10-10-2007, 11:40 AM
#151
i am almost tempted to purchase this board but after my last .... i'll wait for the Abit max ver to come out
My experience is not quite so bad , though i don't have fond memories of the ROG Commando.
What may be ok here though is the board appears to originate from taiwan, not , like the commando & strider, china. The talk of quality issues with boards seems to hang over the china plant which i believe was new at the start of the year.
see pic 3rd from bottom Asus Maximus Formula SE X38 - Living Review
must admit i like the crazy, high & normal voltage indicators
I'm torn  this or abit IX38 QuadGT supposedly next week ??
__________________
- i7 920
- DFI DK X58-T3eH6
- G.SKILL PI Black DDR3 PC 12800 CL8 6GB kit (F3-12800CL8T-6GBPI-B)
- Crossfire 2x ATI HD4670 GPU 785 Ram 1060
- Thermaltake Toughpower 1200w
- Cooling: Water - EK Supreme
- Lian Li V2000B+
24/7 OC 4Ghz 20x200 x8 1600Mhz 8-8-8-21
Official Gigabyte X48T-DQ6 Info Thread
DFI DK X58-T3eH6 on Test
10-10-2007, 01:24 PM
#152
Xtreme Mentor
Let's make sure we post up links, on any official reviews that we find on the net.
When you run this board on water, I wonder how well the heat pipe disperses the cooling to the other chips it connects to?
I also would like to know if some other water block would fit where the Fusion is, but is looking for a 1/2" hose.
10-10-2007, 03:17 PM
#153
Xtreme Guru
any official reviews, i ordered mine from newegg, it shipped from memphis so i should get it friday.
__________________
XSMODSRLAME
10-10-2007, 03:26 PM
#154
Dave's Mentor!
o hope its better than dq6 lol cause its cheaper
10-10-2007, 03:38 PM
#155
Xtreme Guru
i hope so man, i didnt like the dq6 much.........asus has been good to me in the past.
__________________
XSMODSRLAME
10-10-2007, 04:00 PM
#156
From all the reviews I have read, they are both pretty much on par with one another.
Gonna come down to personal preference I guess as both boards have unique features that separate them well from one another, but offering similar performance.
10-10-2007, 04:13 PM
#157
Xtreme Mentor
I am confused on the memory for this board: (Newbie)
It has for info:
Dual channel memory architecture
4 X DIMM, supportmax 8GB, DDR2-1200*/1066/800/667 MHz, ECC, non-ECC and unbuffered memory
DDR2 1200 is O.C. speeds.
So if I want to buy Crucial 4GB kit (2GBx2) what memory kit is best?
Here is one that I am looking at:
http://www.newegg.com/Product/Produc...2KIT25664AA53E
and another:
http://www.newegg.com/Product/Produc...2KIT25664AA667
Are these the type I need the the Maximus SE, what is the best Crucial 4GB kit (2GBx2) that I can select, that the board could actually make use of on a high memory OC?
Thanks for the help...
I want to get my memory on order for this baby....
*Update: I noticed the top link is Cas Latency: 4, the second is Cas Latency: 5, but the same price? Isn't that odd?
I guess the top link 'DDR2 533 (PC2 4200) CT2KIT25664AA53E' would be a good choice correct?
10-10-2007, 04:16 PM
#158
Xtreme Guru
My issue with the DQ6 wasnt performance, it hated 4x1gb of my micron d9gmh, one pair from crucial ballistix, and another pair from g.skill hz, both pairs do 550mhz easy with 5-5-5-12 timings, but put them together, and they barely will do 450............stock settings i was getting bsod's with 4gbs...............there is no way i am running with 2gb's again, 64 bit vista takes up 800megs on idle
__________________
XSMODSRLAME
10-10-2007, 04:25 PM
#159
Dave's Mentor!
mine does 4-4-4-12 @ 1040mhz on my p35 n i cant do 800 on my dq6 lol
10-10-2007, 04:56 PM
#160
Xtreme Guru
does anybody have pics of the motherboard without the heatsinks on it?
