XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Motherboard Vmods
Reply
Old 11-22-2007, 03:06 PM   #1
Fastlane
Wink Here it is: Asus P5K-SE Vdroop Mod
Hello all!
Im glad to announce that i developed a fix for the Vdroop on P5K-SE motherboard. I´m an electrical engineer and i work with electronic design. In the past few days i have analysed the VRM of P5K-SE, and i understood how the PWM controler works and how we can adjust the Vdroop. The image attached shows everything. There is another image attached, where you can see how i did the mod on my motherboard.
With the pencil trick, people are getting just average results (max 50% Vdroop reducement), because the original Rfb resistor is "low" (3,6K). If you want more (like me ) you will need to solder a fixed or a variable resistor.
Thank you all, and enjoy this fix!
Felipe.
Fastlane is offline   Reply With Quote
Old 12-25-2007, 07:12 AM   #2
Akane
I tried it with a pencil, it still droops on load (1.408v down to 1.38v) I don't know if I'm doing it wrong or the pencil I'm using just not soft enough.
But thanks anyway.
__________________
Q6600 G0 @ 3.51Ghz @ 1.5v @ 390FSB, Asus P5K SE, Asus 8800GTS 640M, G.Skill F2-6400CL4D-2GBPK DDR2-800 4-4-4-12 4x1GB, WD6400AAKS, DualView with 21" Trinitron + AOC 193FW, Bigwater 745, all fans @ 7v
Akane is offline   Reply With Quote
Old 01-03-2008, 07:44 AM   #3
robz
robz's Avatar
What does this do raise the volts?
__________________
Asus P5K Delux
Intel 6600 2.4 ghz dual core
Crutial Ballstixx 2gb
BFG 8600 GT OC
CORSAIR HX620W
WD Raptor 250 gb
robz is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
