XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme News
Reply
Old 02-01-2008, 11:58 AM   #26
mrcape
mrcape's Avatar
I don't really give a $hit about the temp sensors, it's the degradation reports from guys using only 1.4v and less that worries me.
__________________
mrcape is offline   Reply With Quote
Old 02-01-2008, 11:58 AM   #27
Brother Esau
D.F.I Pimp Daddy
Brother Esau's Avatar
I think Intel is lying to you boys Did I just say that
__________________
D.F.I LanParty DK 790FXB-M3H5 ~ 7/27/2009 ~ "Beta" Bios
AMD Phenom II 720 Black Edition ~ For Bios Testing
Custom Water
2x2gb Crucial Ballistix Tracer 1333mhz 6-6-6-20
POWERCOLOR AX3870 X2 CROSSFIRE
ULTRA X3 1000w
Danger Den Torture Rack
Wilmington Computer Repair
Brother Esau is offline   Reply With Quote
Old 02-01-2008, 12:03 PM   #28
informal
AMD™ 10h&RV770 cruncher
informal's Avatar
I was wondering about that one too.Can you post some links for the reports ,please?
__________________
Quick dictionary lesson:Bulldozer : n. 1. A multi-threaded performance-oriented x86 processor core contained in the “Zambezi” processor for client PCs and “Interlagos” and “Valencia” processors for servers. Included in the “Scorpius” desktop PC platform and “Maranello,” “Adelaide,” and “San Marino” server platforms. “Bulldozer” will be a completely new, high performance architecture for the mainstream server, desktop and notebook PC markets that employs a new approach to multithreaded compute performance for achieving advanced efficiency and throughput. “Bulldozer” is designed to give AMD an exceptional CPU option for linking with GPUs in highly scalable, single-chip Accelerated Processing Unit (APU) configurations. 2.A heavy, driver-operated machine for clearing and grading land, usually having continuous treads and a broad hydraulic blade in front 3. An overbearing person; a bully.
informal is offline   Reply With Quote
Old 02-01-2008, 12:15 PM   #29
mrcape
mrcape's Avatar
Well informal, they aren't officially reports, but symptoms reported. I can poke around and find some links if you'd like. There were posts on this site about it. Of course, it was brushed off as a PSU or CPU issue lol. There was also a poll going on at some greek forum that had interesting results showing degradation over a week or so of time with low~medium volts.
The idea of what high volts are goes out the window as it should with this new architecture. I think it totally skews the current methodology of how to get a good, safe over clock. That's why I don't see why people think the current board and bios offerings make any sense. Sure 45nm can run on them, but it's starting to seem like putting a porche engine in a mustang body.
This is sorta bringing up a chicken before the egg argument. So what side is everyone taking? Are these new chips designed for todays boards and chipsets? Are todays boards and chipsets designed for yesterday's chips? Does fancy cooling matter as much anymore?
__________________
Old 02-01-2008, 12:31 PM   #30
informal
informal's Avatar
Thanks for the informations mrcape.
It sure sounds like electromigration effect,but i must say i'm a bit sceptical about it happening in "weeks time-frame".I would've expected it to show up after several months of heavy overvolting(>1.5V),not in weeks time.
Could it be that since the increased stress on the VRM(after excessive OCing),some of the components of the mobos started to fail?It would have looked like you described it.But if the chips(in question) experienced the same behaviour in a brand new motherboards,then it would mean sure degradation.Also like you said,it could be PSU failing,too.
If you get a hold of some links,post 'em up please.Thanks .
__________________
Old 02-01-2008, 12:38 PM   #31
STaRGaZeR
Xtreme Mentor
STaRGaZeR's Avatar
And somewhere in this forum you talked about AMD thread crapping... well done brother
__________________
Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
STaRGaZeR is offline   Reply With Quote
Old 02-01-2008, 12:45 PM   #32
zakelwe
Xtreme X.I.P.
I agree with Vapor we are getting too hung up on temps and VID's and pack dates and week this that and the other. Just bench it and see how you go. You'll either be lucky or unlucky with the cpu you have.
As for degredation I'd like to see a mass of people on XS get it first rather than rumours from a Greek forum etc. It is true though that this is a new process using new metals and we are sticking 50% more volts through a cpu which has smaller surface area, so if you need a long lived chip then just give it 1.3v and hit 4Ghz or abouts. That's still not shabby.
But if you are XS then stop whinging about things and just do it. I'm doing 4.5GHz plus at 1.55v.
On a stock Intel heatsink.
Which aint bad at all......
Regards
Andy
zakelwe is offline   Reply With Quote
Old 02-01-2008, 12:55 PM   #33
mrcape
mrcape's Avatar
And snap into a slim jim!
