So the way you have your red Line drawn in that pic is the way the pencil is suppose done....
Please if someone could confirm the pic and the redline..I would greatly appreciate...Getting my MM case and all my W/C and my 9650 today. Would like to do this mod now...Thanks
Could someone take a pic of the internet of the 780i board and circle where the mod is suppose to go..Because the area that needs to be done is different than the 680i...Sorry but I dont want to do the wrong place...Iam already nervous going W/C...
Ok if someone will take the time out of thier busy schedule and take a pic of thier board with the mod done on a 780i evga or xfx and circle where the mark is suppose to be i will give you a 2g ddr2 800 Supertalent stick of memory...
There has been no pics posted with the mod done on the 780i mobo. only the 680i And from what I can tell they are not positioned exactly the same. So I just what be double sure iam doing the right one
thanks anyway..After looking at the pics..Blown up on the 680i and the xfx 780i the scratch places are in the exact same place..not sure what I was looking at before
__________________
XFX 680i LT Sli
Intel E8400
Tuniq Tower
4 x Corsair XMS2 1GB DDR2 800Mhz
2 x 7900GS (evga/pny)
Ultra Xfinity 600W Titanium
Coolermaster black mystique
1 x WD 80GB Sata
2 x WD 160GB Sata
1 x WD 320GB Sata
1 x 20x/20x DVD-RW/DL Sata
Dell 1708FPt
Razer Tarantula
Ratpadz GS
Ruckus, I just did the vdroop on the same XFX board with good results. With Core set to 1.5v in BIOS:
IDLE LOAD
Before: 1.464 1.440
After: 1.480 1.480
It got the voltage closer to what its set to, and completely stabilized it under load. I'm about to start working up an overclock. With a Q6600 on a 680i board I know that I'll likely be limited, but going to do the best that I can.
__________________
XFX 780i SLI (P08)
Intel Q6600 G0 @ 3.2GHz
Custom Liquid Cooling
2 x 2048 Patriot DDR2
2 x BFG 8800 GTS 512MB @ 715/2000MHz
1WD Raptor 150GB, Seagate 320GB SATA2
2x 16X DVDR/RW
PC Power & Cooling 750wt PSU
Silverstone Case
Sorry, newcomer here. I tried this mod, but I set 1.3 in BIOS, but it reads 1.264 in Windows on load. Did I do something wrong? I used a 2B pencil and did a couple passes over the resistors.
My board's voltage would normally drop about 0.05v from where I set it and 0.675 when under load. I did the pencil mod on the blue points very heavily because it wasn't showing at all after about 10 traces.
I'm now at the point where if I set the voltage to 1.25v it reads at 1.23 in the BIOS and 1.232 in CPU-Z at idle and under load. It's still below the BIOS setting but doesn't variate at all anymore. Basically what I'm asking is will it be safe to take the resistance all the way up to where if I set it to 1.4 in the BIOS it stays at 1.4 at idle and under load?
I just wonder if it's safe for there to be no variation in the voltages when under load. Thanks.
