I am supprised no one here knows the answer to my question.
_____________________________________________
Rig = GA-P67A-UD3P Rev 1.0 - 2600K @ 5.2~GHz 1.5v~, 1.489~v Under Load - Swiftech Water Cooling - 2 X 4GB Corsair DDR3 2000Mhz @ 1868MHz~ 9,10,9,27 @ 1.65v~ - Asus 6970 @ 950MHz / 1450MHz - 3x Western Digital RE3 320Gb 16Mb Cache SataII Drives in Raid0 - Corsair HX 850w Power Supply - Antec 1200 Case - 3DMark 11 Score = P6234 - 3DVantage Score = P26237
System temp isn't "NB temp".... it's "motherboard" temp... sensor is somewhere next pci-express x16 slot1, I think....
( I have a high temperature in system temp because of my 8800 ultra oc, I think.... )
IL MENNE Q6600G0@3.2 - Scythe Infinity@2*Nanoxia FX-12-2000 - Gigabyte GA-X38-DQ6 - 4*1gb Vitesta 8500+ Extreme Ed. (Micron D9gmh) - BFG 8800 Ultra OC - 2*Cheetah 15K.6 146gb SAS ( raid0 ) on Dell Perc 5/I - 2*WD Raptor 74gb (Raid0) - Seagate 7200.11 500gb - Seagate 7200.10 ES 500gb - Toughpower 750w - Hardcano 12SE - Armor Silver - Samsung 205BW - SL DTS/5.1 Digital * Me * Me2 * MyDesk * Me3 *MyOldPC
Ok thank you guys, I just wanted to make sure I was right about that then I need to get cooling for my NB because that is what is holding me back with my overclock. I am going to order some thermalright chipset coolers for her and that should resolve any heat issues.
I don't think so. I have a 9450 and can get it up to 465 x 8 then it starts to need more voltage on the nb +.5 or whatever it is to be specific and at that point it starts getting to be to much for it to handle.
I'm guessing that is what is wrong with it,, either that or this board is just for the 9450 or the 9450 is I have but, I don't think it is the chip to be honest because it seems like it is running fine at like 1.3v~ for the 465x 8. Advice would be awsome.
Should I get chipset coolers for this or leave the stock on it. I think the stock is not doing the job good enuogh at high voltages. Is there a vdroop pencil mod for this board?
CoOl I will go to microcenter today and pck one up but, is there a vdroop pencil mod for this board does any one know?
[SIGPIC][/SIGPIC] CoolerMaster Stacker 830SE|Antec Signature 850W|Gigabyte X58A-UD5 F5 slic2.1
Intel Core i7 930 16x200@3,200Mhz|vcore 1.14|Intel Stock CPU Cooler
GSKILL DDR3 Perfect Storm 2000 @6-6-6-16-1T 1600Mhz|ATI 5870 1024MB 850/1200
Windows 7 Ultimate x64 bootdisk: Crucial RealSSD-C300 128GB SATA-III
That sucks the vdroop on mine is bad like, .1v so, I say give it 1.35v and it gives it 1.25v.. with loadline enabled yes. I got the fans for my beast last night I got a spot cool for my memory and a little powerfull quiet fan for my chipset and a new more powerfull fan for the side of my case " that makes like ten fans in her now lmao" and was able to run prime95 all night with the following settings, 450x 8 = 3.6Ghz , CPUv 1.35v actuall 1.25v, fsb term +.1 and nb +.3 and PCIEv +.2. I would say at this point I should be able to get 3.8Ghz easy,, and possibly even 4ghz.Some one really needs to figure out how to do a vdroop pencil mod on his thing tha would be sweet.
Good news is the vdroop is only really bad under load conditions
when it's idle it's not too bad,
so try not to run any games or demanding apps and it should be ok
But seriously folks, vdroop is the only gripe I have left for my x38-dq6
apart from that the board is sweet after a dozen or so bios revs.
Finally, I have seen a proper mod for the vdroop for my board, maybe there's one for the ex38 as well if you feel confident to try it, I wasn't game.
Vdroop on my ga-x38-dq6 with loadline calibration activated is only 0,01v ( full load ) .... pretty fine!
Actually mine was overvolting about the time he wrote it was bad only under load. It was actually overvolting quiet a bit to. I just ordered an Asus P5Q Deluxe P45 board though so, things will get better now . Bye Bye Gigabyte . I lost both my MBs in an electrical storm Saturday by the way. The lighting went through the cable modem and zapped my EX38 DQ6 completely and just fried my Fiances Nic on her P35 DQ6. I am sending the boards back seperate to avoid them saying this was electrical and bought that new board which will be here tomorrow and when I get the EX38 DQ6 back,, I will proably sell it on Ebay or to some one here if they want it.
Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
hi,
I was wondering when a new bios would appear for this X38T-DQ6 mobo? still at f7b at the moment.
No hurry, just a little
DiKKeneK fan !!
Silverstone CW02 HTPC Chassi
Q6600
2 x GB Mushkin PC1066
GA-X38-DQ6
Scythe Ninja Rev B
3WARE 9650SE 4Lane RAID Controller
1xRAPTOR 150GB
4x500GB 1.5TB RAID 5 ARRAY
8800GTS(G92) 512MB
700Watt Thermaltake Modular PSU
New BIOS for EX38-DQ6 today, F3 final
http://www.gigabyte.com.tw/Support/M...ProductID=2760
EX38T-DQ61. Support DES Advanced
2. Update CPU microcode(Support Intel Wolfdale/Yorkfield E0-stepping CPU)
http://www.gigabyte.com.tw/Support/M...ProductID=2762
Edit: looks like all EX38 got new bios today.
GA EX38 DQ6
C2D E8400 @3.8Ghz
2x2GB Corsair 8500 C5D
XFX 8800 GTS (G92)
2x WD2500YS
X-FI(XM)
Intel PRO/1000 PT(PCIe1x)
TT 750 Toughpower PSU
WinXp x64/Server 2008 x64
I-LOVE-FANS-I-LOVE-NOISE-RIG @ -10dB
(needed to wire a 10dB speaker to PSU to understand if it posts!)
Gigabyte GA-X38-DQ6 F7
2 GB DDR2-1066MHz Kingmax [5-5-5-16 tRD 5]
Q6600 @3.20 GHz [WB: Zalman ZM-WB5] 8 x 400MHz 1.35v +0.25 DDR +0.05 gMCH
Gigabyte 8600 GT [WB: Zalman ZM-GWB3]
Samsung 500GB SATAII [WB: Innovatek HD-O-Matic] + wrapped with sound absorbing material
Silentmaxx 500W PSU [WB: Built-in]
LG Flatron 915FT Plus [19" CRT, hate LCDs alternate: HP w2207 22" LCD] + Panasonic PT-500AE 100"
Aopen H700C Full Tower
2008 Server Enterprise x64
Zalman Reserator XT [f***ing fan removed , DTek DB-1 Pump wrapped with sound absorbing material]
Any body overclocking on X38_DQ6 have problems with bios resetting overclock setting back to stock settings randomly?
custom case
I7 2600
GIGABYTE P67A-UD7 b3
8gb gskill ripjaw 1333 ram
Samsung f3 1tb hdd
my first custom case build
Just so y'all know...i'm done with the X38 model and have purchased the EP45-DQ6, though i haven't physically installed the mobo as yet. Few weeks before i install...as such updates and what not will be located at the official EP45 thread.