__________________
Old 02-01-2008, 01:16 PM   #34
LowRun
LowRun's Avatar
Accurate temps reading is meaningful data.
LowRun is offline   Reply With Quote
Old 02-01-2008, 01:34 PM   #35
FUGGER
Xtreme Owner
FUGGER's Avatar
Send a message via MSN to FUGGER
VTT / FSB voltage will cause the cpu to overheat if it is up too high.
__________________
Intel I7 980X
Asus Rampage 3 Extreme
GTX 480 SLI
Corsair Dominator 6GB 2250C8
Corsair Force 120 SSD RAID 0
Corsair HX1200
FUGGER is offline   Reply With Quote
Old 02-01-2008, 02:28 PM   #36
Hornet331
Xtreme Guru
Hornet331's Avatar
Send a message via ICQ to Hornet331
no disrespect, but i dont think much users that oc actually touch more than vmem and vcore (maybe vmch and vpcie).
Anyways it could be very well true, that high VTT/FSB voltage increases the temprature.
Hornet331 is offline   Reply With Quote
Old 02-01-2008, 03:15 PM   #37
Plywood99
Xtreme Cruncher
Plywood99's Avatar
Send a message via MSN to Plywood99
Not to beat a dead horse here but this is something I said well over a year ago. Temp does not matter. What matters is stability. If your stabil then your overclock is good...
Ply
__________________
Antec 900 Case
Q6600 SLACR @3550 / Giga P35 DS3R
Cooler Master Hyper 212/ PCP&C Quad 750
4 gigs G.Skill PK series
BFG 8800gt / Thermaltake DuoOrb GPU Cooler
X-fi pci-e / Logitech Z5300
Plywood99 is offline   Reply With Quote
Old 02-01-2008, 03:55 PM   #38
R101
2 x E8400@1.425v, 4 GHz 24/7, TT BT VX = 0 problems.
If they die, I'll report here.
R101 is offline   Reply With Quote
Old 02-01-2008, 04:03 PM   #39
kiwi
xtreme energy
kiwi's Avatar
Send a message via MSN to kiwi Send a message via Skype™ to kiwi
Running @ 1.45V for 2 weeks so far fine. Temps ~40C till TJmax Heatpipes are cold
AUTO sometimes might be even worse because MB itself sets too high value if you overclock
__________________
kiwi is offline   Reply With Quote
Old 02-01-2008, 04:10 PM   #40
JumpingJack
Xtreme Mentor
Reading over the forums (briefly) sounds like what we see with Everest with Phenom before the recent build or with CoreTemp with Brisbane... there is no official support from AMD or Intel on providing information on the DTS other than what the author of CoreTemp has extracted for C2D's...
It could be that the calibration algorithm has simply changed or that the wrong MSRs are being read, and the legacy MSRs are just getting the wrong digital value.... this is probably nothing at all, other than the Inquirers seemling clocklike attempt to smudge/blackmark any Intel new release by digging around in the forums.
Then again, there could be a problem with the DTS and temperatures are better taken from the socket than at the core.
__________________
".. an ounce of honest data is worth a pound of marketing hype." - Spec.Org
JumpingJack is offline   Reply With Quote
Old 02-01-2008, 04:13 PM   #41
JumpingJack
Xtreme Mentor
It is not electromigration that should be a concern with respect to the newness of this product, but TDDB.
(If I read the context of your refrence to EM correctly).
If there are people concerned about a safe overclock, my advice would be never exceed the Vmax spec'ed by Intel... as this is the spec that Intel states the CPU can handle.
__________________
Old 02-01-2008, 04:17 PM   #42
Hornet331
Xtreme Guru
Hornet331's Avatar
yeah i agree, but most go manual anyway so VTT/FSB stays the same.
Old 02-01-2008, 04:43 PM   #43
mrcape
mrcape's Avatar
Yeah how could you go auto with vtt/gtl if it's (auto) designed for 65nm which needs more? For me, setting it lower made all the difference in getting a stable setting at or over 4ghz.
This is a great paper. I'd like to see a continuation with present day examples (boards/chipsets/chips).
__________________
Old 02-01-2008, 06:13 PM   #44
TopherTony
TopherTony's Avatar
How to figure out if you have a bad sensor:
1. Attach ln2 tube
2. Top off tube with LN2
3. Check sensor
If it says it cold bugging and registers as 48C, bad sensor
__________________
My Custom Pressure/Temperature Charts for Various Refrigerants
QX6700 @ 3900 | EVGA 680i |2 GB Corsair 8500 Dominator | 7800 GT SLi | Silverstone 1KW | Seagate 7200.9 Barracuda RAID 0 + Hitachi Deskstar 2TB RAID 0 | SS Phase w/ Cryostar Evap | MIPS Full Motherboard cooling
My Fake Quad Core is better than your real Quad Core! **cough**Barcelona**cough**
Lian Li Cube Case with Phase and Water DONE!!
