03-27-2008, 01:04 PM
#276
Originally Posted by Tjalve
Got it stable at 520x6 today on my E8500
I know its not the same thing om Dual Core but it seems like this board can get some nice FSB clocks.
Starting to play with Q9450 OEM,L806B004.Waffer number not good.We shall see.
Edit:Reseated block 3 times.These little chips idle hot,if coretemp 097.1 is correct.
03-27-2008, 02:03 PM
#277
Here's what my stock settings looks like:
ANy thoughts? (Notice how CoreTemp says 3250 (?WTF?)
__________________
x3350@3.4<>DFI X48T2R LT<>8GB RAM<>GTX280<>Vista Ultimate x64 SP1<>NEC 2690WUXi
03-27-2008, 02:31 PM
#278
Originally Posted by gersson
Nice, I didn't realise C1 Quads apart from QX's had hit the streets did you get it retail ?
CN
__________________
PLAY RIG CUPBOARD IS BARE ATM !!!! SHALL I i7 OR NOT
HOME 24/7 RIG DFI LP UT P45, E8500, 4GB OCZ PC2-6400 REAPER X , EZ-COOL 600W PSU, GE-CUBE HD3870X2, 2 X 80GB HITACHI SATA 2 HD'S IN RAID 0 + 2 X 250GB MAXTORS MIRRORED + 1 X 500GB MAXTOR, VISTA ULTIMATE SP1 (32 BIT)
WORK 24/7 RIG DFI LP DK P45 PLUS, E8500, 4GB OCZ PC2-8000 REAPER X, EZ-COOL 700W PSU, RADEON HD3450, 2 X 160GB RAID 0 + 2 X 160GB SAMSUNG'S SATA 2 HD'S IN RAID 1, VISTA ULTIMATE 32-BIT SP1, CPU COOLING : TUNIC TOWER 120
OLD FAITHFUL DFI NF4 EXPERT, OPTY 144, 1GB OCZ PLATS, 600W PSU, 6600GT, 60GB MAXTOR, XP PRO - SP2, CPU COOLING : STOCK
03-27-2008, 02:44 PM
#279
Xtreme Guru
Originally Posted by Jor3lBR
Tx will try 1st thing after lunch. So it would be like this: 88/88/102?
What would be the correct Nb volt for 88/88/96? I wanna try to estabilish a link that would work the best for me.
67-69% of vtt =gtl
first 2 are for cpu vtt
last is for fsbv
03-27-2008, 02:52 PM
#280
Just having a play with one of these while reviewing it.
It does well at low voltage so far.
400x9 3600Mhz 1.31v 800Mhz RAM - All voltage settings at default apart from the NB voltage at 1.35v and DRAM voltage at 2.19v.
CPU Feature
Thermal Management Control: Disabled
PPM(EIST) Mode: Disabled
Limit CPUID MaxVal: Disabled
CIE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 9 X
Target CPU Clock: 3600Mhz
CPU Clock: 400
Boot Up Clock: AUTO
DRAM Speed: 400/800
Target DRAM Speed: 800Mhz
PCIE Clock: 100mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU VID Control: 1.31v
CPU VID Special Add: AUTO
DRAM Voltage Control: 2.19v
SB Core/CPU PLL Voltage: 1.51v
NB Core Voltage: 1.35v
CPU VTT Voltage: 1.211v - Note that this is slightly higher than the X38's 1.205v
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disabled - Not needed yet.
x CPU GTL1/3 REF Volt: 110
x CPU GTL 0/2 REF Volt: 110
x North Bridge GTL REF Volt: 110
DRAM Timing
Enhance Data transmitting: AUTO
Enhance Addressing: AUTO
T2 Dispatch: Disabled
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: AUTO
DIMM 1 Clock fine delay: Current
DIMM 2 Clock fine delay: Current
Ch 1 Command fine delay: Current
Ch 1 Control fine delay: Current
Ch2 Clock Crossing Setting: AUTO
DIMM 3 Clock fine delay: Current
DIMM 4 Clock fine delay: Current
Ch 2 Command fine delay: Current
Ch 2 Control fine delay: Current
Ch1Ch2 CommonClock Setting: Auto
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 15
All Precharge to Act: AUTO
REF to ACT Delay (tRFC): AUTO
Performance LVL (Read Delay) (tRD): AUTO
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
Channel 1 Phase 0 Pull-In: Auto
Channel 1 Phase 1 Pull-In: Auto
Channel 1 Phase 2 Pull-In: Auto
Channel 1 Phase 3 Pull-In: Auto
Channel 1 Phase 4 Pull-In: Auto
Ch2 Read delay phase (4~0)
Channel 2 Phase 0 Pull-In: Auto
Channel 2 Phase 1 Pull-In: Auto
Channel 2 Phase 2 Pull-In: Auto
Channel 2 Phase 3 Pull-In: Auto
Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Read to Write Delay (tRDWR): AUTO
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): AUTO
ALL PRE to Refresh: AUTO
I couldn't go any higher at this voltage.
