XtremeSystems Forums
Reply
Old 01-12-2008, 03:54 AM   #1
coolmiester
coolmiester's Avatar
Send a message via MSN to coolmiester Send a message via Skype™ to coolmiester
MC-TDX Nozzle Kit + Bowed Base
As has been pointed out by Martinm210’s Danger Den MC-TDX Pressure Drop Test Results the MC-TDX is the new King of Flow for CPU pin matrix type blocks, which got us both thinking about a nozzle kit so decided to knock one up.
The pin arrangement does have a recessed section in the middle which may indicate the Danger Den have plans for something similar and would guess they have plans to put something out soon.
Anyway, basically got a splodge of Blu-Tac and pushed it into the pins which gave an exact impression of the recess then with a black marker I highlighted the bit in question and transferred it onto a piece of paper.
I hunted around for a piece of material the correct thickness (1.1mm) and came across an old CD case which was spot on so stuck the imprint onto it and cut it out with a fret saw.
I little bit of filing later and i have a finished nozzle that fits really snug and will stay in position once the top is re-fitted.
I’ll knock up a few more and if martinm210 wants to undertake the job of testing he can try a few different hole configurations, as he would do a much better job of testing than I could.
A few pictures of the making……
coolmiester is offline   Reply With Quote
Old 01-12-2008, 04:45 AM   #2
septim
Banned
Send a message via Yahoo to septim
cool, everything should improve with some more focused pressure.
pattern should probably be the same with dTek nozzles...
septim is offline   Reply With Quote
Old 01-12-2008, 05:55 AM   #3
coolmiester
I would of thought directional flow to the four cores would be more beneficial as the original nozzle kit was more for single core but I guess it will be a bit of trial and error testing tbh
Old 01-12-2008, 08:21 AM   #4
Nate P.
Xtreme Mentor
Nate P.'s Avatar
Looks good, some temp results would be nice...
__________________
E8400 / DFI Blood Iron / 4GB G.Skill / HD3870 512MB / Silverstone 650W / WD 250GB
20D / 24-70mm 2.8L / 70-200mm 2.8L / 580EXII
Website
Nate P. is offline   Reply With Quote
Old 01-12-2008, 08:35 AM   #5
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Wow, that's a great idea an much simpler than what I was thinking.
I'm going to have to try that too. For a C2D, I'm thinking a nice simple slot nozzle or maybe an array of smaller jets in a rectangle.
Way to go!!
Martinm210 is offline   Reply With Quote
Old 01-12-2008, 08:36 AM   #6
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
I didn't realize that depression was rectangular, that has to be what it's for.
Old 01-12-2008, 08:41 AM   #7
systemviper
Phazers on Stun
systemviper's Avatar
Send a message via Yahoo to systemviper
I have been sticking to my apogee GT since everything that has come out hasn't been a monster improvement over the go old Apogee gt, but i have been reading about the
MC-TDX and i think i am going to put one of these MC-TDX in my best rig to cool the quad even better.... It will be interesting to see what temp changes are on my quad.
but now i need this new mod lol
I lile the look of this new block but as we see , just a few tweeks and wazzzom, you got something pretty special
__________________
HEAT
systemviper is offline   Reply With Quote
Old 01-12-2008, 08:43 AM   #8
coolmiester
Yeah the depression is more of a square shape with rounded corners so there is no chance of it spinning or turning.
If you PM your address Martin i'll get a few more made and send them over for you to do some testing as you have the relivant equipment along with some DDC tops as per PM
Old 01-12-2008, 09:41 AM   #9
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
You have PM, this is a great idea. I'm really looking forward to this mod
Old 01-12-2008, 11:04 AM   #10
nikhsub1
Xtremely Wet
nikhsub1's Avatar
Send a message via AIM to nikhsub1
problem is, this block will never contend for a top spot without being stepped or bowed.
__________________
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
Q6600 @ 3.7Ghz / Maximus Formula X38 / 4GB Supertalent 6400 / 4870 HD
PC Power & Cooling 750W
Mountain Mods U2-UFO Cube
GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
Win7
"Artificial intelligence is no match for natural stupidity."
Originally Posted by ranker View Post
Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
nikhsub1 is offline   Reply With Quote
Old 01-12-2008, 11:38 AM   #11
Vapor
Admin
Vapor's Avatar
Doesn't DD have nozzles for the regular TDX? Are they compatible? If not, can they be cut down?
Agreed
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 01-12-2008, 11:39 AM   #12
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Yeah, I'm curious if the thicker 1mm nozzle actually bowes the base, I think it will.
