XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 02-28-2008, 05:29 AM   #1076
Milamber
Milamber's Avatar
Just updated mine, and i saw a few more options to do with ram. temps seem better too.
Milamber is offline   Reply With Quote
Old 02-28-2008, 05:41 AM   #1077
doakh
doakh's Avatar
Does Bios 0602 expand the 'tRFC' memory setting past 42.
__________________
Asus P5Q Deluxe (P5QD1406) || Q9400 at 3.4GHz || 2x2GB Mushkin Redline PC2-8000 || HIS HD 4870 1GB w/ Scythe Musashi (silent) || 501GB Samsung HD || Zalman ZM850-HP || Antec P182 || Windows 7 x64 RTM
doakh is offline   Reply With Quote
Old 02-28-2008, 07:51 AM   #1078
screwtech02
screwtech02's Avatar
WZ, if im reading into the "GTL" volt setting correctly, its supposed to be approx 2/3 of whatever cpu volts your running??? I guess the same would apply to northbridge GTL also???
__________________
Gigabyte X58 UD4P
I7 920@3.8
12gb Gskill DDR3/1200
4850X2 x2
2 120gb seagate 2.5 drives (raid 0)
4 160gb seagate 3.5 drives (raid 0)
X-Fi Titanium
Custom watercooling setup
(proc,chipset,vid cards)
Windows7 Ultimate X64
screwtech02 is offline   Reply With Quote
Old 02-28-2008, 08:15 AM   #1079
VinnyG
VinnyG's Avatar
Send a message via MSN to VinnyG
Users that flashed to BIOS 0602, would you be kind enought to tell me if your temps are reading normaly? Ever since BIOS 0502/0601, my CPU temps are reported as 10C lower and NB temps, 20C lower...
VinnyG is offline   Reply With Quote
Old 02-28-2008, 11:30 AM   #1080
mu||et
mu||et's Avatar
Its the same man as 0502/0601.
__________________
http://img51.imageshack.us/img51/6522/newsigi.png
mu||et is offline   Reply With Quote
Old 02-28-2008, 01:39 PM   #1081
VinnyG
VinnyG's Avatar
Darn... I was hoping this would be solved, its the only real issue I have with the BIOS right now:P
Old 02-28-2008, 02:04 PM   #1082
mk-ultra
mk-ultra's Avatar
anyone passed 500fsb with their p5e with e8400 on air?
can you please post your voltage, cuz mine doesn't seem to like it, or i'm not giving it enought juice idk
thanks
btw vinny, it's weird you seem the only having temps problems with the lastest bios
__________________
Intel i7 w3540 / 3851A257
HK3.0+Thermochill Typhoon III+D5+ 2xMCR320+1xMCR220
EVGA Classified X58+EK FB
6GB Corsair Dominator GT 1866 7-8-7-20(TR3X6G1866C7GT)
EVGA Geforce GTX295
Enermax Revolution+85 950w
Corsair Obsidian
mk-ultra is offline   Reply With Quote
Old 02-28-2008, 02:11 PM   #1083
De1337
De1337's Avatar
Originally Posted by MMaster23 View Post
ps .. forgot to post with my post .. my ram also is PC8500 dominator. Corsair ftw on this board.
Tempted to get another 2x1GB ... u getting good clocking speeds with 4 sticks?
haven't really taken them beyond 1066mhz... no point for me.. im just finally happy i got 533 5gb without issues.
bottom line is 4 of these work. I actually recieved a set of 4x1 dominator before the current one, where one stick was bad... i was VERY close to just sending all the back and run my 2x2gb 800mhz xms2 ram... but that add to shopping cart button and the "-23%" pricetag on the 2x1gb dominators from another site just made me do it.
thank god it was only the stick. I got my money back from the one firm and got the ram somewhere else, and now it finally works.
__________________
CPU: Intel Q6600 @ 3.2 Ghz
GFX: HIS Radeon HD4870X2
MB: ASUS P5E (0702)
RAM: 4x 1GB PC2-6400 Corsair DOMINATOR + Fan
Timing: 4-4-4-12
PSU: Corsair HX1000
HDD: 2x WD2500YS 250GB 16MB RAID0 + Samsung 500GB HD501LJ
Case: Antec Twelve Hundred
De1337 is offline   Reply With Quote
Old 02-28-2008, 03:02 PM   #1084
necron66
Originally Posted by karl_eller View Post
Hmm fair enough. I dunno if the readings would change much from board to board, and from RAM to RAM, but I'll be getting a 2x2Gb G.Skill 1000Mhz kit in the next week or so, so I'll have a bit more of a play around with voltages then...
Eller
Also would be interesting to know which slots are populated when ppl are testing vDIMM.
