XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 06-15-2008, 08:17 AM   #776
lowbid
I am Xtreme
Send a message via MSN to lowbid Send a message via Skype™ to lowbid
Originally Posted by Lloyd View Post
Anyone using the EK 3a mosfet blocks on this mobo? coz mine didn't come with the O spacers, i'm using EK barbs with the recesed O ring and i do have the spacers to hand if you think i shouls use them?
thanks in advance for your help
Kind Regards
Lloyd
I have north and south bridge and mosfet 3a buy ek with same fittings and no spacers just 0 rings.
lowbid is offline   Reply With Quote
Old 06-17-2008, 03:44 PM   #777
simri
simri's Avatar
Send a message via MSN to simri
ASUS Maximus Extreme 1101 Modded BIOS
Intel(R) Matrix Storage Manager option ROM v8.0.0.1039 ICH10R wRAID5
(*Intel(R) Matrix Storage Manager option ROM v7.5.0.1017 ICH9R wRAID5)
JMicron PCIE-to-SATAII/IDE RAID Controller BIOS v1.06.75
(*JMicron PCIE-to-SATAII/IDE RAID Controller BIOS v1.06.69)
Add-on:
ASUS SLIC ...
(*...)=Old version
http://www.4shared.com/file/51720520...101-Final.html
__________________
| Intel Core 2 Duo E6600 ES 2.44GHz @ 3.60 GHz | ASUS Maximus Extreme BIOS 1302 Custom | Corsair TWIN3X2048-1800C7DF DDR3 | ATI Radeon HD 2900 XT @ 800/1000 | Creative Audigy 4 Pro | RAID 0 2x Maxtor 6V080E0 80GB 8MB Cache SATA-II | RAID 0 2x WDC WD1200JD-00GBB0 140GB 8MB Cache SATA | LiteOn DVDRW SOHW-1693S | Lian-Li PC-65B | OCZ Powerstream 520W |
simri is offline   Reply With Quote
Old 06-17-2008, 03:56 PM   #778
TAOTAO161
TAOTAO161's Avatar
hi all,
what are your opinion on the latest bios version of the maximus formula.
they are:
1. 1102 2008/05/15 update
OS DOS / All OS
Description Maximus Formula 1102 Bios
Fixed it can not enter the setup of some PCI-Express SATAII RAID Card
or the
2. Beta Version 1201 2008/05/04 update
OS DOS / All OS
Description Maximus Formula 1201 Bios
Improve Memory compatibility
at the moment i use 1004 and it's stable on 3.6 with my Q6600 and my OCZ PLATINUM REV 2.
their is a better version their, that worth the update ?
TAOTAO161 is offline   Reply With Quote
Old 06-19-2008, 03:09 AM   #779
tistou77
hello
what bios you recommend to the maximus extreme? 904/905/1001 are always the best?
or 1101 is better view stability and performance?
that is what you call the bios moddé?
thank you
PS: sorry for my english ^^
tistou77 is offline   Reply With Quote
Old 06-19-2008, 04:10 AM   #780
jabski
jabski's Avatar
Send a message via MSN to jabski
905 gave me good results
__________________
Originally Posted by jayhall0315 View Post
If you are really extreme, you never let informed facts or the scientific method hold you back from your journey to the wrong answer
jabski is offline   Reply With Quote
Old 06-20-2008, 06:25 AM   #781
tistou77
ok jabski,
and those who have tested the 1101 gives it what?
What is the bios moddé that some have? it is better, more perf?
thank
Old 06-22-2008, 11:38 AM   #782
PalmeAsus
For me 1101 is the best bios and most stable running my e8500 in 540 fsb 24/7 and it's my cpu that's stopping me from going further.
PalmeAsus is offline   Reply With Quote
Old 06-23-2008, 10:54 AM   #783
PalmeAsus
Simiri Rampage extreme bios out now so gogo crossflash xD
ftp://ftp.asus.com/pub/ASUS/mb/socke...eme/RE0121.zip
if it works ill do so also =)
Old 06-23-2008, 12:42 PM   #784
simri
simri's Avatar
Is know about new ASUS Rampage Extreme
Test result:
Volt & Temp monintor dont work in BIOS but works on EVEREST v4.50.1403 Beta
DDR3 volt set to 2.0V get 1.5xV in EVEREST
CPU volt set Auto,1.400V get 1.28x in BIOS/EVEREST
N/A:
JMicron JMB36x Serie RAID/IDE/eSATA
LCD Poster (Volt,Temp or Clock)
I got RE to boot XP @ 2.4GHz FSB 266MHz DDR3 533MHz
im back to ME bios
__________________
Old 06-23-2008, 07:56 PM   #785
TMC2K
Does anyone have a suggestion on a good low profile fan/heatsink for the ME Southbridge chip? I would like to cool it a bit better than putting ramsinks on it. (My fusion block is removed).
__________________
Asus Maximus Extreme X38, Q9450, 2 x 4GB Kits TW3X4G1333C9DHX (only 4GB installed until NB goes under water), Palit 9600 GT 1GB Sonic (connected via DisplayPort), 2 Barracuda 250G SATA RAID1 for OS, 2 Barracude 7200.11 500GB SATA RAID0 for data, ASUS DRW 2014LIT SATA DVD, ASUS Xonar D2X, Hauppauge WinTV HVR 1800, Thermaltake 750w modular PSU, Zalman GT1000 case. Vista Ultimate 64
D-Tek Fusionv2 CPU WB, Enzotech SNBW on NB, Dominator Fan, Ramsinks on SB, case intake fans and exhaust fan.
