaving" each fin on both sides to get it to look original.
Another "fitting" pic
So i assembled the pieces to see what it is going to look like somewhat.
Update to the old ceiling computer. Still good for pr0n and laying around killing things.
Dual Opteron 270's
2gb DDR400 ECC Registered
Supermicro H8DCE-O
Dual ATI 3870's
Bunch of watercooling stuff
Win 7 Ultimate
And added a 19" LCD since the last one. I might add another 19" if I ever get around to repairing this one I have laying here.
Dual Opteron 270's
Supermicro H8DCE-O
Dual ATI 3870's
Win 7 Ultimate
I've been waiting for years to hear something along the lines of "last night my monitor fell off the ceiling and cracked me in the head." - I'm still waiting.
Dual Opteron 270's
Supermicro H8DCE-O
Dual ATI 3870's
Win 7 Ultimate
OMG!!!
Is this SCULTRAIL overther hanging off the cieling?????
great job!!!
What are these?4850s?
My most recent ghetto mod is a uni-sink hacked up to fit under an HR-03 with a ghetto retention bracket. Yes the dust did get cleaned off of the HR-03.
__________________
Asus P5Q Deluxe bios 2001m, Intel q9650, True black, 8gb G.Skill 4x2gb PC8500, Evga GTX280 SSC, HR-03 GTX, Pc Power and Cooling 750w silencer, Antec 1200
Originally Posted by LiberalElephant
ASUS actually hates you and wants you to die by way of freak south bridge chipset fire than eventually englufs your entire house while you sleep. The kicker is that ASUS installs a program on your computer that causes it to download gay porn while you are idle until the south bridge over-heats and you die in a gay-porn fireball. Your relatives find your hard drive full of gay porn and the evil empire of ASUS has struck again.
Disclaimer: Being gay is okay. ASUS is not actually trying to kill you in a fireball of gay-porn.
So I decided to start a project,
I called it Project Cool n' Quiter.
I have a Delta PFB1212UHE-F00, 252CFM 67dBa fan. Ofr the past few months I've been using it at 5v, but the motor on the fan doesnt like 5v. Its been barely spinning, like 1200 RPM (mind you at 12v it spins at 5500RPM). So I feel like its been wasted. I also have at Delta AFB1212SHE, a 152 CFM, 53 dBA fan. At 5v this fan runs at 1300 RPM, and moves plenty of air while remaining quiet enough.
So using a normal switch, handybox, some speaker wire, ductape, electrical tape, and a few other cheap items I made a nice switch for the monster fan for OC runs.
I stuck two aluminum nails into a molex, one in 12v and one in ground. Taped it up real nice so they didn't touch. I then took some 16-gauge speaker wire and wired it from the molex nails into the handy-box via PCI-slot. I spliced the fan and speaker wires grounds together with a wirenut, and put the hots on the light switch.
I put the AFB on top of my Xiggy (ductape) pulling air 24/7 while the PFB remains off. I also put some sound deadening material to make it a little quieter, but that was a waste of time.
I have done some mods to my Cisco PIX 506e firewall I picked up for free from my old employer.
First I upgraded the RAM for 32mb of PC-100 SDRAM to 256mb of PC-100 SDRAM. I then went ahead and upgraded the CPU from a 300mhz Celeron to a PIII 600mhz. Too bad I can't adjust multiplier.
The thing only had one 50mm fan cooling the tiny heat sink. The thing was hot and loud. I cut a hole in the top and put in a 120mm fan ontop of it. Thing now runs cool and quiet. It is no longer hot to the touch.
The stock AMD heatsink only allows 60mm fan to be mounted, but I want to use a 80mm fan. So, I used Zip Ties to mount the 80mm fan on the stock heatsink.
This is currently how i cool my xbox 360 (not joke), the stock fans stopped working. Xbox currently has no fans plugged in at all, just this big window fan blowing on it, it works better than the origonal fan ever did!
__________________
Q9300 [Crunch]/ XFX GTX285[Fold]/ EVGA 750i
Two 250GB 7200 / 4GB XMS2 800 / 1Kw XPS PSU / Freezer Pro 7 10,797 3DMark Vantage / Scythe 120mm Case fans / Vista U. 64 PS3 - 700 Work Units and going strong!, XPS 720 H2C Case
Crunching 24/7 on Q9300....might upgrade to an i7
