Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Thread: Pump Died
    Xtreme Cruncher
    Jul 2007
    Flushing, NY
    Pump Died
    Every morning when I get up, I head straight to my computer to check weather and stuff..
    This morning when i came to my computer i noticed it was off while my other rig was on. Started to look around inside the case feeling the tubing and noticed that the tubing around the CPU was REALLY HOT.
    Tried to turn the computer back on and everything turns on but the pump..
    only after 6months.. DDC3.2 from petras.. is this common? also i notice around the barb a small amount of water leak.. after 6months it wants to leak now?
    Nikon User
    Nikon D200 (Gone =( )/D300
    Nikkor 18-105mm(Gone) // Nikkor 50mm 1.8 // Nikkor 55-200VR(Gone)
    Tokina 12-24 // Tamron 90mm //
    Manfrotto & Benro Legs // Benro Ballhead.
    Current Lust = 80-200 Or 70-200VR1 <--Pending
    No more computer parts for me... Well for now until I
    really REALLY need to upgrade.
    Dec 2002
    HB
    Not good news but it looks like it is time to replace the pump...
    Dec 2006
    Maryland
    Quote Originally Posted by lazy View Post
    which barb (inlet or outlet) maybe something got loose and is blocking up your loop and your pump saw low flow and high pressure. maybe...
    Current System Build
    Designaton:" Rad Hat "
    __________________
    • Mother Board, RAM and CPU:
      Mobo: Asus Maximus Formula (SE) BIOS 1207 | CPU: Intel q9650 @ 3.80GHz Vcore 1.272v | RAM: Crucial Ballistix Tracer PC2 8500 4x1GB
    • Graphics Processor:
      GPU: BFG 8800GTX | BFG 8600GT (Quad Monitor Setup)
    • Hard Drives:
      RAID: 2x 74GB Raptors on RAID 0 for OS Drives
    • Case and Power Supply:
      Case: Antec Case | PS: OCZ ProXstreame 1000W
    • Water Cooling:
      Pump: Swiftech MCP655-B | Rad: Dual Swiftech MCR320's | Fans: 6x Yate Loon D12SH-12's (W/ Variable RPM Rheostat) @ 88CFM Max Each - 528CFM Total!!!
    • (Water Blocks and Fittings):
      CPU: D-Tek Fusion Block | GPU: Danger Den Full Coverage 8800 Block | Mobo: EK's Mosfet, NorthBridge and SouthBridge Blocks
      Res: Swiftech Micro | Tee's: 4x MartinM's High Flow Copper Tee's | Elbow's: None | Y's: None
    Flow Order: >> Rad's 1 & 2 in parallel > Res > Pump > CPU > GPU > SB > NB > Mosfet 1 > Mosfet 2 >>
    Temperatures: CPU: 57°C Max, Running Prime95 | GPU: 58.3°C Max, Running 3Dmark | NorthBridge: Untested!
    Last Updated 11/11/09
    Xtreme Cruncher
    Jul 2007
    Flushing, NY
    Quote Originally Posted by RickCain View Post
    which is what i dont understand.. lifespan of only 6months? i thought the knew ones were suppose to be better
    Quote Originally Posted by Exahertz View Post
    it was in the inlet coming in from the res
    Nikon User
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    6 months
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
    Banned
    Mar 2007
    French Quarter of Grinchville
    Time to drain the loop and take a look at the pump.
    I also wonder if the pump is sitting on something like gel ?
    Xtreme Cruncher
    Jul 2007
    Flushing, NY
    Quote Originally Posted by Xilikon View Post
    heres an old pic,
    it sitting on top of a sound dampen material
    Nikon User
    May 2007
    Yorkshire born n bred
    What sort of sound dampening material? something where air can flow a little bit like sponge or mesh. Or something that would cause the pump to overheat, like gel?
    Banned
    Mar 2007
    Might be caused by overheating but we cannot be sure before you drain it and test the pump alone. It might also be caused by a loose molex.
    Never call anything dead before you are sure it is. We don't want to bury something which isn't dead
    Dec 2006
    Maryland
    is there something wrong with gel???
    N.M. i got it. overheat... doesnt apply to my MCP
    __________________
    • Hard Drives:
    • Water Cooling:
    Banned
    Mar 2007
    Exact, doesn't apply to the D5, only the DDC. The deaths we saw is almost surely tied to the burning of the pcb due to no airflow. Sitting it on gel or anything which block airflow will cause it to overheat.
