Results 1 to 11 of 11
Thread: i650 SLI motherboards
    Sep 2004
    I can't seem to find much other then a few reviews about any of these boards, just looking for more advice as i'm stuck on what one to buy.
    ABit Fatal1ty FP-IN9 SLI
    MSI P6N SLI-FI
    ASUS P5N-E SLI
    I would like to keep the price down, the i680 is too expensive for me. I know ASUS makes a dual 16x pci express mobo of i650 but that too is really expensive, I"ll probably have dual 8600 GT in there.
    A64 Venice 3000+
    DFI NF4 Ultra-D
    X800 XL
    1 GB OCZ Gold 2-2-2
    520 Watt Powerstream
    Xtreme Cruncher
    Mar 2005
    Lancaster, PA
    Dual-core, the P5N-E SLI is a nice board. I got up to 490fsb on my E6400, but that's as far as the chip itself would go, so it's possible it could have gone further.
    If you're going quadcore, don't even consider any of the 650i boards. They will all have a fsb wall around 333fsb.
    A wolf in wolves clothing.
    Sep 2004
    I have an E2140 that can do 420 FSB
    A64 Venice 3000+
    DFI NF4 Ultra-D
    X800 XL
    1 GB OCZ Gold 2-2-2
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    yup P5N-E SLI
    but you have to do the vcore pencil mod or your gunna get massive vdroop
    and the bios voltage setting isnt what it really is so the vcore pencil mod is a must.
    after the pencil mod 1.3 will equal like 1.35 w/ zero droop.
    1.45 = like 1.5+ so you have to be careful what you set it to.
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    Jun 2006
    Asus was the best of those afaik
    Your better off with one gfx card unless you have a need for lots of monitors? Get a 2900pro
    Sep 2004
    i already have one 8600 GT and will get the other one froma friend for well under the retail price.
    A64 Venice 3000+
    DFI NF4 Ultra-D
    X800 XL
    1 GB OCZ Gold 2-2-2
    Sep 2004
    I just picked one up thanks.
    A64 Venice 3000+
    DFI NF4 Ultra-D
    X800 XL
    1 GB OCZ Gold 2-2-2
    Xtreme Guru
    Aug 2003
    Athens, Greece
    One word of advise, replace the stock heatsink with an active aftermarket or place a fan on the stock.
    Project ZEUS II
    Asus Rampage II Extreme
    Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
    3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
    2 x Asus HD 6870 CrossFire @ 1000/1100MHz
    OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
    Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
    Watercooling setup:
    1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
    2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
    Assembled in Mountain Mods Ascension Trinity
    Powered by Corsair Professional Series Gold AX1200
    Jun 2006
    I used to do that for the NB but now I have just lowered the case temp and its not nessecery
    Jul 2007
    MSI P6N SLI-FI is a great board is great i have the sli plat version and it's really good. Great for OCing i got mine upto 3.65g.
    Apr 2007
    Portugal
    P5n-E sli is a great board, i have my PD805 at 3,7 and is fine.
    PD 2160 - 3,2ghz
    100%OC -3,6 (1.6375v) - Aircooling
    GSkill DDR2 2GB-6400 (500mhz)- 5-5-5-15
    Crucial Ballistix 8500 500mhz cl4; 600mhz cl5 (2,1v)
    (7600gt- Accelero - less 20ºc load- without fans)
    MSI 8800 GT OC
    Thermalright Ultra 120 Extreme
    P5E (107)
    Corsair 620HX
    AerocoolaeroengineII
