-Q6600 G0 @3.6GHZ
-Apogee GT Block, Onboard Maximus SE NB Cooler
-X38 Asus Maximus Formula - RaMpAgEd
-4GB G-SKILL 800Mhz
-EVGA 280 GTX and EVGA 8800 GTS
-3TB RAID-0
-750 Watt Silverstone Zeus
Yeah, fair comment thanks...
Mobo: Asus Maximus Formula SE (0802 Bios - Air Cooled using Thermalright HR-05 IFX coolers on NB & SB)
Proc: Intel C2Q Q9550 2.83ghz FSB1333 12mb (o/c to 3.41ghz 8.5x 400fsb) with Thermalright Ultra 120 eXtreme cooler
Mem: Kingston Hyper-X 2gb(2x1gb) 1066mhz 5-5-5-15 (KHX8500D2K2/2G)
VGA: XFX 8800GTS 640mb
PSU: Antec Neo HE 650w Blue
Case: Antec P182SE with 4x 120mm fans
Sound: Auzentech X-Fi Prelude (in PCI slot above graphics card)
Drives: Intel X25-M 80gb SSD - 36gb WD Raptor - 320mb Seagate SATA-II - 320gb Hitachi in an Antec MX-1 ESATA Caddy - Sony SATA DVD-RW
Op Sys: Win XP Pro
Display: Benq 24" Q24WS
Controls: Logitech G15 Keyboard and MX1100R Mouse
Printer: Epson R800
ISP: Be Value 12mb ADSL (England)
bought the GTX260 (trade up EVGA) but for some reason I am getting major lag that I didn't get before. Even when viewing pictures and trying to move a big picture up and down (too see the whole picture) but I also noticed it in Unreal 2004
Has anyone seen something like this? Could it be the latest Nvidia drivers? I've been trying everything I can think of. I went from a 9800GTX to the GTX260
thanks
EDIT:returned the card for RMA
Core2 Q6600 - Go
ASUS Forumla Maximus SE (1207)
GSkill 4G PC2-8500
Silvertone 750W
Freezer 7 Pro - Artic Silver 5
Antec 900
Samsung SH-S203B
Seagate 250G x2 AHCI
EVGA GTX260
What's the latest/best BIOS for 45nm quads now?
Did ASUS ever manage tofixc the in FSB wall?
The latest BIOS is the 1207.
you can found it here: http://support.asus.com/download/dow...imus%20Formula
Wow man, the rig just popped itself!
TRipped the appartment fuze box.
Strange cooking smell.
Wierd, was just sitting there idle, not long turned it on, clean as.... and only a paltry OC to 3 Ghz. Maybe was just the power unit, but i fear the linger smell is not from the power box...OOOhh.... can't be my Q6600... i had it stable as man... ran at 50% load for hours.
I got about 3 waranties on this thing, so i'm going to the maker and we get a little analyticals.
....Back soon, take a pill.....
[SIGPIC][/SIGPIC]Antec Nine Hundred
Maximus Formula Rev 1.xx BIOS 907
Intel C2 Q6600 G0 @3GHz
4Gb Kingston Hyper-X PC8500 1000MHz
ATI Crossfire - HD3870 DDR4 512mb x 2
Antec 1000w TP Quattro
Zalman CNPS9700NT (on CPU)
2x WD Caviar SE16 250GB Raid 0
2x WD Caviar SE16 500GB
Seagate 300GB E-SATA
WD 500GB MyBook E-SATA
Vista 64 Prem
XP Pro
Does anyone recommend any other memory besides Corsair Dominator 1066Mhz? Using the Maximus Forumla. I was thinking about G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1100 (PC2 8800) the board says it will go to 1200Mhz on RAM but O.C.
So I am not sure if it means I can install something like the G.Skill or OCZ at higher than 1066.
I am in the process of RMA for the second time on the Dominator memory and to say that I am unhappy is an under statement. Around Thanksgiving it will be 1 year since I built this machine and every six month it seems the Dominator 1066 seems to fail one stick. Memtest86+ fails every test (sea of red)
Any suggestions would be great.... thanks
Core2 Q6600 - Go
GSkill 4G PC2-8500
Silvertone 750W
Antec 900
Samsung SH-S203B
EVGA GTX260
I had about the same luck as you with Dominator's on this board. Bought some G. Skill(2x2gb) pc-8000(pq) running 1081mhz and havent had a prob. in the last 8 month's.
I would say get the G. Skills they seem to work good on this board
Help Save Lives Join World Community Grid!
Rampage Formula | E8600 | 2x2Gb Gskil F2-9600CL5D-4GBPI| Saphire 5870|2x intel x25-v 40gb, WD 640gb black| Silencer 750 | 655 > pa 120.3 > fuzion v.2 > ek nb5 > ek 250 | cm 690
thanks friend funny part is I started to scan through the board and found that almost 75% maybe more are using GSkill ram so I bought the 4G kit of 1066 I will hopefully get the RAM today from Newegg.
