XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme News
Reply
Old 03-10-2008, 06:50 PM   #1
Zorlac
Zorlac's Avatar
Cool HIS iClear = Clearer audio/video?
I saw a picture of this from Cebit and found the product on the HIS site:
http://www.hisdigital.com/html/product_ov.php?id=340
"HIS iFilter card provides a better image with clear picture
HIS iClear card provides better gaming experiences by reduce the distortion and noise generate from graphic card.
It can eliminate the noise generate from high-end card such as 8800GTX, GTS graphic card to provide a "clear picture" when they play can
HIS iClear card provides an ultimate HD experience by reduces the distortion and noise generate from TV tuner card."
Snake oil?
Zorlac is offline   Reply With Quote
Old 03-10-2008, 06:53 PM   #2
HotGore
HotGore's Avatar
All I see are some caps, and resistors.
__________________
q9450@3.6ghz w/D-Tek Fuzion w/Nozzle
Asus P5K w/Swiftech MCW30
2x2gb OCZ Reaper DDR2-800
EVGA GTX 260 w/Danger Den Triton Block
X-Fi Xtreme Gamer
Corsair 620HX
HotGore is offline   Reply With Quote
Old 03-10-2008, 06:53 PM   #3
Wiggy McShades
Wiggy McShades's Avatar
i dont get it if you look at the card its just a pcb with a few capacitors on it.
__________________
Wiggy McShades is offline   Reply With Quote
Old 03-10-2008, 06:54 PM   #4
NickS
I am Xtreme
NickS's Avatar
How the heck does it work?
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
NickS is offline   Reply With Quote
Old 03-10-2008, 06:55 PM   #5
SparkyJJO
Xtremely High Voltage
SparkyJJO's Avatar
Send a message via AIM to SparkyJJO
Sometimes, that's all it takes to clean up a signal. I'm not aware of any video noise that needs cleaned up from a gfx card though.
__________________
This forum requires that you wait 70 seconds between posts. Please try again in 1 seconds.
SparkyJJO is online now   Reply With Quote
Old 03-10-2008, 06:57 PM   #6
Wiggy McShades
well yeah but how would a separate card clean the video signal from my graphics card?
__________________
Old 03-10-2008, 06:57 PM   #7
perry_78
Ebay Hater
perry_78's Avatar
Send a message via ICQ to perry_78 Send a message via MSN to perry_78
Good question.
__________________
In short, both AMD and NVIDIA discovered that their next-generation graphics cards are superior to each others' last-generation graphics cards.
perry_78 is offline   Reply With Quote
Old 03-10-2008, 06:57 PM   #8
kamongear
kamongear's Avatar
Guys what you don't see is the magic inside. :-P
kamongear is offline   Reply With Quote
Old 03-10-2008, 06:58 PM   #9
SparkyJJO
SparkyJJO's Avatar
I honestly don't know. I see how only a few components can clean things up, but I don't get how this separate card can clear things up
__________________
Old 03-10-2008, 06:59 PM   #10
Wiggy McShades
ohh i see it now the card runs on hopes and dreams.
__________________
Old 03-10-2008, 07:05 PM   #11
doober
Goes great with your KillerNIC and physx card
doober is offline   Reply With Quote
Old 03-10-2008, 07:12 PM   #12
ryboto
ryboto's Avatar
my HD 3870 makes some signal noise under 3d, it's clearly audible over the rest of the system. Then again, the fastest spinning fan in my system is quieter than my loudest hard drive, so my system may be atypical.
__________________
Q9400(3.0ghz 1.1v) | Asus P5Q-EM| HD3870 | 2x2gb DDR2-1000 Mushkin | WD6400AAKS | NSK 1300 2xEnermax Marathon | Thermalright HR-01 Plus + AC S1 Passive | PicoPSU(220W)
ryboto is offline   Reply With Quote
Old 03-10-2008, 07:15 PM   #13
Natalia
Natalia's Avatar
Send a message via MSN to Natalia
Same thing I was asking myself
__________________
Windows 7 - RC Build 7100 x64
Intel i7 920
ASUS P6T6 WS Revolution
4 GB OCZ RAM PC-12800
WaterKegIII Xtreme for CPU
ASUS Xonar D2 on Denon D2000
2x WD 150GB Raptors RAID 0
30" @ 2560x1600 on 9800GX2 Quad SLi
22" @ 1680x1050
Natalia is offline   Reply With Quote
Old 03-10-2008, 07:16 PM   #14
MuffinFlavored
Send a message via AIM to MuffinFlavored
Reflective PCB?
__________________
Gigabyte P35-DQ6 | Intel Core 2 Quad Q6700 | 2x1GB Crucial Ballistix DDR2-1066 5-5-5-15 | MSI nVIDIA GeForce 7300LE
MuffinFlavored is offline   Reply With Quote
Old 03-10-2008, 07:23 PM   #15
ChaosMinionX
Xtreme New Yorker
ChaosMinionX's Avatar
Send a message via ICQ to ChaosMinionX Send a message via AIM to ChaosMinionX Send a message via MSN to ChaosMinionX
might be some sort of EMI/RFI shielding that you put inbetween your videocard and soundcards... since most Mobos have PCIE1x inbetween the PCIE and PCI...just a guess though.
__________________
===Under Construction===
[HeatWare]
ChaosMinionX is offline   Reply With Quote
Old 03-10-2008, 07:27 PM   #16
Knight
Knight's Avatar
I was going with that guess, but not a lot of motherboard makers have the open slot.