I had slots 2 and 4 filled (the 2 black ones).
__________________
necron66 is offline   Reply With Quote
Old 02-28-2008, 03:16 PM   #1085
mk-ultra
mk-ultra's Avatar
yes, and it adds a whole lot of settings for tRFC
the only thing, i noticed so far
__________________
EVGA Geforce GTX295
Corsair Obsidian
Old 02-28-2008, 03:38 PM   #1086
karl_eller
Xtreme Cruncher
karl_eller's Avatar
Send a message via MSN to karl_eller
Yet another thing I'll have to play around with. I wonder if RAM usage/activity would also have an impact on the volt readings...
Looks like when my G.Skill kit gets here, I'll have some experimentin' to do!
Eller
__________________
Desktop: Q6600 G0 @ 3.6 Ghz | P5E | 2x2 Gb G.Skill PC8000 | 8800GTX | CM690 | TT TP 750 watt | Windows 7 RC1 x64 | Water Cooling | Crunching
Server: Q6600 B3 @ 3.0 | TR SI-128 + ZM-F3 | P5K Deluxe | 2x1Gb Corsair PC5300 | HD3450 | VX450 | Server 2008 x64 | Crunching
Crunch1: E7200 @ 3.8 Ghz, 1.30v | HDT-SD964 | MSI P35 Neo2-FR | 2x1 Gb PC6400 (D9GMH) | ATi X300 | Vantec Ion2 460W | Ubuntu 9.04 x64 on USB | Crunching
Laptop: Dell Vostro 1510 | 2.0 GHz T5870 | 4 Gb DDR2 RAM | 8400M GS | 160 Gb 5,400 RPM HDD | Windows 7 RC1 x64 | Not Crunching
karl_eller is offline   Reply With Quote
Old 02-28-2008, 04:07 PM   #1087
lowtcell
lowtcell's Avatar
Wierd things going on.
I just bumped FSB to 450 and set RAM 1:1 and start stress testing and my CPU temp jumped up to 90c (Everest and AISuite). Both cores were at 52c. OK, so I boot to Bios and check CPU temp, 38c. Boot back to windows and CPU temp reads 27c, both core are 35c. I let it idle while I read about the 602 bios and I hear my CPU fan spin down. Checked Speedfan and sure enough, running 50% (Q-Control disabled) and CPU temp back to 79c (cores still at 34c/35c). After a couple of minutes the fan went back to 100%, but the CPU is still at 79c as I type this. I'm still on Bios 501 that I flashed when I built the system and have not seen this behavior at any FSB (up to 515).
__________________
ASUS P5E X38 (RF 0701 Bios) Q9550@3.51 1.248v, Xigmatek S1283, 8GB GSkill DDR2-8000@990 1.94v, 2 - HD3870 XFire,
2 - Seagate 7200.10 320G RAID0, Seagate 7200.11 500G, Seagate 7200.12 1.5TB
Lian-Li (Rocketfish) Full Tower, Silverstone Zeus 750Watt, Vista Ultimate x64 SP1, Acer AL2223W
lowtcell is offline   Reply With Quote
Old 02-28-2008, 04:39 PM   #1088
INTREPID
Another change with the 602 bios:
601 Bios: Vcore on Auto with E8400 reads a too high 1.360v in bios
602 Bios: Vcore on Auto with E8400 reads about 1.185v (forgot to note exact voltage)
I have my Vcore manually set to 1.24375v with an E8400 @ 3.6Ghz. Bios Reads: 1.208. Windows Reads: 1.216. Windows Under Load (with Loadline Calibration On): 1.192
601 Bios was a "beta" according to the Asus Website. No info on 602 bios. If they follow their pattern,
602 should not be a beta. If anyone finds the release notes to 602, let us know!
INTREPID is offline   Reply With Quote
Old 02-28-2008, 05:00 PM   #1089
VinnyG
VinnyG's Avatar
thanks
When the BIOS hardware monitor says 12C for the CPU when its really 21-22C, there is a problem. Its also a noted issue as far as Im concerned over at the Asus forums. I use air cooling and ambient temps are 21ish degrees... As far as I know, its impossible for standard air or water cooling to be below ambient.
Its moot point, really, since everything else works:P
Old 02-28-2008, 08:45 PM   #1090
INTREPID
I have an E8400 @ 3.6Ghz. with an Ultra 120 Extreme. I wonder why my core temps are reading normally with bios 0602 while others are having problems. Or are these temps too low?
CoreTemp & Everest -
Idle: 25C
Stress with OCCT: 38C
Stress with Orthos: 40C
Old 02-29-2008, 03:44 AM   #1091
Darknezz
Well I just got the new 0602 bios in an it runs much better than the 0601. I am running my Q6600 at 3730mhz on air 8x465 with my Transcends aXeRAM DDR 1200 at 1200mhz before i had too run them at 1103mhz.