I sent out the Dominator RAM for RMA but I plan on possibly selling it
Core2 Q6600 - Go
GSkill 4G PC2-8500
Silvertone 750W
Antec 900
Samsung SH-S203B
EVGA GTX260
just popped in the Gskill 4G kit 8500 I hope this memory last longer than the Dominator memory. At some point I think I need to sell off the RMA'd Dominator memory or keep it as spare memory. hutkikz what bios revision are you using with your GSkill?
thanks
Here is the PC Probe voltage reading can anyone tell me if I have my voltage too high for my new RAM and if I do have it too high how do I set it to the correct voltage so I do not hurt this memory
Core2 Q6600 - Go
GSkill 4G PC2-8500
Silvertone 750W
Antec 900
Samsung SH-S203B
EVGA GTX260
I'm using Rampage bios 0501 because of my current E8600 but my fav is 0308. I was able to run 1066 5-4-4-12 1N w\ these sticks on 0308. havent used MF bios since 0903
Edit: G Skills dont really respond to high volts I usually dont need more than 2.0v on mine
Core2 Q6600 - Go
GSkill 4G PC2-8500
Silvertone 750W
Antec 900
Samsung SH-S203B
EVGA GTX260
actually only had this e86 a short while, was on a e6750 before that. I use Rampage because I get better clocks w\ it regardless of proc.
Core2 Q6600 - Go
GSkill 4G PC2-8500
Silvertone 750W
Antec 900
Samsung SH-S203B
EVGA GTX260
2.21v is kinda high, I run mine at 2.0v in pc probe. since this board overvolts the ram .08v I have it set at 1.92v in bios.
sorry I found it, I researched the 2.0~2.1 but this http://www.gskill.us/166.pdf recommended 2.0 and that is what I am set to now so I will leave it.
THe FBS strapped to North Bridge at 333 what will that get me?
thanks
Core2 Q6600 - Go
GSkill 4G PC2-8500
Silvertone 750W
Antec 900
Samsung SH-S203B
EVGA GTX260
http://www.xtremesystems.org/forums/...d.php?t=128913
This should help explian
Just need your assistance.
I'm about to RMA my Maximus Formula due to sensor readings.
False readings are, might be:
a. PSU RPM
b. CPU RPM
c. MB TEMP
d. NB TEMP
e. SB TEMP
e. g. Everest Ultimate:
They idle version, non OC.Informationsliste Wert
Sensor Eigenschaften
Sensortyp W83627DHG + W83791D + ADT7475 + ADP3228 (ISA 290h, SMB 2Ch/2Eh/20h)
Motherboard Name Asus Maximus Extreme / Formula
Gehäusezutritt gefunden Nein
Temperaturen
Motherboard 33 °C (91 °F)
CPU 27 °C (81 °F)
1. CPU / 1. Kern 37 °C (99 °F)
1. CPU / 2. Kern 35 °C (95 °F)
1. CPU / 3. Kern 33 °C (91 °F)
1. CPU / 4. Kern 34 °C (93 °F)
North Bridge 55 °C (131 °F)
South Bridge 50 °C (122 °F)
WDC WD740GD-00FLA0 [ TRIAL VERSION ]
Kühllüfter
CPU 1406 RPM
Stromversorgung 1432 RPM
Spannungswerte
CPU Core 1.14 V
+3.3 V 3.25 V
+5 V 4.94 V
+12 V [ TRIAL VERSION ]
+5 V Bereitschaftsmodus 4.92 V
FSB VTT 1.30 V
North Bridge Kern 1.38 V
South Bridge Kern 1.07 V
South Bridge PLL 1.54 V
DIMM 2.24 V
DIMM VTT 1.12 V
Well, I'm familiar to Intel data sheets and X38 won't die 'till around a hundred °C.
PSU RPM is 1420-1500 max., different case fans (Noctua/Scythe/Loonies, even off do not change either CPU nor PSU RPM signifiatilly)
CPU RPM is 1380-1430 max., impossible due to vendor specs.
NB TEMP idle 55°C, load exceeds 67°C
SB TEMP idle 50°C, load exceeds 62°C
During boot there is a "OPT3" failure message to be resumed by F1.
Well, when they Panhead's got no E-start, I'm not looking for a switch.
Any conclusion?
NH-U12F(NF-P12)/QX6850/Maximus Formula/2x Cellshock CS2221550
HD5870 VaporX/SB X-Fi Fatal1ty/WD1500HLFS stripe/WD6401AALS/iHAS424
Enermax Modu 87+ 600W/Lian Li A16A/aquaero 4.0 VF
Everest is v4.20.1170, no different readings comparing various software including PC Probe II V1.04.40. Hardware Monitor f. s. as well.
BIOS, I'm back to 0401 because I recognized Die/Core readings given most realistic values for my QX6850. Got the whole pack 'till 1207, but I didn't try every version.
QX6850 is no engineering sample (none of those coming in little black PU-boxes).
If only the NB/SB-Temps would worry, I'd ask the hairdryer and and one of my thermal compounds to solve it (ref. P5W-DH, complete absence of TC on some early revisions).
My Maximus Formula is "7A..." prod. code.
@ sullysnet
Tryed different dual kits on my board. When going for Dominators check revisions, different ones could cause trouble (even same SPD's).
For your purpose I'd go for Micron Chips, D9GMH or D9GKX, even not listed in vendors QVL, MB will start with initial release BIOS all slots populated.
Depends as well a bit to your location and RMA regulations.
The only vendor I know granting chips is CellShock (preselected Microns, I've tested 30 passes Memtest 86+, no failure), but if you like orange heatspreaders, go for Crucial and check it out.
