XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 05-05-2008, 12:27 PM   #26
KTE
Xtreme Mentor
Trying to keep 0xC0010064 as the COF would work much better I think, that's where my multis are coming from always.
KTE is offline   Reply With Quote
Old 05-07-2008, 01:40 PM   #27
VVJ
VVJ's Avatar
Here is a snapshot for low-power Opteron 2204 45W processor.
An Athlon 4850e even looks much better!
VVJ is offline   Reply With Quote
Old 05-17-2008, 09:44 PM   #28
Morais
does anyone have more overclocking results on this chip?
__________________
Morais is offline   Reply With Quote
Old 05-19-2008, 03:04 AM   #29
N00B
N00B's Avatar
Aqui vai o meu.
Here's mine.
Stock voltage.
__________________
Gaming-Q9450|Asus P5Q-E P45|SAPPHIRE HD4870 DDR5|2gb Xtreem|Seagate 250gb (1 Plate)|OCz 470w 32A
Work-Amd x2 4850e|Gigabyte GA-MA78GM-S2H|2*2gb TeamXtream|Samsung F1 750gb|LC 550w 14cm
SERVER1-Sempr0n 1.6@2.4Ghz|Dfi LP nf3|Riva Tnt2|2*256 OCZ EL|Samsung 160GB|420w
MAC-Ibook G4;12";1ddr;9200ddr
CSS Server-Asus pundit;p4 3.2Ghz;2*512ddr;Samsung 40gb;
barton 2600+@2800mhz SuperPI 37s Sempron 2800+@2665mhz SuperPI 35,5s OLD SCHOOl
N00B is offline   Reply With Quote
Old 05-25-2008, 02:30 PM   #30
Kardahs
Hi All,
Just got mine a few days ago and I'm testing step by step, for the moment I tested lowest voltage at 1000Mhz (stock idle frequency) and went down to 0.850V, I think it won't go far beyond that but I'll try. I'll try to post other results when the tests are done
@ NOOB : I see your CPU-Z screenshot shows some overvolting compared to stock voltage (1.296 instead of 1.25), I have the exact same overvoltage shown in CPU-Z with my Gigabyte GA-MA78G-DSH3, do you have an idea where it would come from
Bye !
Kardahs is offline   Reply With Quote
Old 05-25-2008, 04:42 PM   #31
Spectrobozo
Spectrobozo's Avatar
I'm using a g1 brisbane @ 1ghz 0.80v for six months now...
I never tested the stability on any burn test, but it is 100% stable at Idle, and I even played "NFS porsche 2000" at this clock and voltage for hours, anyway, what would be the estimated TDP at such clocks/voltages!?
__________________
Spectrobozo is offline   Reply With Quote
Old 05-26-2008, 02:26 PM   #32
Kardahs
I don't know what would be the TDP at that speed and voltage, I'm monitoring only the total power consumption of the PC.
Seems I didn't get the best sample, I'm getting errors at 2875Mhz (12.5 x 230Mhz) at stock voltage, 2750Mhz went fine but not here. Have to do more checks but I already lowered the HT Link speed and still get the same errors, I'll try cooling actively the CPU, it might help a little bit.....
Old 05-26-2008, 09:28 PM   #33
Kain665
What is your cpu cooling and what is your board?
__________________
Q9550 4ghz (475x8.5) 1.32v load (Megahalem Push/Pull)
Asus P5Q - Deluxe (m2102) 1.40v NB
4gb Crucial Ballistix Red (6-6-6-18 @ 1140mhz, 9.3gb/s read)
BFG GTX275 720/1475/1269 (1.18v, higher for benches.)
OCZ SXS 600w
Lian Li PC-7 (Small, Old 80mm version )
Kain665 is offline   Reply With Quote
Old 05-27-2008, 01:43 PM   #34
Kardahs
My board is a Gigabyte GA-MA78G-DSH3 and the CPU cooler is a Cooler Master Z600. I use it fanless (with no fan attached to it), however it benefits from the extraction fan of the PSU located just above.
This evening I added a little bit juice (1.275 in BIOS instead of 1.25V) and 2875Mhz went OK
Old 06-19-2008, 01:17 PM   #35
arthur92710
Originally Posted by N00B View Post
Aqui vai o meu.
Here's mine.
Stock voltage.
How do you get that? I can only get to 3ghz with 250fsb 12.5x and 1.425v
arthur92710 is offline   Reply With Quote
Old 06-19-2008, 01:57 PM   #36
Kardahs
That's a matter of luck
I achieved the 3ghz with mine at 1.325 VBIOS? Now running it at 2750Mhz on stock voltage
Old 06-19-2008, 01:59 PM   #37
arthur92710
What if he burned it in?
I did not so that might be the solution.
Old 06-19-2008, 04:03 PM   #38
N00B
N00B's Avatar
mine was just out of the box!
I'll try to get to 3.6Ghz
__________________
Old 06-19-2008, 07:02 PM   #39
arthur92710
no way man!
lucky!!
I think its the ram.
