Results 1 to 25 of 25
Thread: HD3780X2 Crossfire tests
    Nov 2004
    France
    8.47 RC3 driver used with special "HD3450"
    QX9650@4.7ghz
    Maximus Extreme
    Cellshock 14400
    2XHD3870X2
    3D05: 32564
    3d03: 114290
    3d06: 27067
    Great perfs playing COD4 always 92fps 1920X1200 4AA16Aniso no fps drop, can't wait the officials 8.3!
    i7 3960X@5ghz, Asus Rampage IV Extreme, 8gb Gskill RipjawsZ PC19200C8, Corsair force GT 240go, 2XGTX Titan, MM Ascension, Seasonic X-serie Gold 1250W, Watercooling
    i7 3930K@5ghz, Asus Rampage IV Extreme, 8gb Gskill RipjawsZ PC17000C9, OCZ Vertex 3 120go, GTX670 DCU2 Top, MM Pinnacle, Corsair AX850, Watercooling
    Aug 2007
    Montenegro
    WoW. Does your board have 2 native 16x PCIe lanes?
    When I purchased my board (Foxconn Mars) from newegg in specification section it showed PCI Express x16 2 so I thought I'm future proof. But then learned it is 16x and 4x.... Would you recommend having two of those babies for my board?
    Internet will save the World.
    Foxconn MARS
    Q9650@3.8Ghz
    Gskill 4Gb-1066 DDR2
    EVGA GeForce GTX 560 Ti - 448/C Classified Ultra
    WD 1T Black
    Theramlright Extreme 120
    CORSAIR 650HX
    BenQ FP241W Black 24" 6ms
    Win 7 Ultimate x64
    Xtreme 3D Team Member
    Jun 2006
    small town in Indiana
    you take a pretty good hit going to x4 bus. I would recommend you grab the new x48 from foxconn when it ships (soon). I have the DFI x-38 and also the p-35 both boards are basically identical except the x-38 has 2 x16 and 1 x4 pci-e slots (Gen 2.0 to boot) and with the X-38 @ 4500 MHZ I get better scores on 05 than with 4900 MHZ on the p-35
    awesome scores, like I posted in other threads I can get the option for crossfire but it is greyed out for me? I have diagnostics and configuration tabs but they are also greyed out? I installed as the 3450 and 3470 neither acted differently. GPU-z shows crossfire enabled (2GpUs) but shows clocks etc on the second card. riva shows no jump in clockspeed and 0.0 usage on second card also. same drivers as you.
    QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
    DFI LP LT X-38 T2R
    2X HD4850's water cooled , volt modded
    Thermaltake 1KW Psu
    4x Seagate 250GB in RAID 0
    8GB crucial ballistix ram
    Feb 2004
    Thousand Oaks, CA
    Wow...all on Vista...INCREDIBLE!
    I hope to see scores improve even more when as the drivers mature.
    Intel Xeon 3520 | eVGA Classified E759, GTX-285 SSC Tri-SLI | Corsair Dominator GT 2000Mhz 7-8-7-20 | Auzentech X-Fi Prelude | Intel 160GB X25-MG2 x 2, WDC 1TB Green Storage | Watercool HK 3.0, GPU-X² GTX285, MO-RA 2 Pro | Mips Chipset Kühler | Dual Laing 18w DDC+ | Corsair HX1000 | murderMod TJ07 #007 | Dell 3008WFP | Windows 7 Ultimate x64 |
    xwards
    Guest
    great results
    Feb 2007
    Great results and wow at the lack of people congratulating you.
    Xtreme Guru
    Jul 2004
    Quote Originally Posted by cognoscenti View Post
    are these at stock?
    congratulations for running 2 $450.00 video cards at stock speed.
    just joking
    seriously. I haven't tried to oc 2x x2's but I'm sure its the same method except it will show 4 in AMD GPU clocktool, see on device -
    BN:3, DN:0 = GPU1
    and BN:4, DN:0 = GPU2
    BN5 GPU3
    BN6 =GPU4? etc.
    try it.
