XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 02-12-2008, 11:28 PM   #1
AuDioFreaK39
The generation of 2010
AuDioFreaK39's Avatar
Send a message via AIM to AuDioFreaK39 Send a message via MSN to AuDioFreaK39 Send a message via Skype™ to AuDioFreaK39
Wink Celeron 430 @ 3.33GHz on air
So as I've been waiting patiently for the launch of the Q9450 (or am I?), I decided to pick up a $42 dollar Celeron 430 to keep me going for the past 2 months. To my surprise, I managed to get the thing up to 3.33GHz 24/7 on stock cooling (with a Q6600 heatsink that is). I was wondering if these speeds are any good, or if I should even attempt going higher
Abit IP35 Pro v1.1
Celeron-L 430 (Core 2) @ 3.33GHz
4GB (4 x 1GB) Crucial Ballistix Tracer DDR2 8500 @ 925MHz 4-4-4-10
eVGA 8800Ultra @ 660/2330
AuDioFreaK39 is offline   Reply With Quote
Old 02-12-2008, 11:39 PM   #2
Sav
Sav's Avatar
nice, what's your max fsb?
Sav is offline   Reply With Quote
Old 02-12-2008, 11:49 PM   #3
AuDioFreaK39
I'm pretty sure its 372, which would explain why it's so difficult to get past 3.33GHz. Then again, I could probably up the voltage more to find out, but I'm good
Old 03-26-2008, 07:03 PM   #4
r4zor
I think its impossible to be 372....celeron 430 can make a high % of overclock...
sun, I will buy one...then I post my results
fsb hole...wrong voltages....
but I think its impossible only that fsb
regards
r4zor is offline   Reply With Quote
Old 03-27-2008, 01:23 AM   #5
Sav
Sav's Avatar
I had 2 celron 420, first run 385x8, second 380x8
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