TopherTony is offline   Reply With Quote
Old 02-01-2008, 07:13 PM   #45
mion
mion's Avatar
On my board in windows core temp reports 42c minimum temp no matter what, load are 51 core 0 and 61 core 1, that's at 4ghz. On the other hand gigabyte's cpu utlity reports 30 idle and 51 load. Cpu doesn't experience any problems beside one, C1E when enabled crashes system.
mion is offline   Reply With Quote
Old 02-02-2008, 12:22 AM   #46
emoners
emoners's Avatar
is the temp sensor prob only with E8400s? how about E8200 & E8500?
__________________
ZOTAC® GeForce™ 9300-ITX WiFi Rev.01 (+ Noctua® NC-U6) | Intel® Core2Quad™ Q9400 L910B375 (+ Corsair® H50)| OCZ® NVidia SLI-Ready DDR2-6400 2x2Gb | PowerColor® ATI™ Radeon HD4770 | Western Digital® Caviar™ Black 1Tb | Silverstone® Sugo™ SG05 | Windows® 7 Ultimate 32-bit
RETIRED: DFI® LanParty™ UT P35-T2R Rev A02 (05/21 Bios) | DFI® LanParty™ JR P45-T2RS Rev A03 (10/07 Bios) | Intel® D945GCLF2 Little Falls-2 | Intel® Core2Duo™ E6850 L723A348 | Intel® Core2Duo™ E8400 Q746A446 | Intel® Core2Quad™ Q6600 L723B837 | Intel® Core2Duo™ E7400 3849A508 | Intel® ATOM™ 330 | XFX® NVidia™ GeForce 8800GTX | XFX® NVidia™ 8800GT XT Alpha Dog Edition | Creative® Sound Blaster™ X-Fi Fatal1ty XtremeGamer Pro
emoners is offline   Reply With Quote
Old 02-02-2008, 12:47 AM   #47
cadaveca
xtreme member
Send a message via Skype™ to cadaveca
I'm concerned about temp readings on these cpu as mine HAS degraded over the space of a week, with 4ghz first requiring 1.3375, and now requires 1.3825, 4250mhz used to require 1.425, now requires 1.4625.
Loss of clocks happened over the space of a day..one day i primed 4ghz for 12.5 hrs, and when done, went up to 4.25ghz, again primed for 12 hrs.
Left the systems on idle, came back, it wasn't stable. Prime would not run for more than 1 minute.
I spent some time verifying the board was ok, that ram was not the cause, all parts proven stable using other components.
So, during this, cpu was under fuson block in Maximus Formula SE. I never mounted cpu with aircooler. But temps never budged from 35c CPU and 40c DTS0 and DTS1.
So, on air, temps went over 70c DTS at stock, which seems a bit high for 45nm, but oh well.
I'll be checking throttling next time I get a chance...I don't think it's an issue tho...
And I'm sorry, but "stable" isn't good enough for me. Stable can include TM1/2 throttle, with no notice given to user, without knowing what to look for. Without accurate temp readings, it's impossible to verify that throttle is an issue without specific software, and hence my need for such temp readings...it's nice to know how far away you are...
cadaveca is offline   Reply With Quote
Old 02-02-2008, 04:20 AM   #48
saaya
Xtreme X.I.P.
saaya's Avatar
Send a message via MSN to saaya Send a message via Yahoo to saaya
no hw mfg actually advertizes or guarantees a thermal diode to work properly.
you could have a cpu or gpu or other chip with defective temp reading and it would not get rma'ed
saaya is offline   Reply With Quote
Old 02-02-2008, 05:19 AM   #49
Ugly n Grey
Unbanned for Life
Ugly n Grey's Avatar
Send a message via MSN to Ugly n Grey
I agree with you. So how do we go about getting accurate on die temp readings? maybe they could leave a hole in the IHS so we could use our own thermal probes.
__________________
"Foldin, Foldin, Foldin...keep those benchers foldin..." (Lyrics by Angra, Music is Rawhide)
BOYCOTT MIR's
Originally Posted by Monkeywoman View Post
aww an OC virgin! lose it tonight with Xtremesystems!!!
Ugly n Grey is offline   Reply With Quote
Old 02-02-2008, 05:30 AM   #50
lapdog
The thermal diode could only be calibrated for stock voltage anyway.
__________________
= P5WDH - E6600 - Tuniq Tower - 2GB STT PC6400 - 8800GT - Real Power Pro 850 =
lapdog is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
