Intel E8400 @4.3ghz (Q745A576)
DFI LP DK P35-T2RS
GSkill F2-8000CL5D-4GBPQ
Visiontek HD4870 830/1100
Xclio Greatpower 600w
Thermalright Ultra-120
E8400@3.6ghz 1.11v |Asus P5E3 deluxe bios 1001| 2 giga Cellshock DDR3 12800@1696mhz|Samsung Syncmaster 2232BW 22' | Asus 8800 GTSē 512 TOP|Western digital sata 500 SE16 | Blu Ray LG GGW-H20LRB| Creative X-fi platinum|Nexus 600W | case Coolermaster 1000 "Storm"
Xeon E3110@3.6ghz 1.15v|Asus P5K premium "blackpearl" bios 503|2 gigas Cellshock DDR2 8500 |Twintech 9600 GT|nec 1970 GX|Gigabyte 3D aurora case
E8400(Q804A249) valid@ 4.8 ghz 1.56v
Xeon E3110 (Q746A534)valid@ 4.79 ghz 1.59v real bios AIR /superpi 1m@9.968 .. under vista
My Ibanez 540S " Saber "overclocked with Di Marzio and Sperzel
My cousin on drums Hi Brian !
Just got in a retail E8400 today from mwave.com. Pack date is 3/27/08 so it's ultra fresh. Currently priming at 3.83ghz (425 * 9), 1.25v in bios on a DFI P35 UT T2R. It primed fine at 3.6ghz stock voltage but only for about 10 minutes before I wanted to try higher.
I'll post back later with further results.
Gaming Box
Asus P6T Deluxe V2 | i7 920 D0 @ 4.3ghz 1.37v (HT off) | Thermalright TRUE | 3x 2GB Corsair XMS2 PC12800 @ 820mhz (2:8) 9-9-9-24 | eVGA GTX 280 | 2x Intel SSD G2 80GB RAID 0 | Audigy X-Fi XtremeMusic | Silverstone Olympiad 650 | Antec P-183 | Dell 3007WFP | NEC 20WMGX2
Home Server
Asus P5W DH Deluxe 2704 bios | Q6600 @ 3.0ghz 1.3v | 4x 1GB mixed G Skill / Corsair @ 5-5-5-15 | GeForce 8600GTS | 2x 150GB WD VelociRaptor raid 1 (os), 6x 750GB RE2 on RR 2320 in raid 5 (3.41TB) | Corsair HX750
Alright... so I thought I would try to see how low I could go. This is about it... cant really remember what I set it to in bios but this is what it reads in cpu-z under load. Sniggle.... try 1800fsb. I couldnt get it stable below 1.38+ in bios.
EVGA 780i--E8400 @4.05Ghz--TRUE--EVGA GTX760 4GB--4X2GB PC6400 REAPER 4-4-4-15-2T @800mhz--150 RaptorX--PCPC 750 silencer--Antec 900
It's not that I wasn't stable at 3.6; it's that I didn't give it a chance to fail. I knew this chip could do better.
Now priming at 4.05ghz @ 1.33v in bios. When I tried 4.2 it would not even do one iteration of prime before failing even at 1.36v so I knew I was hitting the point of diminishing returns. I might try to optimize further to get 4.2 stable but 4.05 was my goal so I'm good here for now.
Gaming Box
Home Server
Hello, my first post on this forum so i hope it's gonna be a good one. Yesterday I've installed a Scythe Ninja Plus so i wanted to see what can my e8400 do. The FPO is Q746A496 and it's pack date 1/31/08. Tell me what do you think about the temperatures and give me tips because i need them . I know it should be a 1 hour Orthos test, but i got bored after 10 minutes .
I am going to settle on 4.15ghz @ 1.4v for now. It's needing way more voltage to get any higher. This setting is prime (small fft) stable for 9.5 hours which is good enough for me. I might actually be able to get away with lower voltage since I made a fairly random jump to 1.4 after 1.38 didn't work @ 4.2ghz.
The chip is a SLAPL, FPO is Q802A321
Gaming Box
Home Server
IP35-Pro
E8400
EVGA 8800GTS-512
2gb BallistiX PC8500
2 150gb Raptors in raid0
GA EP45-UD3P (r1.6) work in progress
Q6600 @ 3.6ghz w/Thermalright Ultra Extreme 120
Patriot Viper PC8500 2x2gb
The temps on this chip are way out of kilter.
With realtemp, idle is high 40's but load is only a couple of degrees higher.