I've also done a DFI BIOS guide that might help a few people.
03-27-2008, 03:07 PM
#281
Originally Posted by zsamz_
67-69% of vtt =gtl
last is for fsbv
Humm so how come my Gtl's are off if 0.69x1.26v(my actual vtt volts) equals 87-88??
Can you explain for dummies how you calculate yours (I've read all the links)?
03-27-2008, 03:35 PM
#282
Your method of computing GTL values is close. Depending on component tolerances you will be within +/-5.
__________________
#1 Rule Of The Internet - The majority of writing stated as or giving the impression of fact is little more than the author's opinion. And more times than not that opinion is based on little or no knowledge of the topic.
03-27-2008, 05:11 PM
#283
Originally Posted by Clunk
Some good info & a good bit of work there, its real nice to see a UK review on a DFI & actually be able to get hold of it from a large UK retailer when the board is still hot news.
CN
__________________
03-27-2008, 05:22 PM
#284
Thanks mate
Theres a few places in the UK with stock on the way for sure. Scan has stock.
03-27-2008, 05:27 PM
#285
Vey nice Clunk.Just a short run here on Q9450.450x8.
Voltage Settings
Cpu VID 1.29375
CPU VID Control: Auto
CPU VID Special Add: Disabled
SB Core/CPU PLL Voltage: 1.640
NB Core Voltage: 1.492
CPU VTT Voltage: 1.175
Reason: Add cpu vid
03-27-2008, 05:29 PM
#286
Xtreme Guru
1,5vX.69=103 you got 96 nb gtl
or am i getting something wrong
03-27-2008, 05:48 PM
#287
Not to argue, but it is my understanding that both the CPU and NB GTL settings are a % of the VTT. Is that not correct?
According to the Chart it is true.
http://www.edgeofstability.com/artic...fault_gtl.html
Larry
__________________
Q9400 @ 3904
Asus P5Q-D Bios 1406
260 GTX FC Block
2x2gb OCZ Flex II PC2 9200
Water Cooled/ Iwaki MD20/ D-Tek Fuzion
PCP&C 1KW-SR
SCSI Perc4E RAID0 2x147 15K Fujitsu
Reason: added link to chart
03-27-2008, 05:51 PM
#288
GTLxVTTxVNB
I see what you mean Sam:
So you calc like this:
For CPU GTL 0/3&1/2 = 0.69*VTT voltage
For NB GTL = 0.69*NB voltage
The original way of making those calcs are always to use VTT as reference in percentage, like Praz said. So all variables must come from VTT and none from VNB (so always apply 0.69*VTT voltage for CPU GTL and NB GTL) - it's strange I know
But for some like you seams to be the case that a stray NB GTL works better.
I will try both ways and see if I can get those 4 sticks running 1200Mhz 2.1v again.
03-27-2008, 06:17 PM
#289
Xtreme Guru
yup thats how i do it works for me maybe i'm wrong
i run 4x1 @ 1200+ easy should be same or better on x48
edit: you right i messed up all gtl is related to cpu vtt pl voltage
back to drawing board for me i be makin some new tests
maybe i pass 555fsb lol
but funny how my settings workin for me
03-27-2008, 06:18 PM
#290
From page 24 of the X38 datasheet.
Note: Unless otherwise noted, the voltage level for all signals
in this interface is tied to the termination voltage of the Host Bus (VTT).
As it pertains to the chipset in this intance VTT is taken from the same source that supplies the processor.
From page 284 of the same datasheet.
Notice inside the red boxes? 0.666xVTT_FSB. Northbridge GTLREF is set from VTT.
When it's all said and done all that really matters is one comes up with settings that work.