I can try stepping on the mill, but I need to finish testing all stock first to have good numbers to compare against.
Old 01-12-2008, 11:45 AM   #13
coolmiester
The TDX Accelerator Nozzle Kit is actually 3.2mm thick which might be a bit much tbh and could end up bending the copper pins but i'll have a bit play
Old 01-12-2008, 12:47 PM   #14
coolmiester
Used the blanc from the older TDX Accelerator kit but at 3.2mm it was never going to fit so filed it down to the correct rounded corner square then proceeded to shave off some thickness.
Eventually got it down to 1.88mm which fits just fine and low and behold it bows the base
And some more pictures...
Old 01-12-2008, 12:53 PM   #15
Nate P.
Xtreme Mentor
Nate P.'s Avatar
Nice! Lets see some temps! A comparison with the Fuzion, nozzled Fuzion, MC-TDX, nozzled MC-TDX, bowed MC-TDX, and the EK would be very helpful, if not over the top.
__________________
Website
Old 01-12-2008, 12:56 PM   #16
coolmiester
Martinm210 is kindly doing the number crunching so i'm sending them over to him on Monday.
Old 01-12-2008, 12:59 PM   #17
Nate P.
Xtreme Mentor
Nate P.'s Avatar
Sounds good, thank you Martin for all your hard work!
__________________
Website
Old 01-12-2008, 01:02 PM   #18
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Awesome! That's great!!
Do you think you needed all of that 1.88mm?
1/16" acrylic or lexan sheet would be 1.58mm, it would be pretty easy to make blanks from that.
Old 01-12-2008, 01:10 PM   #19
coolmiester
I would say 1.88mm would be maximum without doing damage to the pins and would imagine 1.58mm would do just fine - depends on how much of a bow is needed i would have thought.
Old 01-12-2008, 01:15 PM   #20
smee
smee's Avatar
So your saying that this dd block with out perform the fuzion?
Also, this may sound noobie, what's the point in bowing a block? (I can't seem to figure it out)
__________________
[PROJECT] "Theblank.box" - Supported by: (UN) Designs, PetrasTechShop and Bitspower.
[theblankbox.net] - A build I've planned for ever so long, is finally becoming a reality.
[My Comp] Dell XPS Studio 13 || Intel P8600 2.8GHz || NVidia 256MB 9500M || 4GB 1066MHz DDR3 ||WD 500GB 5400RPM || Windows 7 RC1 Build 7100
Connected: Samsung 2220WM 22" || Creative 2.1 Speakers || Logitech Illuminated Keyboard || Logitech G500 Mouse || Skullcandy Buds
[Network]
2Wire 2701HG-B /Bridge Mode (as Modem) || Buffalo WHR-HP-G54 w/Tomato Firmware 1.25 || Trendnet TEG-S80G 8-Port Gigabit Switch
[NAS Box]
Intel Atom 1.60GHz || ASUS AT3GC-I || GMA950 || 1GB 667MHz Crucial || 250W PSU || 2X Samsung 1TB HDs || Windows Home Server SP1
[Flickr] - Canon 30D || 28-135mm f/3.5-5.6 IS USM
smee is offline   Reply With Quote
Old 01-12-2008, 01:19 PM   #21
Nate P.
Xtreme Mentor
Nate P.'s Avatar
It puts more pressure on the center of the CPU (where the core is) and results in better temps.
__________________
Website
Old 01-12-2008, 01:24 PM   #22
smee
smee's Avatar
Interesting.....
But then you don't want the motherboard to bow, right? Or is that a good thing?
__________________
[Network]
[NAS Box]
Old 01-12-2008, 01:26 PM   #23
Nate P.
Xtreme Mentor
Nate P.'s Avatar
Interesting.....
No you don't. That's why people use backplates.
__________________
Website
Old 01-12-2008, 01:37 PM   #24
smee
smee's Avatar
Gotcha.
So, the nozzel kit for the fuzion, the bigger the fitting you put in there the more the fuzion bends right?
The 5.5mm nozzel is the biggest one for the fuzion right?
__________________
[Network]
[NAS Box]
Old 01-12-2008, 01:41 PM   #25
Nate P.
Xtreme Mentor
Nate P.'s Avatar
Gotcha.
Yes, the 5.5 is the biggest, but that's the size of the hole. All the nozzles are the size, it's the size of the opening that's different. So the 5.5 would have the highest flow out of all of them, no bow the base the most.
__________________
Website
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