Darknezz is offline   Reply With Quote
Old 02-29-2008, 05:42 AM   #1092
VinnyG
VinnyG's Avatar
Idle: 25C
Thoses actually seem good. (Im having problem with the 0502/0601 BIOS not the new one as I havent tried it yet...)
Old 02-29-2008, 06:47 AM   #1093
doakh
doakh's Avatar
Originally Posted by Cranox View Post
602 bios is out dunno what the changes are , anyone brave enough to test it
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...-ASUS-0602.zip
I updated to Bios 0602. No problems. The only change I can find was to expand the 'tRFC' memory latency manual settings.
I installed the update from my harddrive. I created a 9MB FAT partition and EZ Flash instantly recognized it. This is easier than using a flash drive.
__________________
Old 02-29-2008, 09:02 AM   #1094
Darknezz
I am Having problems with random shutdowns i can prime it but after primeing it sometime it just reboots???
__________________
Cpu E8500@4500 E0 Batch#Q82A790
Water cooling/ ThermoChill PA120.3 - Laing D5
Swiftech MCRES-Micro AGB - Swiftech Apogee GTZ
Ram CellShock 4x1Gb PC2-8500
ASUS Maximus II Formula
PSU Enermax Galaxy DXX EGX1000EWL
GTX280 core@729 Ram@1250 Shaders 1520
Harddrives 1xSeagate 120Gb 2x500 maxtor SataII
Old 02-29-2008, 09:59 AM   #1095
screwtech02
Something different with 602, i cannot acheive the same overclock with the same settings, without upping the volts more.... And the memory timing "expansion" looks to be pretty basic.....
__________________
Gigabyte X58 UD4P
I7 920@3.8
4850X2 x2
X-Fi Titanium
Old 02-29-2008, 10:34 AM   #1096
EagleRock
Xtreme Cruncher
EagleRock's Avatar
602 seems to be better with overclocking the memory.
mine will not go over 960mhz stable on 601 and now seems to be working ok at 1066mhz
i like the new bios
__________________
Asus P5E, Q6600 G0, Thermalright 120 Extreme, 4GB OCZ Reaper, Ati 4870 X2, Corsair TX850W, Coolermaster HAF 932, X-FI XtremeGamer, WD Caviar Black 1 TB, Samsung 500GB.
The world needs your support.
Join The XS WCG team and help cure Cancer, AIDS, and other diseases.
EagleRock is offline   Reply With Quote
Old 02-29-2008, 06:29 PM   #1097
lowtcell
lowtcell's Avatar
Alright, I flashed 602. There is no improvement in the G-Skill, still capped @ 1066 (not the board's fault) but now my CPU temp reads 9-17c and setting vCore to 1.365 in Bios shows up as 1.334 in CPUz, Bios monitor and AISuite, although I'm 100% stable @ 3600 now at that voltage.
PS.
SPD Tab in CPUz now only shows only module size, WTF?
__________________
Old 02-29-2008, 10:19 PM   #1098
Milamber
Milamber's Avatar
PS.
Download the latest CPUZ... Version 144.1.
Its important to keep with the times, new hardware and old software versions don't mix to well.
Old 03-01-2008, 12:50 AM   #1099
aiya_au
aiya_au's Avatar
THANK YOU ASUS for this bios. fixes all my 1066mhz ram problems.
my crucial ballistix tracer 8500 2x1gb use to fail at stock settings with the 0502 and 0601 bios's. With the 0602 bios, i just completed 20passes of memtest finally.
i've noticed that with the 0502 and 0601 bioses, memtest reported a bandwidth of 5593mb/s at stock speed. The latest bios reports 4895mb/s. so i guess to increase stability, they reduced the speed a little.
finally i have a stable system with no random BSOD's from ram errors
__________________
CPU Intel E8400 4.3ghz (9x478), Poseidon WCL-04 Water Cooling | RAM Crucial Ballistix Tracer PC2-8500 2x1gb | Motherboard Asus P5Q Deluxe | Graphics Card 512mb ASUS 9800GTX+ | Audio X-Fi XtremeMusic, Logitech Z-2300 | Power Supply Corsair HX620 | Case Antec 900 | Input Devices Razer ProClick, Logitech G15 | Display Device Dell UltraSharp 2408WFP, Samsung 226BW
aiya_au is offline   Reply With Quote
Old 03-01-2008, 01:23 AM   #1100
dreamluc
Send a message via MSN to dreamluc
Now, which bios is the best? Just the newest?
dreamluc is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