__________________
03-27-2008, 07:27 PM
#291
Guys I think I screwed up: I bought ram too slow for my goals. For some reason the only factor I weighed once the 2 diff ram types were in my newegg basket was price. I bought 8GB (2x2x2) of DDR800. Instead of the 1066
Right now I'm at 1.2vcore 3.2Ghz (all else stock; vcore could be potentially less)
I tried to isolate the ram and couldn't go much further than 800Mhz.
When doing 901 (for 3.6Ghz), I gave the NB 1.4 and the ram 2.25v (6x multi) and boot process gets hung @ first prompt. I've gotten REALLY rusty -- any ideas on where to go next? I would apprecite a good plan of attack to see if it really is my ram
__________________
03-27-2008, 07:36 PM
#292
Have you tried loosening your ram timings? That should get you higher clocks. If I may ask, what are the rated default timings and voltage for your ram at 800 mhz?
03-27-2008, 07:53 PM
#293
I'm using 2x of these:
http://www.newegg.com/Product/Produc...82E16820231122
I'm going to turn in, though -- enough for today. 3.2Ghz stable @ 1.18vcore all else stock -- not bad
QUICK EDIT:
I tried 450 FSB; NB:1.5v; 5-5-5-15 @901mhz ram...any suggestions on some timings? I'm thinking 2.20vdimm cos of all the ram?
__________________
03-27-2008, 10:55 PM
#294
I just got my system built this afternoon with an E3110 and i'm posting 9x445 (4005) at stock volts right now but i have yet to run any real tests. I'll report back tomorrow with some real results if time permits.
__________________
E8400 @ 4ghz 24/7
DFI LP LT X48-T2R
G.Skill F2-8500CL5D-4GBPK
BFG 9800GX2
2 x 150GB Raptor X in RAID 0
03-27-2008, 10:59 PM
#295
I am Xtreme
QUICK EDIT:
change your trfc to 42 then try, and use teh voltage with an actual voltage as close to 2.1 as u can get
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
03-27-2008, 11:39 PM
#296
How did you guys mount a Thermaltake Ultra 120 Extreme on this board vertically,and cooling the NB too?If you mount the original cooler from the box,the TR 120 Extreme has to be mounted horizontally to fit,and this is very bad for the power supply if you mount it this way because all the hot air from the CPU,NB,goes there.
Does this problem dissapear when you mount a Noctua U6 NB cooler,if you have a TR 120 Ultra Extreme?
03-28-2008, 12:20 AM
#297
Sorry its of topic but what are considered good waffer numbers for the Q9450/X3350.
03-28-2008, 01:37 AM
#298
mrcape
what model exactly is this heatsink
__________________
AMD X2 6000+ | Xigmatek Achilles
DFI Lanparty DK 790FX-M2RS | 2x2 GB Corsair XMS2 800mhz
Sapphire ATI 4870 | Acer Al2223W 22"
On the table... | Corsair TX750w
SoundBlaster X-FI Xtreme Music | Z-2300 thx
OVERCLOCKERS GUATEMALA
03-28-2008, 02:31 AM
#299
Hey, for some reason when I have Logitech Setpoint set to it's own mouse driver as opposed to "OS's" I get complete system freezes when left clicking from time to time. I have to hard shut down when this happens.
Only component I've changed today has been the motherboard and PSU, this mouse worked fine before. Issue with X48? Or what?
Anyone else with a Logitech G5 mouse (or other I guess) had this issue?
__________________
Q6600 g0 (lapped up to 1200 grit) @ 3.6 ghz (will be higher once a game comes out that needs the juice)
DFI LP LT X48
EVGA GTX 260 (216) FTW (what a name...)
4 gigs DDR2-800 Ballistix 4-4-4-12
Creative X-Fi XtremeGamer
500 gb Seagate + 150 gb Raptor X
Silverstone 850 watt (modular)
Vista Business 64 bit
EK Res 150 -> DDC3.2 + XSPC Rev. 3 top -> MCR320 rad (S-Flex F fans) -> Apogee GT (bowed) -> MCW30 -> MCR120 rad (Zalman F3 fan) -> MCW60 -> EK Res 150
03-28-2008, 02:38 AM
#300
no idea why u guys running so high for 1600fsb at those nb voltages
here is mine
everything at stock
just increased the fsb to 400 .. rest all at default
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