TMC2K is offline   Reply With Quote
Old 06-23-2008, 08:02 PM   #786
TMC2K
Originally Posted by REVHEAD View Post
I guess this board is dead in the water, there isnt really any riveting posts or input in here of late, and as for q9450 input its basically non existant.
I think I may have made a mistake getting this board.
I don't know that it is a mistake to get this board. Perhaps this board and this CPU combo is a bit limiting for OC'ing. I have a similar setup. I've been prevented from OC'ing my setup due to northbridge cooler leaks. 1st the fusion block leaked and then the Enzotech SNBW waterblock leaked after running fine for 2 weeks. Both problems known to manufacturers.
I've had a hole shot in my schedule by these leeks but if you're still around I may be OC'ing my rig in a week or so.
__________________
Old 06-24-2008, 12:03 AM   #787
REVHEAD
REVHEAD's Avatar
I got my g0 out and tested it with this board and what a blessing, I can get my ram to run @ 1866 as spec and my fsb is 466 and divider is 266 and its rock solid, I couldnt get anything over 375 fsb stable with my 45nm quad. I am happy with this board now.
__________________
GA-EX58-UD3R rev 1.6[/color]
6gb Patriot DDR3 @ 1333mhz
166 QPI Core i7 920 @ 3.33ghz
4 X 80gb Veloci Raptors in Raid 0
Creative Xfi Fatal1ty
2 Sapphire 4870s in Crossfire
Dell 3007 WFP
Cooler Master Real Power Pro 1000watt PSU
Lian Li PC-A10B
Air Cooled by Noctua
REVHEAD is offline   Reply With Quote
Old 06-26-2008, 09:08 AM   #788
PalmeAsus
New bios ftp://ftp.asus.com/pub/ASUS/mb/socke...treme-1102.zip
Old 06-26-2008, 02:52 PM   #789
techno_17
techno_17's Avatar
Originally Posted by PalmeAsus View Post
Thanks for sharing, any improvements?
Regards,
__________________
techno_17 is offline   Reply With Quote
Old 06-26-2008, 09:47 PM   #790
mystikmedia
Do let us know how this latest bios works compared to the previous...
mystikmedia is offline   Reply With Quote
Old 06-27-2008, 07:18 AM   #791
PalmeAsus
None cpu oc improvements so far . Tho i have reached the limit of the cpu so i cannot test it with this cpu but still able to run 540 fsb 24/7.
Going for mem oc improvements now.
regards
Old 06-27-2008, 12:37 PM   #792
Smooth
I went back for 0904 - I set the same values on 1102 as I got on 0904 (to my QX9650 @ 3,8 GHz for 24/7 ) ... and I got a BSOD on Prime within 5 mins !
Also my CPU-Temp-reading was wrong ! It seems that 0904 ist the only Version which shows my CPU-Temp right !
__________________
Smooth is offline   Reply With Quote
Old 06-29-2008, 05:58 AM   #793
REVHEAD
REVHEAD's Avatar
simri would it be possible for you to mod the 1102 bios for us, with the latest raid roms?
Thanks in advance.
__________________
Dell 3007 WFP
Lian Li PC-A10B
Old 06-30-2008, 08:38 AM   #794
pakko
question!
If i flash with simri modded bios and than went back with 905 original bios... roms bioses are still updated??
__________________
(CPU) Intel Core 2 Quad QX9650 + Thermalright Ultra 120 eXtreme + Noctua NF-S12-1200 (Motherboard) Asus Maximus Extreme (RAM) Cell Shock DDR3 1800MHz 4x1GB (GFX) Point of View 8800 GT 512MB + TT DualOrb (Audio) X-FI Extreme Gamer (OS) Windows XP SP3 (HDDs) 2x WD Raptor X 150 + Seagate 7200.11 500 (Case) Soprano FX + Monster Fan (Keyboard) Logitech G15 (Mouse) Razer Copperhead
pakko is offline   Reply With Quote
Old 06-30-2008, 02:37 PM   #795
Romsky
Can someone attach a FireGL V7600 Bios. Ive bought a 2900pro, with a org. FireGL Cooler. So its a FireGL with a 2900pro Bios. But i do not find a FireGL V7600 Bios @Web... so i hope someone can send me or attach one.
Iam pretty sure my Card will work/run with this Bios.
Thanks a lot.
(Sorry for my bad english, but iam German! )
Greets
Romsky
Romsky is offline   Reply With Quote
Old 06-30-2008, 11:24 PM   #796
tistou77
Thanks in advance.
What difference with the bios of origin?
thank you to you
Old 06-30-2008, 11:43 PM   #797
pakko
we are in ME topic, don't u think u r quite OT Romsky!?!? Pm exists..
__________________
Old 07-01-2008, 03:12 AM   #798
simri
simri's Avatar
ASUS Maximus Extreme 1102 Modded BIOS
No SLIC yet
http://www.4shared.com/file/53436391...-1102_MOD.html
__________________
Old 07-01-2008, 04:06 AM   #799
REVHEAD
REVHEAD's Avatar
No SLIC yet
Thanks Simri
__________________
Dell 3007 WFP
Lian Li PC-A10B
Old 07-01-2008, 08:15 AM   #800
tistou77
No SLIC yet
in the bios modded this is what is added?
I not understand
you could explain me
thank you
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
