03-03-2008, 12:38 PM
#1
I am Xtreme
New Xigmatek BattleAxe Cooler
I reviewed this thing today for OCPulse. What a heatsink! Maintained a 57ºC load on my OC'd GTS 640.
The thing looks sick too.
I tested the BattleAxe on my eVGA 8800GTS 640MB video card. It is overclocked to 648MHz core, 1566MHz shader and 972MHz RAM. The RAM is vModded. I compared the BattleAxe to my watercooling system. I have an independent VGA loop, consisting of a BIX 2 radiator, D-Tek Fuzion GFX block & a Swiftech MCP-655-B pump. While this may seem unfair, I think it’s fair. We all know the Xigmatek would beat stock cooling by a huge margin, so I think it’d be more interesting to see how this air cooler does when stacked up against a real watercooling setup.
To generate a load, I ran a program called RTHDRIBL v1.2. I ran this program for ten minutes, at 1680×960 with 16x mutlisampling. I used RivaTuner 2.06 to read the temperatures after I had completed the test. Room temperature was taken into account when calculating ΔT (delta temperature). ΔT is the difference between two measured temperatures. In this case, it is measured room temperature vs. measured card temperature. I chose to use the ΔT between the two because it is far more accurate than measuring the temperatures of the card with each cooling solution without factoring in the fluctuations in ambient temperature that may occur.
Review Link: http://www.overclockerspulse.com/har...xe-vga-cooler/
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
03-03-2008, 12:52 PM
#2
Looks good, but it isn't half big!
03-03-2008, 01:13 PM
#3
Do you know if the Battleaxe mount on the newer 8800GT cards?
03-03-2008, 01:17 PM
#4
Xtreme X.I.P.
only bad thing is that for G9X GPUs is not compatible.
__________________
03-03-2008, 03:19 PM
#5
Is this the newer 8800GT card? new egg item N82E16814150252
I ordere 2 and they arrived today along with the battleaxe + other parts.
I can tell you if that will fit very soon =)
03-03-2008, 03:34 PM
#6
If I ever got that, the grill would meet my Dremel.
03-03-2008, 03:37 PM
#7
Hahaha I would say the same
03-03-2008, 04:53 PM
#8
I am Xtreme
I love the grill! You can remove it if you don't like it, very easily.
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
03-03-2008, 05:00 PM
#9
Xtreme Guru
gona put a bentley grill on there instead?
03-03-2008, 05:21 PM
#10
just confirmed, it will fit this card, but I run into another problem...
originally i was planning to run SLI 1 with this cooler one with original but the SLI bridge that came with xfx 780i is hard one and I don't have the clearance after installing the vga cooler, anyone where can I get a soft one?
atm my options are running it with just 1 8800gt forget about SLI or use 2 stock coolers which I don't want....or I can find the soft bridge!
03-03-2008, 05:22 PM
#11
Admin
Bedazzle that grille
What fans does it use?
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
03-03-2008, 06:45 PM
#12
I am Xtreme
Probably Xigmatek branded ones. 92mm, 40cfm, 25dBa.
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
03-03-2008, 07:43 PM
#13
Xtreme X.I.P.
Be careful, Xigmatek themselfs told me it wont work with any G80 deribate without the IHS on the GPU, that is 8800 Ultra, 8800GTX, 8800GTS 320 and 8800GTS 640. It wont make good contact
__________________
03-03-2008, 09:40 PM
#14
Nope, go grille-less
03-03-2008, 09:49 PM
#15
Phazers on Stun
__________________
HEAT
03-04-2008, 02:56 AM
#16
wow. I want one!
__________________
MotherBoard: GigaByte G33M DS2R
Memory: 2x1 Gb HyperX DDR2-9600, 1200 Mhz
Cpu: Intel e2160 @ 3,6 Ghz on Air
Vga: XFX 4870 XXX
Cooling: Ninja Mini, 2x Ximatek 120mm, 1x Zalman 80mm , Stock Gpu
Case: Antec Fusion Remote
03-04-2008, 04:01 AM
#17
I am Xtreme
Xigmatek on their site says its compatible with X1900 series, etc. That's direct die?
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
03-04-2008, 06:03 AM
#18
Xtreme Cruncher
@NickS - WOW. What were your temps at stock? It looks really good, but how much do the grills restrict airflow?
03-04-2008, 09:04 AM
#19
I am Xtreme
Only tested with the card OC'd but I'd guess 53-55 load @ stock clocks. Even with the grille in place there was a LOT of airflow.
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
03-04-2008, 09:16 AM
#20
any reviews by someone who got it?
03-04-2008, 09:31 AM
#21
I am Xtreme
Heres some results with an SPL meter. This was really close.. ~1ft.
That would be roughly 57 dB @ ~1ft. At about 3ft away it was less than 50 dBa.
Heres a video of it as well.
http://nickfire.com/public/xigma/xigma.avi
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
03-04-2008, 09:38 AM
#22
nice NickS! i wonder if it's better than Thermalright?
03-04-2008, 09:44 AM
#23
I am Xtreme
I think it'd be real close in performance. I like the way this looks and mounts a lot better.
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
03-04-2008, 11:13 AM
#24
Looks sick
__________________
CPU: Lapped Q6600@ 3.42Ghz (8x438) 1.35v (Load)
Memory: 2x1Gb Crucial @ 876 4-4-4-12 2.2v
Graphics: GeForce 8800GTX(648/1560/2000)
Board: Asus P5Q-PRO
HDD: Western Digital 160 Gb + 640Gb WD6400AAKS
Video: Samsung 226BW
Sound: X-fi XtremeGamer
Power: Corsair HX520W (Modular)
Case: CM690 with Zalman ZM-F3's on a Rheobus
What is the Internet?
FEAR 2! Woo!
03-04-2008, 12:22 PM
#25
Originally Posted by Craftyman.
Looks sick
I am still installing the thing, I need to wait on the soft SLI cable or I can only run with 1 card if battle axe installed.
I do realize they come with a heatsink in the package, I think thats suppose to be the headsink you need to put on the small gpu before installing the battle axe.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