    1. If you want to run fan at 100% download and install riva tuner 2.06 and do the following:
    x:\Program Files\Rivatuner 2.06\rivatuner.cfg
    Comparing files rivatuner_2.06.cfg and RIVATUNER_2.06_8800GTS_G92_3870X2_RV670.CFG
    ***** rivatuner_2.06.cfg
    G86 = 420h-42Fh
    G92 = 610h-61Fh
    ***** RIVATUNER_2.06_8800GTS_G92_3870X2_RV670.CFG
    G86 = 420h-42Fh
    G92 = 600h-60Fh,610h-61Fh
    RV630 = 9588h-9589h
    RV670 = 9500h-9501h,9505h,9507h
    RV630 = 9588h-9589h
    RV670 = 9500h-9501h,9505h,9507h,950Fh
    edit your rivatuner.cfg so it looks like the bottom entry, the important line is the rv670 one for you. Open notepad as Run as Administrator, open the rivatuner.cfg in x:\Program Files\Rivatuner 2.06, edit the RV670 line so it looks like this:
    save it close and restart riva tuner
    2. Download amd gpu clock tool here: http://www.nordichardware.com/skrive...kTool_v0.7.zip
    You will need to apply this patch to the root in AMD gpu tool before running the program. here: http://www.nordichardware.com/skrive...16/ToolLib.zip
    2. run AMD GPU clocktool, see on device - BN:3, DN:0 = GPU1 and BN:4, DN:0 = GPU2... BN:3, DN:0 = GPU1
    BN:3, DN:0 = GPU1 will show default clocks(825/900)
    3. select Bn4 core and type in your gpu and mem clocks and hit apply. then select the second Bn3 and do the same.
    Check your clocks by opening the thermal sensor tab and hit start. it will show current clocks for both gpu's and mem
    4. next try to max out each core ad mem by overclocking one slighty higher than the other core and running a benchmark like 3dmark 2006. if it fails then you will know which each core maxes out so you can get the optimal performance from the card. Do the same for the memory.
    Nov 2004
    France
    X2's are clock at 900/1120 for those screens. I know how to use amdgputool and riva thanks.
    Feb 2008
    Quote Originally Posted by pinto View Post
    dude where did you find this driver from
    Nov 2004
    France
    now i use standard 8.3 and scores are on par with RC3
    Feb 2008
    NICE!
    Xtreme Guru
    Jul 2004
    Oh why didn't you mention that in the 1st post?
    sorry. I didn't see the gpu clocks. and not everyone knows how to o.c 3870x2 just trying to help in case you didn't know.
    btw, were you able to clock any higher on other cores? or they are all 900/1120?
    example:
    my gpu0 maxes at 958.5 / 1143
    gpu1 945/1143
    Nov 2004
    France
    For now, first tests, i only try 900/1120 for all cores. I have to repair my cascade to test again at maximum clocks for cpu and gpu's. for now it's good enough to play every games at 1920X1200 and increase my hwbot profile.
    Jan 2007
    trans am can you adjust fanspeed for two 3870x2 in crossfire x with the latest riva 2.7.2.8?
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    nice 06 score.
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
    Xtreme Cruncher
    May 2007
    Conroe, Texas
    Quote Originally Posted by malik22 View Post
    The newest rivatunner adjust both cards fan speed and can OC also, at least it does on my rig...
    Jan 2007
    Quote Originally Posted by road-runner View Post
    Thanks is that on vista 64?
  18. #18
    Xtreme Cruncher
    May 2007
    Conroe, Texas
    Yes I am using Vista 64 Business...
  19. #19
    Jan 2007
    Thanks for your help road runner Im considering two of these just wanted to make sure I could adjust the fanspeed what temps are you getting with both cards?
  20. #20
    Xtreme Cruncher
    May 2007
    Conroe, Texas
    I have not really looked, I have not had much time to really mess with them much yet. I will be messing with them this weekend though...
  21. #21
    Nov 2004
    France
    Fanspeed is ajustable with riva but now i'm using watercooling.
  22. #22
    Jul 2003
    Nice rig & nice scores pinto
  23. #23
    Jan 2007
    And does the fanspeed stickfor both cards on every boot?
  24. #24
    Feb 2008
    COD4 has a default fps cap at 91 (or is it 85?). To watch your babies fly type this into concole /com_maxfps 333
    This is not a hack or any BS. Just a setting, some servers have their own setting limit to 250 or what ever they choose so you may have to turn it dowm a little.
    With 1 3870x2 I get up to 333 but often around the 200-250 mark.
    I only have a 19" screen so expect great things.
    Antec 900 || Gigabyte X38-DS4 || e8400 @ 3.6GHz || Sapphire 3870x2 || Beer fridge fully stocked
  25. #25
    Jun 2006
    Very Good score for 06
    My Computer: CPU Intel i7 920@4 ghz 1.35 volt. MAINBOARD Asus P6t dlx. RAM CSX 2000. VIDEOCARD EVGA GTX 295 . H.DISK 2 x WD VelociRaptor 74 GB @ Win XP SP3 . POWER Zalmann 1000 Watt. CASE LIAN-Li A70 . INTEGRATED WATERCOOLING CPU Couplex + Rad V3 + MP655 + Vaschetta dual 5,25 . SK VIDEO EK + Rad V2 + MP655 + vaschetta 5,25
