Hi,
I have a X2 6000+ on a Crosshair and is really giving me a headache trying to OC' it, I'm starting to think that either is a problem with the Mobo or the settings.
Sometimes it stays stable at 3.4GHz, others crashes only at 3.2GHz. It isn't a CPU temperatures problem cause they never go above 45º, I think it's the Mobo instability in Voltage.
Some info:
Could someone with a system similar as mine post the complete settings of the BIOS? So that I can't compare them or try them if they are different to some of myne, I'm really going nuts with this.
Thanks.
EDIT: Sorry if this wasn't the right thread to post this request but this one was in wich I found more info with systems similar to mine.
If anyone decides to take the time to answer me and don't want to post here, please feel free to send the info in a pm.
INTEL Q6600 @3400MHz (D-TEK FUSION + BIP 240GTS)
ASUS RAMPAGE FORMULA (AIR-COOLED/ATMOSFERIC)
4X 1GB TRANSCEND AXERAM 1200MHZ 5-5-5-15 (ATMOSFERIC)
BFG 9800GX2 1GB ( BIP 120GTX)
CREATIVE X-FI FATAL1TY CHAMPION SERIES (AIRCOOLED)
PINNACLE PC-TV PRO (DON'T NEED NO COOLING)
2 RAPTORX @RAID + 1 RAPTOR 150GB (AIR-COOLED)
THERMALTAKE TOUGHPOWER 750W SLI
THERMALTAKE HARDCANO 12SE
for HTL maybe u can lower a bit, then try to add sum vcore..
mind to attach ur ram tab (cpuz)
CPU: Intel Core i5 660 @ 4GHz / 1.28v
CPU COOLER: Cooler Master Vortex Plus
MBD: MSI P55-GD65
RAM: 1GB Adata
GFX: ATi Radeon X700Pro 256MB
HDD: Samsung Spinpoint F2 1.5TB
PSU: Thermaltake Toughpower 750W
VcoreA and B are not from core 0&1 respectively as in every K8 chip the Vcore is the same for both cores on die.
i would trust cpuz in this case.
maybe a bad die to ihs or ihs to hsf contact?
anyway, its really nice speed for 1.328V
My Rig X6 1055T|Crosshair IV Formula|8600GT|2x2024MB@1800|436GB storage
MBD: MSI P55-GD65
RAM: 1GB Adata
I know it goes higher, but I like low volts.
low voltage is just a number; high frequency is something I can relate to
Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
32 GB Patriot Viper Steel 3733 CL14 (1.51v)
RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
Tons of NVMe & SATA SSDs
LG 27GL850 + Asus MG279Q
Meshify C white
I like low volts as well, especially because I can see on my KillAWatt how it affects power consumption.
For everyday use my Rig is taking 150-200W in normal usage and around 340W when gaming. If I want absolute max from it then welcome to 400W area !
My personal best was touch of 700W when Cross Firing some 3DMark06
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55'' Samsung LED 3D TV
Hi!
I have 2 X2 5200+, both are F3 but the steppings are CCB6F 0710UPMW and CCB6F 0712UPMW.
I'll be testing with MSI K9A2 Platinum 790FX next week. What can I expect from this CPUs?
Thanks!!
Hopefully they will oc to 3GHz ++ the 5200+ is one of the best! Post your results when you're done
just for fun
single core processor
AMD ATHLON LE-1600
BACTH CODE CCB8F 0739 BPMW
validator : http://valid.x86-secret.com/show_oc.php?id=275010
Sorry for my bad english
nice one, but aint that pi a little slow? i can do 34.9s at 3400mhz under vista...
thats the power of 45W Cpu!!!
haha , saw some of my buddies here
decided to show up myself
dblooi from malaysia reporting in
cpu: AMD Athlon64X2 3800+ F3
ram: crucial 10th anniversary
mobo: Biostar TA690G
HDD: WD Raptor 740GD
PSU: TTGI 500W Modular PSU
Cooling: custom Water cooler + ice
super pi 1M : 21.734s
CPU-Z validation: http://valid.x86-secret.com/show_oc.php?id=266568
another SS from me
anyone knows who is FX55?
btw, my proc batch no. is CCB8F 0736GPMW
cpu-z validation: http://valid.x86-secret.com/show_oc.php?id=266567
Welcome dblooi. Nice SP1M!! Wich stepping you got? Awsome oc on thet board too! That actual vcore cpu-z showing?
EDIT: The fx55 score is a bug, the actual score is 2601,67MHz: http://valid.x86-secret.com/show_oc.php?id=125901
hi likmark ,
Batch Code is 0736 GPMW
actual vcore is showing in SS, 1.7v
CPU-Z 1.41 has no issue in reading correct vcore
FX55 actually did make it to 7GHz (But how he make it , i hv no idea ),
The cpu-z server has bug on this,
when u click on the [detail] , it shows the 1st attempt of the user instead of showing the actual result.
Try to click on mine, you won't see the 3.9GHz result as well
I see, found something else too
nice score .. congrats..
New toys bought today.
Maybe someone remember the stepping of the 1620 from my other one..
Next week Dryice session with all that stuff.
My 6000+ which i will test too.
PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
Fantastic OC dblooi!
What cooling you're using to reach that clocks on X2 3800+?
@funkflix
DI session will be interesting
Your 1620 is terrific!