__________________
|Laing DDC w/ Petra'sTech DDCT-01s Top on cpu loop still works like a dream!!
cpu i7 980X
Evga x58 E760
12GB of G.skill
ATI 5970
[Dell 30"LCD 3008wfp oh the colors!
areca 1280ML with 2GB ecc of cache running in other 16x pci-e slot with battery backup running
SSDs boot drives:
Muskin calisto 120GB & Crucial C300 256GB
Standard drives: raid 10 Array 6TB Seagate ST32000641AS & 12TB storage WD 1TB black raid 6 array
sound card: Auzentech Forte 7.1 | Gigaworks S750 7.1 speakers
OSes: debian Linux unstable, and Windows XP pro x64 w/sp2| testing windows 7 x64 ultimate
10-10-2007, 05:39 PM
#161
10-10-2007, 05:50 PM
#162
Xtreme Guru
Yeah man thats what i mean, i am hoping the maximus does good with 4 gigs, im crossing my fingers!!!
__________________
XSMODSRLAME
10-10-2007, 08:13 PM
#163
It has for info:
and another:
Your first link would be a TERRIBLE choice for wanting to overclock. Since its speed is DDR2-533, you may get up to 667 speeds, or even close to DDR2-800 speeds, but I'd doubt that....since that stuff you linked to is essentially value memory and not performance memory.
You need some memory rated at DDR2-800 (PC 6400) minimum, DDR2-1066 (PC 8500...?) would be very much preferrable. A good set of Micron-based D9 chips would be nice to find, too.
Link to Some Mushkin 2 x 2GB DDR2-800.
Some other companies make better choices than what you had.....OCZ, Corsair, Crucial even.
__________________
Papa: Q6600 @ 3.6GHz @ 1.34V, Asus Maximus Formula, 4 x 2GB Mushkin Redline DDR2-1000, Asus HD4870, Antec Sig. 850, Lian-Li/RF case....WC'd via D-Tek FuZion w/quad nozzle, EK S-Max on NB, Laing DDC2 w/XSPC top, 2 x Feser 240's & one TC 120.1 rads.
Momma: Xeon 3210 @ 2.8GHz, Gigabyte P965-DS3, 4 x 1GB Ballistix DDR2-800, Asus HD3870 TOP, Enhance ENP5150-GH, Lian-Li/RF case, HK Champagne 2.1, Xigmatek HDT cooler
10-11-2007, 12:04 AM
#164
Xtremely Addicted
Problems with memory now really gone  Flashed back to bios 0401 and can run all dividers and boot with high FSB again. I think bios 0504 was the actual problem.
__________________
10-11-2007, 01:24 AM
#165
I'm thinking of getting this mobo too .. but can't make a decision yet, are the owners of this mobo happy about it?
and do i HAVE(is it a must?) to use watercooling, or can i do without it also ? and i will overclock yes
10-11-2007, 01:50 AM
#166
Dave's Mentor!
loco did you get to max out fsb yet
how is it doing with 4 sticks?
i maxed out 580fsb on my x38-dq6 the thing even did a pi run of 11.90@4.2
but the thing just dont like 4 sticks
10-11-2007, 01:55 AM
#167
to buy or not to buy
I've been waiting for / watching this mobo for a while now, ok so I was suckered in by the WaterCoolable chipset design.. but I have other reasons for wanting it and I just wanna know whether its worth it for me
- I heard they will phase the Special Edition out so needs to be bought now.
- I received £250 for my bday to buy summit for my computer (either WC or new mobo).
- I have DDR 1066 which only runs at 800Mhz (O/C on 1:1) on my current 975xbx2.
- I'll get my WC parts eventually no matter what.
- I currently have an ageing x1900xt - I might get 2 x ATI HD2600 512MB and put them in true 16x16 crossfire (I game at 1600x1200, 1920x1200 resolution)
OR
- When new GPU's come out I can use them in real crossfire
- I can upgrade to the new CPU's with this mobo
- I'll only buy DDR3 when it costs around £200 for DDR3@1600Mhz (so a while yet!)
