03-05-2008, 12:47 PM
#26
I am Xtreme
Originally Posted by adidassler
is there any quick way to test if my pump is still up?
Hook a long section of tubing to the inlet port of the pump. Connect a short section of tubing to the outlet port of the pump. Fill the inlet tube completely with water. Some water will just flow through the pump out the outlet port, so try to prevent that. Start up the PSU and that will start up the pump.
Three scenarios: (1) pump doesn't start, which means the pump motor is completely dead, (2) pump starts but it is not pumping water rapidly, which means that there can be some bubble in the pump, or something may be defective, (3) pumpstarts up and water squirts out the outlet port rapidly with high pressure.
If it is scenario number 3, then celebrate because your pump is alive and well.
Stay focused and think only positive thoughts.
03-05-2008, 12:49 PM
#27
Location: Philippines (currently in the Middle-East) TPC Pisyong™
hahaha... yeah, i hope so... ill do that Iany... Thanks! =)
__________________
2nd Placer WorldCyberGames Team Philippines NFS MostWanted
_____________________________________
Intel C2 Quad Extreme QX6850 l Crucial Ballistix Tracer x4gB lEVGA 780i 3way SLI Mobo l TT Toughpower 1500W
EVGA 9800GX2 QUAD-SLI l Dell 2407 WFP 24" Wide LCD
Liquid Cooled
D-Tek Fuzion l Tygon 1/2 R3603 l EK MultiRes 150 Rev. 2 l PC Ice Coolant w/Pentosin G11 l Vista Ultimate x64 SP1
____________________________________________
Dell XPS M1330
T7500 | 3GB Ram | 250HDD 7200rpm | Slot Loading DVDRW | 13.3" Display Crystal LCD |
03-05-2008, 12:50 PM
#28
Fill your lavatory with water, take your PSU and turn it on with the pin trick
__________________
E6550
Asus P5K
EVGA 7900GS 256MB
2*1GB Team Elite 667mhz
Seagate Barracuda 320GB/80GB
Enermax Liberty 620W
03-05-2008, 01:42 PM
#29
That's pretty much what I'd say. Just connect some tubing to both inlet and outlet, give the inlet a source of water.....even a pitcher full or something like that would do.
Hook the pump up to the power supply (removed from your computer!) and short it on...jumping the green wire to any black wire in the 24-pin ATX motherboard power connector....paper clip works great for this.
If your pump is good, it'll start to work and pump out the water from your container. Turn off before container runs dry.....and be thankful.
__________________
Papa: Q6600 @ 3.6GHz @ 1.34V, Asus Maximus Formula, 4 x 2GB Mushkin Redline DDR2-1000, Asus HD4870, Antec Sig. 850, Lian-Li/RF case....WC'd via D-Tek FuZion w/quad nozzle, EK S-Max on NB, Laing DDC2 w/XSPC top, 2 x Feser 240's & one TC 120.1 rads.
Momma: Xeon 3210 @ 2.8GHz, Gigabyte P965-DS3, 4 x 1GB Ballistix DDR2-800, Asus HD3870 TOP, Enhance ENP5150-GH, Lian-Li/RF case, HK Champagne 2.1, Xigmatek HDT cooler
03-05-2008, 01:51 PM
#30
Originally Posted by Jedda
Thats why we leak test.
Good luck, buddy.
Thats why we clamp every hose, everytime
__________________
Phenom 9950BE @ 3.24Ghz| ASUS M3A78-T | ASUS 4870 | 4gb G.SKILL DDR2-1000 |Silverstone Strider 600w ST60F| XFI Xtremegamer | Seagate 7200.10 320gb | Maxtor 200gb 7200rpm 16mb | Samsung 206BW | MCP655 | MCR320 | Apogee | MCW60 | MM U2-UFO |
A64 3800+ X2 AM2 @ 3.2Ghz| Biostar TF560 A2+ | 2gb Crucial Ballistix DDR2-800 | Sapphire 3870 512mb | Aircooled inside a White MM-UFO Horizon |
Current Phenom overclock
Max Phenom overclock
03-05-2008, 02:01 PM
#31
any 12V power source will work for your pump. you don't necessarily have to use your PCs psu.
03-05-2008, 02:07 PM
#32
run the pump from psu power with the paper clip trick. with the inlet tube in some water aim for a friend then fire. on i side note next fill up with non-conductive fluid. it costs about the same but more peace of mind.
03-05-2008, 02:29 PM
#33
you can short your psu with the pump hooked up. Just get a large tub and have a tube stuck in the water in the tub hooked up to the inlet of the pump so it can suck water through and have it shoot back into the tub.
