XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 01-29-2008, 12:54 PM   #576
Blackwhite
I'm still strugling with my Mobo and E8400
I need 1.368v to run 4GHz, but in BIOS I have to set 1.485v , so it means vdrop is 0.117
New BIOS is needed!!!
__________________
EVGA SLI LE / i7 920 D0/3x2GB Corsair Dominator 1600/ SSD 64GB & WD 640 Gb/ ATI 5850 / SB X-Fi / CM ATCS 840 / Enermax 1250
my youtube channel
Blackwhite is offline   Reply With Quote
Old 01-29-2008, 12:59 PM   #577
unclewebb
unclewebb's Avatar
Read the Micron datasheet for D9 DDR2 memory and you will see that it is only factory rated at 1.8 volts. When people are overclocking they usually start giving their memory voltages like 2.3 or 2.4 volts. In my experience, bad memory is usually the cause of most performance and stability degradation. It will be interesting to see some reports from XS users how the 45nm chips are holding up long term, like maybe a month or so at 4+ GHz.
It might even be that 45nm is more sturdy than older chips.
Intel wouldn't have raised TjMax if they thought otherwise. TjMax represents the highest safe operating temperature for a C2D so a bump up in this rating is a sign that Intel is pretty confident in these new processors, even at extreme temperatures.
unclewebb is offline   Reply With Quote
Old 01-29-2008, 01:05 PM   #578
sofarfrome
sofarfrome's Avatar
That is not vdroop, it is offset between what you set in bios and what is indicated by windows. What you need to do is launch P95 or Orthos and then look at the CPUz 1.368v. The amount it drops when the CPU is loaded is vdroop. Better yet, use a voltmeter and measure the REAL vdroop.
__________________
DFI LP LT X38; Intel E8600; Crucial 10th Anniversary DDR2-667 (2x1GB); eVGA 8800GT 512MB; WD 250MB Sata-ll (and others); Silverstone Striker 750W; D-Tek Fuzion-TC PA120.3-Swiftech MP655; Lian Li G70B; XP32 SP3
DFI LP P45 Jr.; Intel E8400; Crucial Ballistix DDR2-1066 (2x1GB); Custom WC setup; PNY 9800GTX; Corsair 620HX; Plextor DVD; Lian Li; Logitech G11/MX510; Lian Li; Vista Ultimate 32 bit
The clueless don't even know they are.
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe. -- Einstein
HEAT
sofarfrome is offline   Reply With Quote
Old 01-29-2008, 01:05 PM   #579
mrcape
mrcape's Avatar
I really hope they are holding up well! I want to run these suckers hot.
I understand that in the past overvolting has been fine if you can keep the temps down, it's just that there are conflicting reports about 45nm. Reports that come from the same guys who love to throw voltage at chips, not the conservative types.
__________________
mrcape is offline   Reply With Quote
Old 01-29-2008, 01:12 PM   #580
Zucker2k
Banned
I've even pumped 1.6250v (bios) set, and on posting, I saw CPU Overvolt warning, still booted into windows fine and trying to determine max clocks. I tell ya, once you broach the subject, people are going to be pointing to the cpu instead of troubleshooting other things.
Zucker2k is offline   Reply With Quote
Old 01-29-2008, 01:17 PM   #581
hazardous
Q745a576
box date 1/4/08
lapped and ready to go!
breaking 4ghz at about 1.22v orthos stable on x38
now playing with the fsb, pics later
hazardous is offline   Reply With Quote
Old 01-29-2008, 01:18 PM   #582
Zucker2k
Banned
0.117 This would give me 200mhz.
Old 01-29-2008, 01:30 PM   #583
flopper
flopper's Avatar
My vdrop is .5 or so.
temps are off tho,
65c idle orginal e8400.
4ghz 68c.
orthos, 95c.
Looking for answers on the net shows, seems as either a bios issue or a temp issue with the e8400 series.
No clear winner yet
__________________
Intel i7 i920 4.2ghz 1.4200v ekwater supreme -GA UD5 [F9e] - His 5850 940/1100 24/7 - Kingston valueram 6x1gb cl9 - Kingston 2x40gb ssd raid+ software raid and a-data ssd 3x32gb raid0 Areca 1210 - 22inch Lenovo 220x - haf932 - Corsair 750w-watercooled ekwaterblock-sennheiser hd600 headphones - Asus essence stx - Razer deathadder and G15 -windows 7 home edition 64bit - - 18k Vantage (40/60c -) WarHammer Rune priest (one of the 26% that isnt confused on xtreme forums)
flopper is offline   Reply With Quote
Old 01-29-2008, 01:33 PM   #584
Zucker2k
Banned
temps are off tho,
4ghz 68c.
orthos, 95c.
No clear winner yet
No way!!!! Because you're saying your volts drop from eg. 1.500v to 1.000v? Impossible.
Old 01-29-2008, 01:36 PM   #585
Mav451
temps are off tho,
4ghz 68c.
orthos, 95c.