Is it worth my while upgrading? Considering I have only one main PC so will have to take my current set up apart (not so bad cos then I can do a fresh O/S install)
Any thoughts on my reasons would be greatly appreciated!! I mean is the true 16x16 PCIE any good? Any idea when the Abit x38 comes out? are Abit any good?!? I have mixed feelings on Asus with various hits and misses (but hell, even my INTEL xbx2 isnt perfect; destroying 3 sets of memory in slots 1+3)
__________________
Core i7 930 (3912C699) @ 4Ghz
Asus P6x58D-E
3 x 2GB Patriot @ 1600Mhz 8-8-8-24
2 x Crucial RealSSD - Raid 0 (R:550/W:150)
Swiftech Apogee XT + MCP655 + MCRES v2 +
BlackIce GT2 240
Modded CoolerMaster Stacker 810
ATI 3870
Benq 24" FP241WZ
2x Samsung F3 in RAID 1
Zalman XM-MFC1 - best analogue fan controller ever!
-- Going to pc heaven ------------
Intel Q9450@ 3.4Ghz
4x2GB OCZ2G8002G
#168
Xtremely Addicted
With me quad max FSB was 467. This is the only board ive used it on so not sure if its max cpu. Also that was with bios 0504 which doesnt work good for me. I wil test the quad tonight in a Blitz to see if max FSB is higher in that board. After that ill test max FSB again in Maximus but with bios 0401.
Me E6600 does 550mhz on air but havent tried increasing PLL volts. The cpu did 550 air on me P5B, Commando and P35C as wel.
Ran 4 sticks just to see if it would run. No serieus OC. Wil try that later.
__________________
10-11-2007, 02:07 AM
#169
Banned
the p5e is an amazing board... @3.4 on my quad 1-1.... still testing....
10-11-2007, 02:39 AM
#170
OCTeamDenmark Staff
Thats not very much m8
not enough to declare the mobo amazing
__________________
OCTeamDenmark.com
10-11-2007, 02:51 AM
#171
i have some problems with P5E!
It wont run same settings as P5K-E with my E6750
On my P5K-E was it stable @ 4Ghz (1.40v VCore), P5E reboot after few seconds
Prime! i tried higher VCore, NB, SB, PLL, FSB but nothing help
10-11-2007, 03:24 AM
#172
noway if you are running with a g0 you shouldn't hit a wall yet, push it further
Then you only have a FSB of something like 380 unless you run lower multi....
__________________
eVGA 680i (Asus Blitz Extreme on 30/10, Conroe E6850@(3,75GHz) (Swiftech Apogee GTX),
2x1GB OCZ Titanium Alpha VX2 PC-8000 CAS4 (Cellshock DDR3 1800MHz CL8 on the way) ...
Silverstone TJ09, WD Raptor 74,3GB Raid 0,
2xGainward 8800GTX (Ek Wave), Silverstone 850W,
Sennheiser HD650, Razer Barracuda headphones, Razer Tarantula
Microsoft Sidewinder 2, Dell 24" 2407WFP, Razer Habu, Steelpad S&S
Windows Vista Ultimate
(Vapochill LS)
10-11-2007, 04:22 AM
#173
Xtreme Mentor
That was a push in the right direction for me. I still am looking, and found these: Kingston HyperX 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory.
http://www.newegg.com/Product/Produc...erX-_-20104001
With this review I spotted: http://techgage.com/article/mushkin_4gb_xp2-8500/1
If I am set on 4GB taking 2 slots, would this be a good selection, or could someone put my nose on a better one? (I will be running Vista 64bit)
Note: I can't find where it is listed, that this is unbuffered memory.
Thanks again.  (I want my Maximus SE happy with his ram!)
10-11-2007, 05:02 AM
#174
In my one maximus the loadline calibration does not function.
More someone with this problem?
__________________
10-11-2007, 05:59 AM
#175
Banned
sorry i should of given the reason for my impression of the P5E, my last board was a P5W DH Deluxe v1.0 and i was limited with my quad to 3.15 completely stable. i could do 3.6 24/7 on the same board with an e6600.
so when i found i was able to boot up @ 3.25 i was v.happy. i havnt had much time to overclock but in the few hours i spent studying the bios settings i managed to hit 3.4 stable easily. i'm sure this chip will go far higher on this board so imo its brilliant....
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
