I didn't think so. It sounds like your on chip sensors might be a little screwed up. Your processor won't start throttling until DTS=0 and you are still a long ways from there.
Set up CoreTemp like this and it will report readings from the DTS directly and show you how far you are away from throttling.
Intel hasn't changed the location or format of this data so CoreTemp does not need to be updated to read it. CoreTemp's interpretation of this data may have changed but all versions of CoreTemp that have this option should have no trouble reading the DTS sensors and should report the same thing.
I can't seem to get Coretemp working on Vista x64. It errors out, and I tried running with administrator.
Any thoughts?
__________________
EVGA 780i / E8400 @ 4199MHz 1.41v
4x2GB GSkill PC2-8000 @ 2.15v 1000MHz
EVGA SLI 260GTX 216 SC
Asus Silent Square EVO
HP LP2475W 24" H-IPS Panel
Case:CM HAF-932
PSU: Tt Toughpower 850W-SLi
Windows Vista 64bit / Logitech G7/G15
Any thoughts?
Disable Signature by pressing F8 before the OS loading. Make sure you are not installed all the window updates. Otherwise, it doesnt matter if you disable the signature it weren't work.
So the read out of CPU temp by a program like Abits uGuru, should be what I look at and be concerned over, not each individual core, via core temp software? At least that is the opinion as far as Intel are concerned?
Intel has said that E8400 users should ignore their core temp readings and instead concentrate on the cpu temps, which they recommend as 61.4C (or perhaps 72.4C as was noted in another post) being the maximum. I would check your bios cpu reading and compare it to any Windows software program you are using. My bios temp reads about 4C higher than most software readings.
Intel has said that E8400 users should ignore their core temp readings and instead concentrate on the cpu temps, which they recommend as 61.4C being the maximum. I would check your bios cpu reading and compare it to any Windows software program you are using. My bios temp reads about 4C higher than most software readings.
My CPU temp (Tc) seem to be in-line with what I expect. Could you link us to where Intel has made this announcement? I'd love to read the details.
__________________
Lian Li PC 7077A
Dual Watercooling Loops
Asus P5K Deluxe (BIOS 0705)
Core 2 Duo q6600 (3402MHz, 1.41v)
Core 2 Duo e8400 (4682Mhz, 1.57v)
1xXFX 8800GTX XXX
2 Team Xtreme DDR2 800-PC6400 @ 504
2 x 80gb WD in RAID 0
1 x 250GB WD Storage
PC-P&C 750 Silencer
HI guys, i hit a brick wall with my e8400, keep gettin the "FATAL ERROR: Rounding was 0.5, expected less than 0.4" message in prime past 4.3 ghz. aiming at 4.5 but no vcore will satisfy the beast. my assumption so far is that these chips dont need that much vcore to hit sky high but its other settings like cpu ppl, fsbt, and those gtl thing but have no idea what to set.
anyone running this chip on maximus formula?
so far am at 500fsb, stable @ 8.5 multi but when i change to 9 nuthing seems to work
@ 500x 8.5 am 24hrs prime stable blend
1.425vcore
1.5v cpu ppl (bios set)
1.54 fsbt(1.43 actual)
2.3vdim @ 5-5-5-5-3-35-6-3 @ 1200( passed 12 prime + 24hrs blend)
1.65nb
1.18sb
1.55 sb2
any tips on gettin it stable with multi 9 .
rig
maximus formula se (907)
e8400(Q745a372, 12/20/07, 1.1125vid)
2gb crucial ballistix tracer 8500
2x 80gb seagate sata raid 0
2x saphire 2900gt CF(disabled when priming)
Swiftech 220 compact kit(4x scythe 1500rpm fans on rad)
northbridge and cpu loop.
load temps at 1.425(nb39-41, cpu 54-58, cores 58-62 both same, sb 35)
idle 30cpu, 38cores, nb 38, sb 32)
@ 9x 500 tried 1.45, 1.47. 1.48.1.5 and 1.525(load at 63cpu) and nothing seems to work. any tweakin guru's please tip me. thanks.
I had a e8400 had the same results.. Had great temps! But past 4.2...I would immediately get those errors on core2. I had tried many different voltage combinations but no luck.. Sent it back..
My BIOS CPU temp seems to be spot on with uGuru
Idle 33c load 49c, cooler by 5-9c ish over core temp readings. My CPU gives out weird temps via core temp, one core is 5-8c hotter than the other, as I mention in a previous post.
uGuru temps seem more in line with what I would expect from my WC rig.......
Cheers!
__________________ "I love her muffins more than life itself" Dexter's Laboratory
__________________ PLAY RIG CUPBOARD IS BARE ATM !!!! SHALL I i7 OR NOT
HOME 24/7 RIG DFI LP UT P45, E8500, 4GB OCZ PC2-6400 REAPER X , EZ-COOL 600W PSU, GE-CUBE HD3870X2, 2 X 80GB HITACHI SATA 2 HD'S IN RAID 0 + 2 X 250GB MAXTORS MIRRORED + 1 X 500GB MAXTOR, VISTA ULTIMATE SP1 (32 BIT)
WORK 24/7 RIG DFI LP DK P45 PLUS, E8500, 4GB OCZ PC2-8000 REAPER X, EZ-COOL 700W PSU, RADEON HD3450, 2 X 160GB RAID 0 + 2 X 160GB SAMSUNG'S SATA 2 HD'S IN RAID 1, VISTA ULTIMATE 32-BIT SP1, CPU COOLING : TUNIC TOWER 120
OLD FAITHFUL DFI NF4 EXPERT, OPTY 144, 1GB OCZ PLATS, 600W PSU, 6600GT, 60GB MAXTOR, XP PRO - SP2, CPU COOLING : STOCK
Nah, no chance of that, unfortuantely. First tiem removing the cooler from the box, and the imprint was as good as it gets. I'm just blown away that the cpu has not throttled at all. I guess I must be pretty close to that point tho, on stock cooling.
Maybe that's why the "T" in my FPO...who knows.
Nobody knows-or will tell. Intel doesn't want you to know about the "T".
It's a conspiracy, I tell ya, a cons...................ackkkkkkk
"Retro will be temporarily unavailable until he has been re-programmed about our fine Intel processors."
Department of Internal Affairs and Propaganda,
Intel Corporation
my e8400 has degraded somehow, from 4.3ghz, 6 hrs stable run to stock now,
no matter what i do, any overclock is unstable
Try running MemTest86+ at default CPU MHz and adjust the divider to bring your ram up close to the normal speed you run it at. I've seen more ram go south than cpus but anything is possible. If you have some spare ram available swap it in and see what happens or try using one stick at a time to isolate your problem.
