lol that's just going to heat up the dimms with the NB
the 790 is 10-13W tdp that wont heat up dims, but i dont see the point
amd has the imc so there is no memory controller to heat up the nb it just kills the cpu instead
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
Bling bling ++
so it can be removed. thank god
you still have to pay for it though. but I'm sure there be plenty other ASUS Boards withouth that fancy heatpipe
Notice any grammar or spelling mistakes? Feel free to correct me! Thanks
that would be a pain in the ass to get some tim in there so it could conduct heat from the memories heat spreader
Current setup: http://www.xtremesystems.org/forums/...postcount=1843
what if i wanted to use 4 stick of ram.
_______________________
C2D E6550 @ 3150Mhz 1.4625v
Cooler Master Hyper TX2
Gigabyte GA-P35-DS3P
2GB Crucial Ballistix PC2-6400 5-5-5-12 FSB 5:6 1130Mhz
XFX 8800GTS G80 320MB @ 680/1100
OCZ GameXtreme 700W
250GB WD Caviar's - RAID 0
Here in Sweden the WIFI version with memory heatpipes is 25-30 Euro more than the one without. So it's not that big of a difference pricewise.
Gigabyte GA-990FXA-UD3 rev 1,0| AMD FX-8120@?| Corsair H100| 2x4 GB Patriot Viper Xtreme Division 2 PC15000 9-11-9-27| 2*Powercolor Radeon HD6970 2048MB @ Crossfire| 3*NEC MultiSync EA231WMi 23" Monitorer @ Eyefinity| OCZ Vertex 3 60 GB| 2*Intel 80GB X25-M G2 @ RAID0| Cooler Master Silent Pro M1000W| Cooler Master ATCS 840|
What if I want to use the other DIMM slots?
No rig right now.
it looks like you can still use the other two slots,but those memory dimms wont have no bling
cpu- Intel I7 3930K
Asus P9x79 Deluxe
2x HD7970
32gb ddr3-1600
corsair ax1200
Corsair 800D
Corsair H100 lapped
2x 128gb M4 raid 0
wasn't the general consenses from the original thread about this board that all that heatpipe crap will do nothing more than heat up the chipset?
Athlon XP-M 2500+ 0343MPMW The King is Dead!
Phenom II X6 1090T 1025GPMW Long Live the King!
I'm from the church of the operating room
Wow! Looks a bit like a medieval torture rack...
Thaks god the specs don't change if you buy the one without the WiFi/Mem Heatsinks...
- Do you like our owl? - It's artificial? - Of course it is. - Must be expensive... - Very.
PhII 955BE, GA-MA790FX-UD5P, 2x2GB Firestix, HD 4870X2, 2x500GB RAID-0, Corsair 850TX
its like the p5k-e compared to the deluxe u just get more heatpipes as far as i can tell
Pre-Order here:
http://www.overclockers.co.uk/showpr...d=5&subcat=808
thanks to psycho_eddie
well at least there using a solid design. the pipes and fins look solid, not chincy.
FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
Asus Crosshair Formula 5 Am3+ bios v1703
G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
MSI 7950 TwinFrozr *1100/1500* Cat.14.9
OCZ ZX 850w psu
Lian-Li Lancool K62
Samsung 830 128g
2 x 1TB Samsung SpinpointF3, 2T Samsung
Win7 Home 64bit
My Rig
