Could I get people to post their OC settings/GTL settings
If I can get people to post their overclock settings and GTL settings, I will take the time to make a chart and post the results. I know that the GTL settings and voltages vary, and that there is no "one" magic setting, but I think it would be helpful for newcomers to see what other people are using.
If willing, please post your processor type, overclock achieved including multiplier and FSB, and GTL settings. As GTL is tied to voltages, please also note CPU VTT and NB core voltages.
Note: I would looking for STABLE settings, don't list what worked for only an hour or two.
Praz has suggested the following: If you are going to do this might also want to list BIOS version as VTT/GTL tables are slightly different between a couple of versions. Might also want to list stability something like this. Prime95,Blend/2hrs or Orthos, sFFT/4hrs.
Why don't we add Prime 95 Blend for 4 hours as a requirement using Prime 95.6, which was linked on last page. That way we will get settings that are at least close for others to try.
I will compile a list of results in 1 week to give everyone time to verify their results are stable.
__________________
Silverstone Temjin T09BW Case|Thermaltake Toughpower 1200 W Modular PSU|DFI Lanparty LT X38-TR2 Motherboard|Intel Q6600 G0 Batch #L737B075 Quad Core Processor @3870 MHz 8 hr Prime95 stable|D-Tek Fuzion Waterblock with Quad Nozzle|Enzotech SNBW-SLI Northbridge Waterblock|Enzotech SLF-1 SB HS/Fan assembly|Swiftech MCP655 Pump (set on 5)|Swiftech MCRES-Micro Reservoir|Thermochill PA120.2 Radiator w/2 Scythe Minebea 41 cfm 120 mm fans|Masterkleer 7/16" I.D. Tubing|Corsair Dominator PC-10000 DDR2 Memory (2 x 1 GB) with Dominator Fan| ATI HD2900XT 512 MB Video Card| 2 Seagate 7200.10 250 GB 7200 rpm Hard Drives| Samsung SH-S203B DVD Drive
Reason: Added request for BIOS version and verification of Prime 95 stable for 4 hours
__________________
#1 Rule Of The Internet - The majority of writing stated as or giving the impression of fact is little more than the author's opinion. And more times than not that opinion is based on little or no knowledge of the topic.
What bios are you people with these new 45nm chips using?
Installed my chip with 24/12 on and it worked ok. Booted up went int bios and changed my hdd settings and a few other things, didnt change any cpu or ram settings. Saved and restarted and nothing, error codes all to crap. Was just stuck on a 1 second boot then stop loop. Reset bbios with jumpers same thing, took battery out and left it a while put it back in, no difference.
So i put an old P4 chip in to make sure the board was ok and it booted fine.Flashed bios to latest beta 1/09 and put E8400 back in and same crap happens.
Had battery out for 2 hours earlier still not going right but managed to get working after pressing the ezclear switches for a bit. Dont wanna restart now in case it dont work again.
I've got the same problem with my E8400 when using 12/24 or 01/09.
11/07 works like a champ.
__________________
Asus Rampage II GENE | Core i7 920 D0 + Prolimatech Megahalems | 3x2Gb G.Skill Trident 2000MHz | Ati Radeon HD 5870 | Intel 80Gb X25-M G2 + WD 640Gb Caviar Black | Auzentech X-Fi Forte 7.1 | Corsair HX620W | Antec P180 Mini
Anyone with Wolfdale noticed your CoreTemp posting weird/inaccurate temps?
I'm using CoreTemp 0.96.1 & noticed that my temps aren't moving, when i compared it to SG, it's way way off...could this be a bios thing? (01/09 Bios)
I have a similar issue using the 12/24 bios. just got the cpu last night and am apparently experiencing very high core temps (55C idle, 83C load, 20ishC ambient, 1.29ish volts) using a scythe ninja and arctic ceramique. temperatures were virtually identical after reseating, and were radically lower using same mounting techniques and e6600.
so my question lies in the image below. Everest shows my cpu temp is a much more plausible 38C. could the core temps be erroneous? i primed all night at 8x500 with core temps as high as 83C, which shouldn't be possible, right?
Edit: more info - shows CPU Core Temp of 51C in bios, if that helps
No more Wolfdale for me my 2nd one just popped @ 4.2Ghz 1.475v
I don't think the DFI likes these 45nm chips too much!!
Back to the Q6600 for me
__________________ PLAY RIG CUPBOARD IS BARE ATM !!!! SHALL I i7 OR NOT
HOME 24/7 RIG DFI LP UT P45, E8500, 4GB OCZ PC2-6400 REAPER X , EZ-COOL 600W PSU, GE-CUBE HD3870X2, 2 X 80GB HITACHI SATA 2 HD'S IN RAID 0 + 2 X 250GB MAXTORS MIRRORED + 1 X 500GB MAXTOR, VISTA ULTIMATE SP1 (32 BIT)
WORK 24/7 RIG DFI LP DK P45 PLUS, E8500, 4GB OCZ PC2-8000 REAPER X, EZ-COOL 700W PSU, RADEON HD3450, 2 X 160GB RAID 0 + 2 X 160GB SAMSUNG'S SATA 2 HD'S IN RAID 1, VISTA ULTIMATE 32-BIT SP1, CPU COOLING : TUNIC TOWER 120
OLD FAITHFUL DFI NF4 EXPERT, OPTY 144, 1GB OCZ PLATS, 600W PSU, 6600GT, 60GB MAXTOR, XP PRO - SP2, CPU COOLING : STOCK
Yikes what were the batches and vids on those two that died?
That sux! I can see why you'd want to go back to quad. I'm getting my second 8400 thurs but I haven't had any problems as far as I know. My max vcore has only been 1.45 so far. I'm really curious to see if they degrade at all though.
