XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Graphx Vmods
Reply
Old 03-06-2008, 11:21 AM   #101
Zeus
Xtreme kickass
Zeus's Avatar
Send a message via ICQ to Zeus
Originally Posted by trez0r View Post
Is he running reference card or is it with custom pcb w/ 3 phases?
Eh, i'm still patiently waiting for what is i guess OCP mod..
EDIT: On the other hand maybe there is no workaround on this black screen problem and maybe it's just because of weak power phases on reference design. Tho hope dies last.
Erm...
vvikoo's 9600gt is not reference desgin,
exclusively has hdmi,displayport and 3phase PWM for GPU.
I didn't know there was a difference.
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
Zeus is offline   Reply With Quote
Old 03-06-2008, 11:50 AM   #102
LyP0
I did the mod today and mine also craps out as soon as I put the vr on. This is just anoying.
Stock it gets 1.1-1.11v and when i put the vr on the voltage is 1.15. I cant even be in windows for more than a few seconds.
This card is rapidly turning into the most f***ed up thing i've bought
__________________
cpu : e6850 @ 3.5ghz
cooler : boxed
mem : balistix 8500 @ 1000mhz 4-4-4-4
board : asus p5k-e wifi
graphics : 7800gtx
harddisk : wd raptor 74gb
dvd : nec 7173A
dvdrw : optiarc 18x
psu : enermax liberty 620W
screen : dell 3007wfp hc
LyP0 is offline   Reply With Quote
Old 03-08-2008, 04:16 AM   #103
Xargo
I tried to ground the pin #35 today and it seemed to work, sort of. I ran some benchies but the card power line components quickly turned very hot and started to produce a pitched sound and this was only with 1.25V (3d) voltage and 775 clock. But maybe this is good news to people using extreme cooling?
I guess I'm stuck to 800/2000/1107 clocks with this card.
Xargo is offline   Reply With Quote
Old 03-10-2008, 04:23 PM   #104
trez0r
Nothing helps my card. Tried grounding pin35 (VID5) as Xargo suggested - same black screen.
Xargo may i ask you why exactly vid5? There are VID0-VID6 - why exactly VID5?
trez0r is offline   Reply With Quote
Old 03-10-2008, 10:35 PM   #105
Xargo
It was as largon suggested here:
Originally Posted by largon View Post
Yes, the mod works alright.
According to the datasheet of ADP3207, disabling OVP should be very simple: pin #35 (on ADP3208A) to ground using just a jumpwire.
But anyway, I suspect it's the power phases holding this card back. Looks like if you want to have a nice overclock, better not get the reference design. I'm thinking step-up to 9800gtx or some such. Should have plenty enough power headroom at least =)
I'm just a little bit disappointed with my 9600 considering I was able to run 8600gts @ 1.666V \,,/ with only air cooling. Not a reference design though. Now I'm going to sell it.
Old 03-11-2008, 11:08 AM   #106
Fr3ak
OC Jedi
Fr3ak's Avatar
Send a message via ICQ to Fr3ak Send a message via MSN to Fr3ak
I tried a quick and dirty VGPU mod and it doesnt work. OVP or whatever seems to kick in at about 1.18V. Funny is that the card has 1.01V for bootup and 1.11V once it loads the driver. 1.13-1.15V is the voltage under load.
__________________
オタク
"Perfection is a state you should always try to attain, yet one you can never reach." - me =)
Fr3ak is offline   Reply With Quote
Old 03-12-2008, 03:13 AM   #107
Xargo
Good news!
I tried modding the voltage settings in bios today. I was able to boot the system @ 1.52V (1.58V 3d) and run these tests (one by one) in 3dmark06:
Fill Rate - Single-Texturing 6625,231 MTexels/s
Fill Rate - Multi-Texturing 21136,088 MTexels/s
Pixel Shader 414,076 FPS
Vertex Shader - Simple 225,755 MVertices/s
Vertex Shader - Complex 173,459 MVertices/s
Shader Particles (SM3.0) 128,667 FPS
Perlin Noise (SM3.0) 126,964 FPS
Clocks were 875/2150/945. Somehow the gpu overclock resulted in poor memory overclock and 999 mem crashed the tests instantly, vmem was 2.075V.
The stated voltage was achieved together with the 1.2V vid-mod so I have no idea what voltage the card would run if you just flashed my modified bios without any mods. In case someone wants to give it a try, I put it online here:
http://www.hut.fi/~hjkauhan/9600mod.rom
If you try it out, please report what voltage you get. Just be careful with the 1.58 vgpu, the core reached 103C in multi-texturing test with a VF-900cu cooler.
Old 03-12-2008, 06:57 AM   #108
trez0r
I doubt the bios will help me, but thx i will try it.
Can you run atitool artifact scanner too at those frequencies?
Did you measure the voltage with DMM?
edit: the bios file you supplied is with the default voltage setting.
Old 03-12-2008, 08:23 AM   #109
Xargo
Atitool has never worked for me even with default settings with any of the three geforces I have (6800u, 8600gts, 9600gt). I gave it a go anyway and it crashed instantly when I started the artifact scan.
Here's a photo of the voltage reading in idle:
That's strange. I haven't tried it without the 1.2V vid mod though. When looking at the vid-table, going from 1.2V to 1.5V would require going from 0011000 to 0000000. So one explanation could be that when you have default settings ( 0100000 ), the bios switches the vid4 and 3 to "0" but they are "0" already so nothing happens. Could this explain what's happening here?