    The other DDC 3.2 death I saw here was caused by the gel melting and oozing in the pcb board, killing it. But on the DDC2, there are lots of reports with no oozing but burn marks (DDC2 might be stronger but generate lots of heat, causing their early death with no sufficient airflow).
    Xtreme Cruncher
    Jul 2007
    Flushing, NY
    http://www.performance-pcs.com/catal...roducts_id=674
    thats the noise dampener i was using... so im guessing that was a bad
    mistake
    Nikon User
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    mistake
    no... that is a mat, the substance there talking about is a Gell. It looks like a gell, feels like a gell, and melts like one too. :P
    http://www.petrastechshop.com/pegviabbl.html
    Man.. now im worried... The 3.2's were suposed to be a lot more durable then the DDC-2's. And people related the failure more due to the impeller then the heat.
    Ask Pete, he'll tell you exact differences between an old ddc and a new one.
    But bah... this isnt good. If you bought it at petras' id sent it back to alex. He'd probably take it apart and find out why it died.
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Xtreme Mentor
    Feb 2007
    QFA
    V-Twin WIP
    Q6600 G0
    EVGA680i
    4GB OCZ
    8800GTX
    LC - Dual loops.
    Dual 20.1 monitors.
    Nov 2007
    ch
    Eheim ftw...
    sry just had to.
    Open the pump and see whats wrong with it.
    Xtreme Cruncher
    Jul 2007
    Flushing, NY
    Quote Originally Posted by NaeKuh View Post
    yea i had that gel stuff but never used it
    i did buy it from petra and using the petra top with it too... guess ill call him in a few hours
    Nikon User
    Dec 2007
    Portugal
    Eheim 1046, here, about 4 years, pumping 24/7hours...
    No problems!
    German quality rules!
    MB P5Q PRO
    Q6600 G0 @3400 MHz
    Watercooled Apogee GT "Bowled"
    Muskin 8500 4 x 2G =8G
    Corsair 620 by Seasonic
    Sapphire 3870+ Accelero S1 V.2 mad:
    Plextor PX716A + LiteOn 20A4H 20X + BENQ 1640
  18. #18
    Jul 2007
    California
    So the gel is bad? My pump has been running with the Gel from Petra's Tech under it for 5 months now... I have the MCP355 with Petra's Top on it.
    Never gave me any problems what so ever yet.
    Is it not running at all, or just not starting? Did you take it apart yet?
    Current System Specs:
    E5300-R0 @ 4013 Mhz (321x12.5) w/ Scythe Mugen II Cooler
    ASUS p5b Deluxe
    4 x 1gb Corsair DDR2-800 4-4-4-12
    BFG GeForce 8800 GT OC2 Edition @ 742/1728/999 w/ Accelero S1
    Sony AW-G170A (Reflashed to Optiarc 7170A)
    Thermaltake V3 Case
    Enermax Liberty 500w PSU
    2xWD160ABYS, WD2502ABYS, WD3200YS and ST3400620A
    New toy, Q6600 on the way.
  19. #19
    Xtreme Mentor
    Jun 2007
    Chicago
    What are the top 5 most reliable pumps?
    First being the D5?
    Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
  20. #20
    Dec 2007
    so is there a difference between the laing ddc3.2 and the swifttech mcp355?
  21. #21
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    Lazy, do you have a new pic? Something a bit brighter? Are you certain it is a 3.2? Can you tell us exactly what day you bought it?
    Circles SucQ!
  22. #22
    Nov 2007
    Yeah, open it if it doesnt work.
  23. #23
    Xtreme Cruncher
    Jul 2007
    Flushing, NY
    Quote Originally Posted by Waterlogged View Post
    I purchased the pump Aug 07, 2007 but didnt have the loop up 100&#37; until Sept
    I know its a 3.2 since it says it on my invoice/email receipt from petras, ( sorry i would take a screen shot but the key is broken on my laptop)
    as for the picture
    not sure why i posted that other pic.. sorry
    Nikon User
  24. #24
    Chasing After Diety
    Jan 2007
    Quote Originally Posted by Mordorr View Post
    No problems!
    ehiems are great, however noway in hell it would ever replace my IWAKI.
    IWAKI all the way baby~
  25. #25
    Xtreme Cruncher
    Jul 2007
    Flushing, NY
    those are just straight too expensive....
    200+ for a pump? no thanks... i think 80+ for a DDC/D5's are still expensive
    Nikon User