Thats like the TLB Errata Problem with Phenom nobody gets it but yet the Propaganda Train is Rolling at Full Speed down the Tracks delivering disinformation to all of the girls and boys.
__________________ D.F.I LanParty DK 790FXB-M3H5 ~ 7/27/2009 ~ "Beta" Bios
AMD Phenom II 720 Black Edition ~ For Bios Testing
Custom Water
2x2gb Crucial Ballistix Tracer 1333mhz 6-6-6-20
POWERCOLOR AX3870 X2 CROSSFIRE
ULTRA X3 1000w
Danger Den Torture Rack
Or just maybe Intel is not as forthright as AMD is about current offerings and problems associated with them!
Originally Posted by BlueAqua
Well since he's the only one I've seen that has killed a cpu(well two now, cheer cheer) I doubt it's a widespread problem.
Difficult to know where to stand on this one guys but I know I'm not raping them with voltage or cooking them & like you say I haven't heard of any others die apart from one 8500 but that was blamed on the PSU.
1st one Q745A 2nd one Q744A both had 1.1125v vids to start but I did notice both of the vids changed in core temp down to 1.03** & 1.0500v respectively just before they died.
My 1st one had been to 1.4v for a short period of time but it was at 1.3625v when it died, I noticed no degradation it just popped.
My 2nd one had been to 1.6v & I did notice it lost the ability to boot into windows @ 600fsb within the first few hours but it could still hang 590 fine. I also ran this one overnight at 4GHz & 1.4v & it was fine but today when I started pushing up the fsb from 500 to 512 I noticed the CPU needed an extra bit of voltage to do what it had previously benched.
I was happy 4.1GHz was/would have run fine & moved on to 4.2GHz & after about 1 hour of benching the CPU needed another small voltage bump from 1.45~1.475v to run what it had already been running fine at. At this point I started to think the CPU was degrading & thats when after checking all my BIOS settings again I noticed the vid had changed!! literally 15 minutes later it died.
I have my Q6600 back in with all the same hardware & she's doing 480 x 8 with DDR1200 & all is well again.
CN
GTL 1/3 corresponds to the first two threads of Prime95. GTL 0/2 matches up with threads 3 and 4. If either thread for one core consistently fails adjust the CPU GTL for that core. If the failures are random between cores adjust NB GTL. You need to use Prime95 v25.6d.
Regarding the GTL percentages,
what is the minimum or maximum value we should start from?
I mean what is the starting point to find a stable setting?
I am looking forward for your E8xxx results
Also, how is VTT is related to vcore? I can boot into Vista 64bit and play FSX for about half an hour and surf on the net with NO problems at all, but Prime/Orthos fail withing the first 5 seconds!
I can do a SuperPi 1M and 32M without problems.
Is there any incompatibility with prime and Vista 64??
__________________
DFI LP LT X48-T2R | E8400@4050 | OCZ ReaperX 4x2Gb 1066 | Viewsonic 20" VP2030b | ATI 4850 | Corsair HX620 620w | Samsung SLC, 2x Samsung MLC @raid0 | Lian Li PC-V1100B PLUS II | Logitech G5 | Saitek Eclipse black/blue light | Logitech Z-5500 | Laserjet 1320 | 11 custom block - ford transit radiator - eheim 1250 pump - Danger Den Bay Reservoir 5.25" - cheap tubing 1/2"
So far it seems like the 8xxx processors are happy with CPU GTL values around 63% with the NB GTL at 67%. Be sure you're using the 64 Bit version of Prime.
__________________
VTT needs to be whatever value stabilizes the bus regardless of VCORE.
__________________
Ya, we all know how forthright AMD has been...
These chips have the most changes to CMOS design in 40+ years. We cannot claim to understand how they react to overclocking without trying. Its not like they had problems with 65nm.
Whoa.
Can any EE/CompE's theorize what that means? Or how/why a changing VID value would be linked to a dying Wolfdale?
*and now I just realized. I wonder if any of this funny business is linked to the quad delays?
Hi Praz. You linked us earlier to a new build of Prime95 being 2.56d. Was that a link to the 64 bit version, or the 32 bit version? If it was the 32 bit version is there a link to a true 64 bit version of the new 2.56d? Thanks.
__________________
Silverstone Temjin TJ-09BW w/ Silverstone DA750
DFI Lanparty UT P35-T2R
Q9650 @ 3.62ghz w/ Thermalright Ultra-120 Extreme w/ Sanyo Denki San Ace 109R1212H1011
4GB Crucial Ballistix Tracer PC2-8500
EVGA GTX 260 Superclocked+
Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
Intel Pro 1000/PT NIC
1 X 120GB OCZ Vertex 1.30
1 X 300GB WD Velociraptor HLFS
1 X Hitachi 7K1000 1TB
Pioneer DVR-216L DVD-RW
Windows 7 Ultimate 64
Originally Posted by alexio
From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
__________________
Great, thanks. I actually found it myself browsing through the FTP and was just coming back here to post the link myself, but you beat me to it.
Would you say the 64bit version tests differently than the 32bit version under a 64 bit OS to the point that it may fail a test where the 32 bit version wouldn't?
__________________
Don't know. I'm sure it's tuned for 64Bit operation whatever that may mean. On the surface it looks like a very simple program. But the fact is it's full of jumps and branches that are dependent on platform, processor type and chipset. So most likely there are significant differences between the two versions.
__________________
Ok, guess I better start testing with the 64bit version to see how it holds up compared to the 32bit version which held up quite well at my current OC. Perhaps I will be in for a nasty surprise on the 64bit version but let us hope not.
__________________
