Can anyone help me to get overclocking to work on my 8800GTS 512.
Here's the link where I provided all the details:
http://www.xtremesystems.org/forums/...d.php?t=169131
Thanks in advance !
i3770K@ 4.4 - 1.25v - TR120 Black+ Scythe GT AP-14
Crucial Ballistix Tracer 4x4096 DDR3 1866Mhz
Asus P8Z77-v Deluxe
PowerColor HD R290 moded to X
Samsung SSD 256GB 840 Pro
Samsung HDD 7200RPM 2TB (2x1TB) SA(N)TA
Corsair HX 650W
Antec P182 +3x Scythe -800-1200RPM
Asus 27" VN279QLB
Logitech G100S, CM Storm Quick Fire TK
Win 8.1
If I could only get the cpu score up a bit. Anyway they clock very well, this is all air (inc cpu.), stock fan no mods.
Have you got the GTS's max and min frames mixed up there?
Asus P9X79 Pro | i7 3820 @ 4.875GHz | 4x4GB Corsair DDR3-1600| 3x 6970 Lightnings watercooled| Corsair 1200W PSU | Mountain Mods Ascension case |
phenomII 955 c2|790fxt-ud5p|ballistix BL12864BA1608.8SFB|xfx gtx 280 xxx
Powered by UCP 1100
908MHz? I dont think so. Actually its about 580MHz.
If you havent already, the easiest way to find out is use Rivatuner (must mod the .cfg file) to independently overclock the core and the shader.
That way you can just OC the shader to find out if that is the cause.
alo everyone
here is my first results with a Gigabyte card so far, i´ll make more tests soon because this is not the limit clocks for sure.
the benches were on VISTA and of course has alot of you know the results in XP they are a bit more higher (normaly more or less 800\1000 marks depends of the system).
System Used in all tests:
Asus P5K-E @ 0503
Q6600 @ 3800mhz 9x422
TG Elite 4x1GB @ DDR845
Gigabyte 8800GTS 512MB stock
Windosw Vista Ultimate 32bits
Forceware 169.21
3DMARK 2005 e 2006 default clocks - GPU-650mhz MEM-1945mhz SHADERS-1625mhz
3DMARK 2005 e 2006 Max OC Stable - GPU-810mhz MEM-2050mhz SHADERS-2050mhz
By the way since there isen´t results of Crysis yet and of course is one of the resons for people to buy this GTS, here it is some tests that i made.
System Used:
Asus P5K-E @ 0503
Windows Vista Ultimate 32bits
Nvidia Forceware 169.21 beta
MEDIUM 0XAA - 69,00 FPS
MEDIUM 8XAA SHADERS HIGH - 40,59 FPS
HIGH 0XAA - 39,33 FPS
HIGH 8XAA - 30,84 FPS
VERY HIGH 0XAA - 21,17 FPS
VERY HIGH 8XAA - 15,05 FPS
**** in medium resolution the aplication automaticaly put the Shaders in HIGH when turning on AntiAlising
That looks like a great little app. Got a link to it so I can try it?
Edit: Never mind. Found it!
http://downloads.guru3d.com/download.php?det=1791
i7 3770K
ASUS P8Z77-V Deluxe
16GB Kingston HyperX DDR3-1600
240GB HyperX SSD
EVGA GTX 680 SC+
X-Fi Fatality
Corsair AX1200
yes is the Crysis CPU benchmark but graphic version instead of the DOS mode.
So it looks like with the overclocking ability of these cards, they easily outperform the old GTX, huh?
2600k @ 5ghz / z68 Pro / 8gb Ripjaws X / GTX 580 SLi
2x Inferno raid 0 / WD 1TB Black / Thermaltake 1200w
Dell 3008 WFP / Dual Loop WC MM UFO
alo
i dont understand how most of you have so higher clocks on the GPU, mine just freezes if passing over 815\820mhz. using stock coolers?
is just a normal card limitation or there any tricks?
thanks
Vry nice core
Still on air?
I would have thought the temps (right hand side) would be a hint :P
Yes, DICE