I was able to oc to 3.6 at auto voltage (little over an hour of orthos so far)
The VID on this chip is 1.0625 (not sure if that is good or not though)
Are the temps actual? I have a lapped thermalright ultra 120 e with a monster fan on it. With my Q6600 overclocked to 3.2, idle was around 34c or less on cores and load maxed out at 52C and downwards.
Intel i7 2600k , Asus P8P67 Pro, G.Skill Ripjaws 2x4 GB 1600 Mhz, MSI GTX580, OCZ Vertex II 128 GB Extended, X-FI Fatality Pro, Pioneer DVR-212DBK, CM HAF-X, Seasonic M12D 850, Corsair H70, Win 7 64 Home Premium.
IP35-Pro
E8400
EVGA 8800GTS-512
@ Robilar: Mine idles at 34c no matter how low I go. For example my o'c 4.05ghz 1.38v idles 34c. My 3.6ghz 1.2v idles 34c. I have non-lapped TRUE. I say just make sure it's mounted solid and you should be good.
@ ovidiu: 10mins means jack IMO. I've ran solid for 45mins and gotten errors after that. I would say IMHO that 2 hours is proof of stability. Anything shorter just doesn't cut it in my book. Post back with a 2 hour stress or longer for stability praise
@ sniggle. That's rock solid stable IMO. What is memory set to? Linked/unlinked? all other settings. I've had a hard time above 1800mhz FSB. Actually I was stable for 10 hours Prime95 @ 1800mhz, 1.375v and when I did orthos I was failing after 45mins same settings. I never did try to get orthos stable I went all the way up to 1.385 or something and just got mad. I am stable now though at 1600mhz @ 1.2v, pretty happy with low setting.
General q: I set Intel speedstep auto and power management in windows to balanced. So multi at idle drops to 6x. Is there a reason why I shouldn't do this? I mean it jumps up with a load. I just figured why not save a bit on energy bill when I'm not playing games or using cpu intensely. The power is there when I need it and it's stable. I'm just wondering why others aren't doing this.
[SIGPIC][/SIGPIC]
3DMark06: 20974
My Core 0 is stuck on 34C until I get over that, then it works, Core 1 seems to work, at least I think so as it says I am 27C idle.
Smart Guardian gives my 15C idle.
Larry
Q9650
Asus P5Q-D Bios 1406
280 GTX FC Block
2x2gb OCZ Flex II PC2 9200
Water Cooled/ Iwaki MD20/ D-Tek Fuzion
XFX 850 Watt
OWC SSD
Here is my E8400 Q748A094 i m happy for now
ASUS P5B Dlx; 2 x 1024 MB Crucial Tracer
Xeon 3110@4000 MHz 1.296V Seasonic 600W,
8800 GT
@ GUFY Nice job, and NO problem seeing the Screen Shot
Larry
Q9650
280 GTX FC Block
XFX 850 Watt
OWC SSD
My wet dream
4.5 Ghz
Dies on small FFT's, pushed vcore to 1.488 before cowardace set in. What do you guys think...venture into 1.5+ vcore territory?
I love those nice round numbers, makes a killer screenshot
@ AndyM, What are your other voltage settings, ie; VTT and Northbridge at?
Larry
Q9650
280 GTX FC Block
XFX 850 Watt
OWC SSD
I have to wonder if people aren't doing something in their initial testing that's different from later testing. I know I had some similar/strange behavior on my e6750 - I was 100% stable (OCCT for like 6 hours) at 3.6ghz for the first couple of months, following that I could only hit 3.35 with some instability at the same volts.
The biggest thing I wonder is if ambient conditions changed, or airflow, or dust accumulated in the machine, that kind of thing.
core i7 920, gigabyte EX58-UD5, 4870x2
DDC3.2 > PA120.3 > DD4870x2fc > Fuzion v1 > PA120.2 > EK Res
i7-2600k @ 4.8Ghz 1.38v L044A892
ASUS P8P67 LGA
16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
Cooler Master UCP 1100 Watt PSU
GTX 680 1300/7000
Lian Li PC V-2000
Well, may help to give the NB Just a nudge if it starts getting flakey on you.
Larry
Q9650
280 GTX FC Block
XFX 850 Watt
OWC SSD
Memory is unlinked at 5:6. Haven't tried orthos yet but I just played Titan's Quest for a few hours with no issues. Before I go to sleep tonight I might drop the vcore and NB voltage a notch and see if it's still stable. Maybe even the VTT since I upped it on a whim.
Gaming Box
Home Server
P67B3 SB D2@5.1G_1.47v :bow: SA PSC GF110 SSDS SPI-6.79 06-37580 Vantage-P36245
If life gives you a computer...OVERCLOCK IT! :yoda:
