okay,friends ask me how to do the vcore and vdrooping mod
on ga x38 t dq6, here is the vmod, i have tested and works well.
if u want to do those vmod, take all responsibility by urself
be ware after the vmod will lose ur warranty
* for vdrooping , solder a 5k pot , and adjust to 2.1k after soldered.
and suggest u turnoff the loadline calibration in bios feature.
* for vcore mod, solder a 500k or 50k,20k vr another side connect to ground
adjust the vr, til what u want vcore, remember the lower resisitors will get
higher vcore voltage.
sorry, the picture is not clear,
here is another backup picuture found from my harddrive.
vdrooping mod connect the red spot,
and vcore mod solder the green spot another way goes to ground.