No clear winner yet
You may want to update your sig. You're on a Wolfdale now
__________________
>> i5 750 @ 3.6Ghz | CM212Plus + P12 | P55-UD3R [BIOS F2] | 4GB G.Skill CL8 | eVGA GTX 260
.: 500, 640, 2 x 1TB WD; 1TB ST | Corsair TX750 | Lian Li PC-A70A | X-Fi | Logitech Z-2300
Mav451 is offline   Reply With Quote
Old 01-29-2008, 01:39 PM   #586
flopper
flopper's Avatar
humph,
correct, 1.400 to 1.350 would be acurate
me and electronics dont adjust well.
__________________
Old 01-29-2008, 01:54 PM   #587
Plastok
Plastok's Avatar
VID in coretemp can be buggy i think
Look at mine
Plastok is offline   Reply With Quote
Old 01-29-2008, 01:55 PM   #588
Blackwhite
Can you give me a link , how can I measure CPU voltage using a voltometer please.
BTW my English is not so good (I'm Polish) - I understand this offset is bad, and looks like my CPU is crap?
In Windows i've got 1.4V - in orthos 1.368 - that means vdrop is 0.032v.
__________________
my youtube channel
Old 01-29-2008, 02:04 PM   #589
RADCOM
Xtreme Waterbaby
RADCOM's Avatar
Anybody got a Q745A346 pack date 17/01/08? I can't test mind due to Asus Striker Extremes amazing ability to fubb
__________________
Respec'
System:Bunch of crappy overclocked PC's that cost an arm and a leg
"A Caesarean Milks Stops Wort"-anagramL]
RADCOM is offline   Reply With Quote
Old 01-29-2008, 02:34 PM   #590
JoeBar
Xtreme Guru
JoeBar's Avatar
I returned my Q748A242 today (max orthos speed was 3.8ghz ) just to realize that all other cpus (10 of them) were Q748's also...
I decided to grab a new one Q748A141 and at least it's a bit better that the old. Right now priming for 2 hours @ 4.0ghz with 1.39v under load. Still a very high vcore for 4.0ghz but at least it doesn't top @ 3.8ghz...
Seems like Q748's constantly produce the worst results. Better avoid them if u can...
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.42GHz (21 X 210mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1683MHz (6-8-6-20-1N)
Asus 4870 X2 @ 850/950MHz WC'ed
150GB Western Digital Velociraptor | 2 x 320GB Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC-2 with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC-3.1 with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Old 01-29-2008, 02:37 PM   #591
Grnfinger
Banned
Send a message via AIM to Grnfinger Send a message via MSN to Grnfinger
Originally Posted by Stelios View Post
I never wrote that 8 CPU's died . They just degraded . You should read more carefuly next time !
Mainly I reported less Mhz stable . 8 cpu's till yesterday ... 9 today , as another user in a forum here in Greece today reported that his CPU has lost Mhz also.
Also , 3 QX9650 (Hipro5 , Shamino , Victorwang) . You can find the posts here in XS for these CPUs. Also there is one 8400ES that died while benching (ln2) .
A new poll has been opened in thelab.gr today and already 38% voted that they noticed a degradation ... 33% doesn't tried with voltage so they don't know ... and 16% voted that the clocks are the same .
This is very interesting news, would you have a link to this thread by chance?
I have been watching my MHz and bench scores since this rumour/fact started. It will be 1 week Thursday and I have not seen any performance/stability loss......yet.
Grnfinger is offline   Reply With Quote
Old 01-29-2008, 02:45 PM   #592
Stelios
Champion
Stelios's Avatar
The poll thread ? It's in Greek btw . (http://www.thelab.gr/showthread.php?threadid=46871)
What voltages are you running ???
Faster way is to use orthos/prime95 . Write down your current numbers , and check them after some days .
Stelios is online now   Reply With Quote
Old 01-29-2008, 03:56 PM   #593
rge
rge's Avatar
Orthos run so far, 1.2875 bios, 1.28 CPUZ for 4.0, will let it run overnight. I have loadline enabled so voltage in bios matches voltage in cpuz, vdroop is still ~.008 to .01. My batch in sig.
Wonder if any way that a single post could be edited by all people. Be nice for each person to list handle (some accountability for accuracy) their cpu batch, and volts needed for 4, 4.1, 4.2, etc. and get some idea of how these scale. Too much work for one person, especially one with a new toy.
__________________
i950 4.5 Ghz prime stable - Windows 7 64 - GB X58Ex - OCZ Plat 6gb - Corsair HX850 - Intel X25m SSD - 295 GTX - 26 inch Samsung LCD
Lian Li A71F - 3dmark 6 30K - i950 5.13 Ghz water - 8.16 spi1M @ 5ghz - 4.92ghz sp32m
rge is offline   Reply With Quote
Old 01-29-2008, 06:18 PM   #594
Ron 61
Ron 61's Avatar
http://www.xtremesystems.org/forums/...re#post2389552
Post #1885 is a good pic of measure point on board. With beta 16.b04 uguru is real close to what my DMM reads. When uguru reads 1.32v to 1.34v my DMM reads 1.34v. I just wish abit would fix the damn bios. No doubt they have had access to engineering samples of wolfdale for quite some time. Good luck.