If it works like that, I could try out 1.1125V ( 0011111 ) which would (hopefully) result in 1.4125V ( 0000111 ).
edit: Ok, I didn't think it all the way through... we only have knowledge of vid2-5 resistors so I can't set 0011111. So I tried setting 1.15V ( 0011100 ) and with my modded bios the multimeter now shows 1.48V. Time for some benchmarks.
Old 03-12-2008, 09:43 AM   #110
fatbird2046
fatbird2046's Avatar
Send a message via ICQ to fatbird2046 Send a message via MSN to fatbird2046
We should focus on OCP or something else,they are the main problems we meet.But dont give up so easily.
2-phase design is not so weak, Just think about 8800GT reference card,it's 2-phase design too!
fatbird2046 is offline   Reply With Quote
Old 03-13-2008, 03:59 AM   #111
Fr3ak
OC Jedi
Fr3ak's Avatar
When I try to boot with more than 1.2xx Volt with just the VGPUmod, the card shuts down immediately after a few seconds.
__________________
オタク
Old 03-13-2008, 04:09 AM   #112
largon
Xtreme Guru
largon's Avatar
Fr3ak,
Have you tried to disable OVP by grouding pin #35 on ADP3208A?
__________________
You were not supposed to see this.
largon is offline   Reply With Quote
Old 03-13-2008, 12:57 PM   #113
Boogerlad
http://www.galaxytech.com/Product_De...ass1=1&class2= any one know a vmod for that?
Boogerlad is offline   Reply With Quote
Old 03-13-2008, 01:18 PM   #114
wittekakker
wittekakker's Avatar
Send a message via MSN to wittekakker
Jups, I'm having the card right here, voltmods ready. I can't share them for now, I first have a friend picking up the card and test out how it overclocks. They will be online soon, don't worry.
__________________
wittekakker is offline   Reply With Quote
Old 03-14-2008, 03:35 PM   #115
op1e
op1e's Avatar
So still no-go on just a modified bios, then?
__________________
EVGA 780I P02bios
E8400@3.6
BFG 9600gt SLI 710/1000
2x2g GSkill ddr2
Sceptre 20.1 naga
Antec SP500/TT Sli psu
op1e is offline   Reply With Quote
Old 03-18-2008, 03:24 PM   #116
trez0r
I guess we are stuck here with OCP.
@Fatbird - have you found anything interesting out yet?
Nowhere on the internets is any information on how to mod the OCP on 9600gt. In fact many people have problems with factory overclocked cards on reference design which has been called the black screen - the same thing which happens when we slightly increase the voltage and try to up frequencies (and even when not increasing the voltage but upping the gpu/shader freq.).
Atitool artifact scan is a beautiful test to see the black screen in action immediately almost every time.
Old 03-19-2008, 12:38 PM   #117
largon
Xtreme Guru
largon's Avatar
Got bored with my G92GTS which is overkill for my needs anyways, so I decided to downgrade and save some $$$ and ordered a Palit 9600GT. It's a non-reference btw.
I guess I'm gonna have to warm-up my soldering iron again. :p
__________________
Old 03-20-2008, 02:50 AM   #118
trez0r
Nice!
But sad that it is not reference, then you would prolly come up with some ocp mod.
Anyways gratz and keep us posted.
Old 03-20-2008, 12:09 PM   #119
Lanc
Lanc's Avatar
Originally Posted by Boogerlad View Post
I have this card and know vmem mod - it is pretty easy, pencil vmem
Do you try voltmods ?
I think i found a place to pencil to increase vGPU, but when i make ~1.17v (and up, max i tried was 1.25) on GPU i have many artifacts in 3DMarks. 2D and Ati Tool Artifacts Scan are clear
__________________
E8400 :: P35 :: G73 :: 2x1GB :: Corsair 520HXEU :: Firefox :: Tlen :: NOD32 ::
Lanc is offline   Reply With Quote
Old 03-20-2008, 01:58 PM   #120
kaptan54
kaptan54's Avatar
pls show us pencil mod point..
kaptan54 is offline   Reply With Quote
Old 03-22-2008, 06:31 AM   #121
Lanc
Lanc's Avatar
Here we are ;]
vMEM def - 1.95v - max 2200Mhz - ATITool artifact scan free
vMEM - 2.06v - max 2300Mhz - ATITool artifact scan free
__________________
Old 03-22-2008, 07:22 AM   #122
massman
www.hwbot.org
massman's Avatar
Send a message via MSN to massman
If you're talking about the Galaxy ... I'm the one who was pciking up that card and seeing how it overclocked. Voltmods work perfectly, at stock clocks I'm able to go upto 1,67-1,7 volt before the screen goes blank.
Now running 850/2150/1120 stock cooling at 1,41v/2,1v
massman is offline   Reply With Quote
Old 03-22-2008, 07:28 AM   #123
Lanc
Lanc's Avatar
Can you show us a vGPU mod for Galaxy ? ;]
__________________
Old 03-22-2008, 08:29 AM   #124
wittekakker
Soon, have some patience please, massman is still testing his card
__________________
Old 03-22-2008, 08:58 AM   #125
massman
www.hwbot.org
massman's Avatar
Ln² comes next wednesday, so I hope to get the article ready in about a week ...
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