What I have is nothing compared to yours!
Well I can go and start the "unofficial Athlon 4850e Underclocking thread"
Check out my low underclocks!
Low and
Low but higher multiplyer They both draw .80A Idle
Old 06-19-2008, 10:08 PM   #40
VVJ
VVJ's Avatar
arthur92710,
Ha-ha, 90MHz for the reference clock?! LOL! Is it really possible?
Old 06-20-2008, 05:02 AM   #41
justapost
Originally Posted by arthur92710 View Post
no way man!
lucky!!
Low and
Impressive ref HT. Lowest I could reach was ~165MHz on the DFI790FX. What mobo are you using?
How low can you go with the cpu voltage? I'd expect 0.7-0.8V here.
__________________
Office: Phenom 9950BE @ 3.2GHz/2.6GHz /ASRock AOD790GX/128MB@1.0/4x2GB Apogee 1150 DDR2/Sapphire HD 2600 XT/D-Tec FZ v2|MCR320|Laing Ultra/WD Black 320GB
Home: Athlon 5050e/Jetway MA3-79GDG Combo/2x1GB CB Tracers 1066 DDR2/TT BigTyphoon/WD Raptor 74GB
Testing: Phenom II 955BE + GBT MA785GMT-UD2H <-> Intel i5 750 + GBT P55M-UD4/2x2GB OCZ Platinum DDR3 1333 CL7/OCZ Vertex 60GB/GW 8800GT 1GB/SSII 380W
justapost is offline   Reply With Quote
Old 06-20-2008, 05:23 AM   #42
LIKMARK
LIKMARK's Avatar
no way man!
lucky!!
Low and
Damn!!
Was that stable??
LIKMARK is offline   Reply With Quote
Old 06-20-2008, 07:28 AM   #43
arthur92710
My mobo is the ASUS M3A
I set the FSB to 600 and multi to 5x voltage was auto.
Then in windows I used a64clk to test other multipliers.
YES!! I win in something!
Old 06-20-2008, 11:40 AM   #44
justapost
So it's actualy a bug in the bios allowing such an low ref HT?
Bios 600MHz -> System 90MHz?
__________________
Old 06-20-2008, 06:54 PM   #45
arthur92710
Must be a bug.
Well I was able to get to 3ghz.
HERE
Old 06-20-2008, 10:00 PM   #46
crowncobra
nice cpu
__________________
Intel Celeron 430 @ 3.4 GHZ
Gigabyte EP31-DS3L
Cheap 1GB PC2-6400 800MHz
Powercolor 4870 PCS+ 512MB DDR5
Hitachi Deskstar 80GB
Creative DVD 8x
CoolMax 500W
Windows Xp media center 2005
BenQ T22IW
crowncobra is offline   Reply With Quote
Old 06-21-2008, 10:06 AM   #47
Kain665
Here is mine. 10hrs orthos stable. It could run fine at 1.33v, its just this Gigabyte 790x DS4 either overvolts or undervolts :x
http://img261.imageshack.us/img261/5259/82143033zj9.jpg
__________________
OCZ SXS 600w
Old 06-21-2008, 12:13 PM   #48
arthur92710
Nice.
I just tried that but windows keeps crashing when I run prime95
humm I wounder what you keep in your "stuff" folder
Old 06-22-2008, 12:56 AM   #49
Kain665
Nice.
Only the stuff you can get without a subscription:
Orhtos, CPUz, Coretemp, OCCPT, Fraps, Stalker Build 1094, Stalker build 1152, 3DMark06 installer, Winrar installer, Spi, NiBitor, AMD Dual core driver, AMD Dual core optimizer, UXtheme patch for SP3, Opera setup, AOD setup, Winamp setup, Java JRE setup, Zune software, Aquamark setup, Azureus setup, Spysweeper setup, steam setup, and riva tuner. Why?
__________________
OCZ SXS 600w
Old 07-08-2008, 01:46 AM   #50
w0lla
what kind of temps are u guys getting. Im getting weird temps with my 4850e, I have it cooled with a ninja mini (as5). Thing is, its (core 1/2) idling at 15-20´C (at start, usually 20-25'C after its been on for a while), but when I put prime95 small ffts on it makes a huge jump to 50-55'C (core1/2). vcore is set at 1.15v in bios, stock speeds.
I mainly use everest ultimate for temp readings but I also have hwmonitor. Both give the same temp for the individual cores but HW states TMPIN0 as 70'C+ when having small ffts on, confusing.
I first had a gigabyte 780G matx board but after a bad @bios flash (kickin myself of using that) I got a 690G asus board as a temp. recplacement. I get the same temps with both of the boards.
__________________
1. Q6600@ 3.4ghz (1.37v), Asus Formula Maximus, 2x2 OCZ Reaper pc6400 CL4, 150gb velo, HD4870x2, corsair 750w
2.Opteron 165@stock, Gigabyte triton K8, 1gb Corsair (2-2-2-5), 160gb Barracuda, Sapphire x1950pro, corsair 520w
w0lla is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