__________________
E8400 @ 3.84Ghz 1.25v LOAD
ABIT IP35 PRO
4 GB G.SKILL F2-8000CL5D-4GBPQ
EVGA 8800 ULTRA 660/1110
PC POWER & COOLING 750 QUAD
THERMALRIGHT ULTRA 120 EXTREME
2 X SEAGATE BARRACUDA ES.2 ST3250310NS 250GB RAID 0
Ron 61 is offline   Reply With Quote
Old 01-29-2008, 06:20 PM   #595
Supertim0r
INTEL inside
Supertim0r's Avatar
My chip is incredibely cool. I see some members on water at 60c+ low vcore
I'm at 50-51c loaded 4ghz 1.36v with a tuniq @ 800rpm in a lowcfm/silent case
Even at 1.45v, I barely hit 58-60c MAX
__________________
24/7 PC : Biostar Tpower P45, E8400 E0 @ 4.4ghz, 4gig G.SKILL F2-8000CL5D-4GBPQ, Asus 8800 Ultra, Corsair HX520w
benching stuff : P5K Premium, DFI LANParty Dk P35-T2RS, XBX2 <3..., few "D9" kit, few Q66 ES / E8400 / Q9550 ES, 8800GT and GTS, OCZ PS600W, Zeus 750w, Phase change, Tuniq, Ultra 120E...
Supertim0r is offline   Reply With Quote
Old 01-29-2008, 06:50 PM   #596
Ron 61
Ron 61's Avatar
Uguru reports my temps as 33c idle and 50c loaded. Core temp on the other hand reports 51c idle 68c loaded. Thats a 17c spread on both but I think core temp is off because even at default vcore 1.1v core temp reports 48c idle. When I touch the base of my Thermalright it is barely warm while under orthos load.
__________________
ABIT IP35 PRO
Old 01-29-2008, 06:53 PM   #597
BooStFeD
BooStFeD's Avatar
Originally Posted by higgins View Post
Product code : BX80570E8400 S-spec : SLAPL
MM # 895733
Fpo/Batch # Q748A142
version # E27439-001 max 1.225v pack date 01/09/08
P5B Deluxe, vdroop pencil mod.
1.328v idle, 1.336v load.
pretty weird temp though. 24C roomtemp. idling at 42C and loading at 58-62C. fuzion, mcw60, pa120.2, mcp655. thats hotter than my e6600 heh ill try to remount the block a few more times.
Below is my E8400 running on a P5B Deluxe.
I feel my temps are a bit high as compared with yours for water. I however have not done a remount.
Maybe core temp is to blame for temps being off.
What bios are you using?
Originally Posted by BooStFeD View Post
E8400
FPO/Batch = Q746A489
Pack Date = 1/09/08
MB P5B Deluxe Bios 1226
Testing 450 * 9
Bios Vcore = 1.350v
Idle Vcore = 1.320v
Load Vcore = 1.296v
CPU is on water with old DD TDX WB
Going to remount WB but I am concerned about temps.
CPU Idle = 41c / 36c
CPU Load = 56c / 55c
Ambient = 23c
Think I have a bad mount?
__________________
Cooler Master Stacker 810 WATERCOOLED
Black Ice GTX 360 // Danger Den TDX CPU WB //
Maze 4 GPU WB // D5 Pump // SwifTech Micro Res.
ASUS P5B DELUXE // E8400 @ 4410MHz 490*9 1.41v
2x2GB MUSHKIN ASCENT DDR2 1066
SAPPHIRE OC HD5970 2Gb @ 900-1150
Corsair HX1000w // SB Audigy 4
BooStFeD is offline   Reply With Quote
Old 01-29-2008, 07:15 PM   #598
X.T.R.E.M.E_ICE
Cortemp screenshot?. My tuniq fan runs at about 450rpm and my cores idle about 49c at 1.2v
X.T.R.E.M.E_ICE is offline   Reply With Quote
Old 01-29-2008, 07:26 PM   #599
jaredpace
I am Xtreme
jaredpace's Avatar
you could start a spreadsheet on google docs, and link to it in the OP. like
FPO
BATCH
VID.... etc
then when everyones data is voluntarily put into the spreadsheet, 1 user at a time collaboratively, you could sort by any column like a database, and see which versions or mobo combinations are best with the e8400
jaredpace is offline   Reply With Quote
Old 01-29-2008, 07:42 PM   #600
Supertim0r
INTEL inside
Supertim0r's Avatar
This one is Q740A473T
18-19c room temp
The tuniq is so cool to the touch, i might try running completely passive
I have an other Q740A553T running approx same oc 8-9c higher
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