__________________
Intel | Q6600
ASUS | P5Q-Deluxe
G.Skill | 2x2GB PQ
Nvidia | 8800GTS 320MB
Seagate | 2x320GB 7200.10 Raid 0
Corsair | 520W PSU
Knight is offline   Reply With Quote
Old 03-10-2008, 07:31 PM   #17
ZOMGVTEK
ZOMGVTEK's Avatar
Send a message via AIM to ZOMGVTEK
Without a doubt, it would help clean the power going to your video card. But the difference would be so marginal by any measure, its not a big deal. It looks like they are using larger electrolytic caps to store enough to help minimize transient fluctuations, and some smaller SMT style caps. Im not sure what frequencies a video card can throw back into your power, but those smt caps look a bit large to do much good.
If its under $20 and you are experiencing problems likely associated to your video card, such as you 'hearing' your video card through your headphones, then it might help. But getting a bigger and better PSU that has larger internal capacitors and is designed to put out more power would likely do more. But that aint cheap...
And yes, its likely that the main surface of the board is unetched copper clad, and would help to shield your sound card from other devices with proper use.
All of these custom built computers throw rf all over the place, and all the devices have to do massive corrections to adjust for that. Might account for the differences when you run a benchmark twice in a row and you get slightly different results... That should not happen assuming constant conditions.
__________________
ASUS P5K Premium, Black Pearl - 0612
Q9450 475x8 - 1.1250Vid, 1.40Vbios, 1.386Vload
TRUE - Lapped - Dual 115cfm Panaflo's
4870 1GB - 800/1200 Stock Voltages
4x1GB Corsair Dominator DDR2 1066 @ 950 1:1 - 2.25V - 4-4-4-12
2x Hitachi 7K1000 in RAID 0
Silverstone ZEUS 850W PSU
Windows XP Pro 64 Bit
Apple OS X 10.5.8
HEAT
ZOMGVTEK is offline   Reply With Quote
Old 03-10-2008, 07:33 PM   #18
SparkyJJO
SparkyJJO's Avatar
That makes a bit more sense. I was trying to figure out how it would clean up video.
__________________
Old 03-10-2008, 07:37 PM   #19
WeStSiDePLaYa
Aint No Real Gangster
WeStSiDePLaYa's Avatar
this is about 2 dollars of chemicon P series polymer capacitors, and 20cents worth of ceramic capacitors.
No resistors.
All this does is add extra capacitance to the power rails available through the pcie slot.
The reason all the silk screened cap spots aren't filled, is because it was probably too high of capacitors, causing too large of in rush current and causing boot issues.
__________________
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale
2x1GB OCZ PC2-9200 FlexXLC
BFG GTX 280 OC2
Maxtor 6L250S0
Maxtor 6V300F0
Western Digital WD2500JS
Western Digital WD500AAKS
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Arctic Cooling S1
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
WeStSiDePLaYa is offline   Reply With Quote
Old 03-10-2008, 07:38 PM   #20
ZOMGVTEK
ZOMGVTEK's Avatar
I have dealt with power conditioners, and every bit of capacitance i added to the line increased the resolution i could get out of the tv. Not noticeable to most, but the difference is there. The right size and type capacitors can seriously clean up signals.
The moral of the story is, this card isnt going to do anything... That you notice.
__________________
Apple OS X 10.5.8
HEAT
Old 03-10-2008, 07:38 PM   #21
Monkeywoman
Xtreme Supporter
Monkeywoman's Avatar
i bet they are going to sell it for 150 bucks.
__________________
Case-Coolermaster Cosmos S
MoBo- DFI LanParty LT X48-T2R
Graphics Card-SAPPHIRE 4870 Toxic 1Gig 820/1000
Hard Drive-Seagate 160Gb master Seagate 250Gb slave Seagate 500Gb slave Western Digital 500Gb
CPU-Q6600 3.6Ghz 9x400 1.400Vcore (G0)
RAM 4Gb DDR2 800Mhz C4
Audio-Xfi Xtreme Music, Logitech 5.1 Z5500 BOOST22
40Gb of MUSICA!!
SonyPlaystation 3 SECHE01 320gig Western Digital Scorpio
Monkeywoman is offline   Reply With Quote
Old 03-10-2008, 07:39 PM   #22
ToTTenTranz
A bunch of capacitors between the PCI-E power and ground supplies? It should decrease the power supply's noise for the PCI cards.. but I guess most motherboards already take care of that.. And why did they make such a big card to store 7 small capacitors?!
I wonder if this will ever make any difference at all. And audible at that.
Nothing like a RightMark AA -based review to prove it.. In case some reviewer ever bothers..
ToTTenTranz is offline   Reply With Quote
Old 03-10-2008, 07:42 PM   #23
ZOMGVTEK
ZOMGVTEK's Avatar
http://www.digit-life.com/articles3/...is-iclear.html
I would say this would have the biggest impact on something sensitive, like a analog tv tuner... Otherwise, i couldnt see it making a difference.
__________________
Apple OS X 10.5.8
HEAT
Old 03-10-2008, 07:48 PM   #24
WeStSiDePLaYa
Pretty much garbage.
__________________
Specs
BFG GTX 280 OC2
Maxtor 6L250S0
Maxtor 6V300F0
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Arctic Cooling S1
Audio Setup
Old 03-10-2008, 07:52 PM   #25
ZOMGVTEK
ZOMGVTEK's Avatar
Well yes, no reason to get it... Unless youre REALLY into getting channel 2 off the air as perfect as possible and dont want to modify anything.
I see youre into your headphones...
__________________
Apple OS X 10.5.8
HEAT
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