__________________
Pentium 4 3.2E (SL7PN E0) @ 4246.46 MHz (265.4 * 16) 1.48cvore
Intel Corei7 920 @ Stock (Still testing) - EVGA e760 x58 Classified - 6GB (3 x 2gb) GSkill Tridents @ Stock - BFG Nvidia GTX 295 - Creative X-Fi Elite - 4 x 74GB Raptors (RAID0) - 2 x 400GB WD - Antec TPQ-1200
Phase unit by runmc @ full load -33
H2O Loop - MCRes>AQ50Z>GTX295>PA 120.3>AQ50Z>PA 140.1
03-05-2008, 02:36 PM
#34
lol...
Is there an echo in here?
03-05-2008, 03:14 PM
#35
i didnt see there was a page 2 and just did a quick reply heheh
__________________
03-05-2008, 03:21 PM
#36
tl;dr
A 9v battery will be enough to make the pump rotate the impeller for a short period of time.
If the impeller rotates its probably fine, dont do it for more than about 1 second though. Dont need any water this way (though you can pour some into the inlet if you want).
03-05-2008, 04:29 PM
#37
Remember, a compression fitting probably shouldn't be used with normal clamps like a zip tie or a worm drive clamp. You are going to want to buy a normal barb fitting to replace one of the ones on the block that cant fit 2 compression fittings side by side when they have their retainer rings on.
So don't just go hooking everything back up with a zip tie or 2 on one of the compression fittings, it may not hold long.
03-06-2008, 12:48 AM
#38
and, never run it empty, even for few seconds
03-06-2008, 02:25 AM
#39
Dissasamble your pump and let all the parts lay on your desk to dry. I had dozens of leaks before, even so bad my x850xtpe was all covered with rust and still worked for about 4 months then I sold it for like 100$  and the guy was so happy with it and still is.
So to give you some faith. It probably will work again if you let it all dry and clean it much as you can  My 8800gts has a blue rusty spot too already, but it doesn't matter at all. If electronics get wet it doesn't mean a thing, only when the transistors on the top (where the cooler is) get wet (soaking wet I mean) then it can cause damage. Or if your pci slot has some water in it.
Give your XFI the same job as the pump / mobo. Just dissasamble all things and let it dry on your desk with a towel
cheers and good luck m8 I know how     ed up it is.
Bastiaan
03-06-2008, 08:33 AM
#40
Oh! Sad to know... hope everything fine dude...
__________________
When you do it right in the training, you can do it right in real life...
03-06-2008, 09:56 AM
#41
Guys, what would i do, i got the scenario 2? i think it is working but cannot suck water in high pressure...
__________________
Liquid Cooled
Dell XPS M1330
03-06-2008, 09:58 AM
#42
also found out that there are bubbles inside...
__________________
Liquid Cooled
Dell XPS M1330
03-06-2008, 10:07 AM
#43
Is it possible to get pump apart and try it then? Because it's moving a littlebit right? I think you should dissasamble the pump one time, make it proper and retry it. Can you do that or have you done that already?
03-06-2008, 10:22 AM
#44
@all
I Thank God for Allowing my pump to stay put... hahaa.. it is still up!! Wahoooo!!!
removed te hose and drained the pump, and blowing some air then tried it for the last time then it sucked water in very high pressure!!!
I Love You God!!!
__________________
Liquid Cooled
Dell XPS M1330
03-06-2008, 10:36 AM
#45
Now this time use clamps on your barbs or properly use the compression fitting. :P
03-06-2008, 10:42 AM
#46
Xtreme Waterbaby
Read this thread with oohs and ahhs.... glad it all went well. Just off the kiss my worm clips. The Smoke thing made me laugh.... reminds me of my former engineering colleagues
__________________
Respec'
System:Bunch of crappy overclocked PC's that cost an arm and a leg
"A Caesarean Milks Stops Wort"-anagram
03-06-2008, 10:00 PM
#47
Just curious, what type of coolant were you using? Distilled water?
Anyway, good luck, it looks like you will be able to save most if not all of it.
Utnorris
03-06-2008, 11:24 PM
#48
I am Xtreme
Don't know about you but distilled water only costs me about $1/gal @ Walgreens, compared to ~$12+/Qt for special fluids. Also, "non-conductives" are actually conductive resistant....not proof, they also don't stay "resistant" for any great period of time.
__________________
03-06-2008, 11:29 PM
#49
I am Xtreme
so did everything come out unscaved?
__________________
Originally Posted by skinnee
No, I think he had a date tonight...
He and his EK Supreme are out for a night on the town!
03-07-2008, 03:15 AM
#50
Still Up!
1. QX6850
2. Gfx Card
3. Pump
4. X-Fi
healing;;; and hope to be healed
1. Mobo
I used a PC Ice PrimoChill Non-Conductive w/Pentosin G11 UV Dye
__________________
Liquid Cooled
Dell XPS M1330
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
